Old 12-11-2015, 11:06 AM   #151
Albert_Trd
Albert_Trd's Avatar
Albert_Trd is an unknown quantity at this point
Originally Posted by Juan@Fontananissan View Post
Looks really good guys, whenever you guys need any OE, JDM or Aftermarket goodies let me know I'll hook you guys up!
We could always use some OE parts. Ill message you about door hinges
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi
Albert_Trd is offline   Reply With Quote
Old 12-11-2015, 11:07 AM   #152
Albert_Trd
Albert_Trd's Avatar
Originally Posted by hasemi View Post
Did you service your drive shaft? If so, did you change it from a non-serviceable to serviceable? I'm at that point where I need to do that.
I just went down to the local Driveshaft place and told them the length and what trans and diff. made it more us.
Old 12-14-2015, 10:34 PM   #153
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
What intercooler piping did you get as 'cores' if that makes sense. From what i've been reading mkiv piping and sr20 core should work great but who knows. and more info on that tasty cooling setup...mmmm.
Originally Posted by xoxide View Post
Gun it towards the nearest mailbox, rip the ebrake, countersteer.
vJilly is offline   Reply With Quote
Old 12-17-2015, 08:42 AM   #154
Albert_Trd
Albert_Trd's Avatar
We used universal and I cut, mocked up, and welded it all here in shop.
Old 01-09-2016, 10:30 PM   #155
Drift_Squad144
Drift_Squad144's Avatar
Drift_Squad144 is an unknown quantity at this point
Got the gtw3684r.
Start to mock up it to see what it would look.
Sent from my SCH-I545 using Tapatalk
Drift_Squad144 is offline   Reply With Quote
Old 01-09-2016, 11:20 PM   #156
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
S14 1jz Brother build
Originally Posted by Drift_Squad144 View Post
Got the gtw3684r.
Sweet deal! What exhaust housing did you go with? I will be interested to see the results as there are not a lot of GTW data out there, esp on the JZ platforms
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 01-12-2016, 01:41 PM   #157
Albert_Trd
Albert_Trd's Avatar
He went with a .70 open on the exhaust.
we got the manifold mocked up, I tack weled the Tial on, and cut and tacked a 90 degree elbow on for outlet. Also mocked up downpipe. Now just need to run and install the oil lines.
Old 01-19-2016, 03:35 PM   #158
Albert_Trd
Albert_Trd's Avatar
A little bit more work
