Old 06-24-2017, 12:51 PM   #1
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
Sr20 no start, possibly bad gas?
Sr20 s13 with t28, 550 sti injectors and z32 MAF with rs enthalpy ecu tuned for the setup. Has spark, has fuel, good battery, turns over great but acts like it's not even trying to fire. Have checked over everything I can think of and the only thing that comes to mind is the gas has gone bad from sitting (5-6months) but even if that was the case I'd think it would still try to start and just run poorly
Other than that I'm out of ideas, any other things it could be? Very busy these days and have limited time to mess with the car so trying to get a list of everything I can check before I go mess with it again.
Gonna try to start it on starting fluid and drain the tank and fill with fresh 93 on Monday but won't have time to until then
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 06-25-2017, 12:16 PM   #2
1988montecarloss
Trader Rating: (24)
Tried it on starting fluid, still nothing. Car popped a couple times but still isn't even trying to start
IG: @Haley72692
Old 06-25-2017, 12:34 PM   #3
wurley
wurley's Avatar
wurley is an unknown quantity at this point
gas gone bad after 6 months
I just started a car last week that had been sitting for 3-4 years, ran fine.
Did it run before it sat? if not you might want to check timing and or compression
@hiddenkouki
WTB: FRONT S14 SILVIA Q'S SEATS purple zebra)
wurley is offline   Reply With Quote
Old 06-25-2017, 12:39 PM   #4
1988montecarloss
Trader Rating: (24)
Daily drove it until last December when I parked it because of winter, planned to big turbo It and didn't so only things that have changed is that I took the injectors/computer out and then put it back together
Timing has never been messed with and compression is 140-145 cold
IG: @Haley72692
Old 06-25-2017, 04:49 PM   #5
wurley
wurley's Avatar
maybe try unplugging the maf or coolant temp sensor. My only guess is either the mixture is way to far off or the spark is too weak
@hiddenkouki
Old 06-26-2017, 08:50 AM   #6
jedi03
check for teeth marks on wires...mice love to get warm in the wires for some reason...
Old 06-26-2017, 05:24 PM   #7
1988montecarloss
Trader Rating: (24)
Have tried both, it's acting like it's not sparking at all but if I pull a plug out and put it in a coil I can watch it spark
IG: @Haley72692
Old 06-26-2017, 05:26 PM   #8
1988montecarloss
Trader Rating: (24)
Haven't seen anything but i suppose it's worth a look
IG: @Haley72692
Old 06-26-2017, 08:56 PM   #9
wurley
wurley's Avatar
are the cylinders flooded with fuel?
@hiddenkouki
Old 06-27-2017, 05:49 PM   #10
1988montecarloss
Trader Rating: (24)
Nope, the plugs will get wet and if I pull plugs and Crank it I can see fuel come out of the cylinder but it doesn't build up to the point where it fills the cylinder any
IG: @Haley72692
Old 06-28-2017, 12:09 PM   #11
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
I would try to reset the CAS. Has it ran before?
instagram : battery1882
www.sterculture.com
battery1882 is offline   Reply With Quote
Old 06-29-2017, 04:32 PM   #12
1988montecarloss
Trader Rating: (24)
Yes have daily driven this car 25k miles with basically the same setup
IG: @Haley72692
Old 07-03-2017, 02:36 PM   #13
1988montecarloss
Trader Rating: (24)
Still not starting, have restabbed cas as per frsport writeup and have gone over every wire and connection and everything seems fine and still nothing, has to be the computer, sending it to Martin on Friday
IG: @Haley72692
Old 07-06-2017, 09:32 AM   #14
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
ive had this issue with my RB same symptoms ended up being a mix between a bad MAF and a dying Fuel pump!!
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
