02-11-2017, 06:32 PM | #1 |
powerFC kuoki to zenki
hello all, i just got a apexi powerFC but its for a kouki harness and i happen to have a zenki, is it safe to repin to make it fit or buy a kouki to zenki adapter and hook it up ?
02-13-2017, 11:17 AM | #2 |
The Kouki and Zenki ECU connector is different. You'd have to have an adapter. The Zenki is really the odd one out in S-chassis ECUs. S13, S14 Kouki, and S15 all use the same physical connector with pins moved around.
If you had the skill, I'm sure you could pick up an ECU connector and move the pins over to that. |
02-13-2017, 01:04 PM | #3 |
im sure if you have a schematic i can have my buddy de/re pin the harness for you.
02-13-2017, 01:22 PM | #4 | |
Zenki 76-pin Kouki 64-pin Zenki to Kouki Patch harness Wiring Specialties sells the ECU connector: http://www.wiringspecialties.com/s14...ecu-connector/ They also sell an ECU conversion patch harness, but it's overpriced IMO. |
240sx 180sx, sr20 240 s14 sr20det |
