Old 08-26-2016, 08:25 PM   #1
240USA
240USA is an unknown quantity at this point
Cluster and fan lights going mad S14
I just bought a 240 Zenki s14 and when the lights are turned on the cluster/fan control lights go on and off randomly. Even when the cars not moving, just idling. Sometimes half the cluster lights will go dead, then the whole thing, then it might turn on again. Any advice? I searched but didn't find anyone with a similar problem.
240USA is offline   Reply With Quote
Old 12-10-2016, 12:20 PM   #2
240USA
Update, I have replaced the dimmer switch, checked fuses, have pulled out the cluster and everything in the center (radio/fan controls) and I couldn't find any pinched/bare/ungrounded wire. It still does it. Any ideas? I'm stumped....
Old 12-11-2016, 07:57 PM   #3
240USA
Is there a control module that controls the interior lights? If not what does? I really want to fix it so it's ready for spring.
Old 12-11-2016, 08:14 PM   #4
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Look at your fender wiring harness for ground out wires.
Old 12-11-2016, 10:50 PM   #5
240USA
Thank you for responding. I will look into that and update.
Old 12-11-2016, 11:47 PM   #6
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Worn wires touching
Old 12-12-2016, 08:26 PM   #7
ADIDASilvias
ADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the rough
When your dash lights are out are your tail lights still on? I had an intermittent dash light issue in my Stanza and my tail lights went off at the same time. I replaced the turn signal stalk on the column, the one that controls the lights, and it solved it. Pretty easy to replace.
ADIDASilvias is offline   Reply With Quote
Old 12-12-2016, 08:49 PM   #8
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
I've had 3 instances where the cluster would illuminate similar.
1 being with a fuse ( don't ask how )
1 being with one of the control boxes not properly grounded in the left kick panel
1 being with a ground issue on the tail lamp circuit.
Check your obvious grounds, use a multi meter for quickness
* understand though I say SIMILAR, your results may vary.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 12-13-2016, 08:07 PM   #9
240USA
I will try that, thanks!
Old 12-13-2016, 08:08 PM   #10
240USA
I will check them all, thank you!
Old 12-13-2016, 08:09 PM   #11
240USA
Originally Posted by rawgarage View Post
Worn wires touching
I've been searching like crazy, haven't found any yet but will keep looking, thanks!
Old 12-14-2016, 06:22 AM   #12
240USA
The tail lights do not flicker, just the cluster and fan control lights.
Old 12-14-2016, 06:24 AM   #13
240USA
The tail lights do not flicker, just the cluster and fan lights. All exterior lights are fine. I'm starting to believe it's not a ground because it's doing it stationary.
