09-21-2018, 10:27 AM | #1 |
How to: Extend Lower Control Arms
I recently extended my front lower control arms 40mm using the Villains Drift extension pieces. It was pretty straight forward, so hopefully this video helps anyone looking to do the same.
Thanks!
https://www.youtube.com/bennyobscene |
10-04-2018, 08:14 AM | #3 | |
obscene: curious why you didn't plate the bottoms of them like most people do? Seems like while you're already in there, might as well. |
10-04-2018, 01:38 PM | #4 |
probably cuz he read this on the villains page
Q: Do you box the LCA's? A: No, not anymore. Having extensively tested both methods we found non-boxed arms handle the rigors of drifting absolutely great! In the worst case scenario of a crash, the arm folds up and absorbs the impact saving the coilover, Cross-member, tension rod and tension rod bracket. |
10-07-2018, 05:57 PM | #6 |
Correct, I went with the idea that these would fold up first when I hit something.
Thanks for watching!
10-07-2018, 06:00 PM | #7 |
I'm all for bracing when it's the actual chassis or sub-frame. It's the stuff that's bolted to the car that I'm fine with destroying.
extended control arm, lower control arm |
