Old 10-30-2015, 06:57 AM   #1
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
S13 240SX partout electrical brakes hubs suspension arms lower tension rods
Accept Bitcoin, cash, and paypal
$25 pair Front brake rotors.
do you need shipping? It's 35lbs and 1 square foot box from SF. Calculate it yourself please. It also fits inside FedEx XL flat rate
$20 S13 hatch 240sx left and right tail lights and center. Good condition. One side is missing the bulb socket cover.
(+$30 for shipping)
$15 8 brand new and 1 used. (two are missing packaging but still brand new) $6 shipping.
Rear:
$20 hub. with extended studs. 4 lug.
$20 pair of rotors. one track day
$110 S13 Kazama Inner tie rods. Used for 2 track days. Boots included
$20 Used inner tie rods. Can't remember what millage these have, but do appear to be good condition, no play.
$80 2x Bolt on spacers. Comes with nuts
$120 for 4 spacers. Comes with nuts
15mm
12x1.25mm
5x114 hub centric for Nissan Infiniti but adapter can be removed to fit any car if you don't want it hub centered.
These have 50 miles on them.
http://www.amazon.com/Nissan-ICHIBA-...ds=ichiba+15mm
Tools for sale
http://zilvia.net/f/showthread.php?t=478050
$25 Stainless Steel brake lines with clear protector for rear, have two track days.
DOT certified. Made in Canada.
I think this is sold? If you bought it please let me know. $20 Wilwood hydraulic cylinder for use with inline brakes to lock rear wheels. Like new, was only test fitted.
SOLD$600 turbo GT2860RS
$20 compressor outlet adapter for 2inch pipe has plug to tap wastegate into.
$10 Pilot bushing or free with any other purchase
$10 Brand new 40in Battery cable. Good for starter wire. etc
$8 battery cut off switch Brand new
$8 battery cable firewall mount through.
$35 6 switches lighted with covers. Brand new.
5 are on/off and 1 is hold for on, it rocks back to off by itself. Great for starter.
20 amps
Made in USA
starter switch
$10 Battery cable 45 inch
$40 Battery cable 170 inch
$4ea battery cable covers or all 4 for $8
Hashiriya415 is offline   Reply With Quote
Old 10-30-2015, 07:00 AM   #2
Hashiriya415
Trader Rating: (22)
$20 (Pair, both left and right) Great condition tail lights for S14 Zenki. Comes with bulb socket holders.
$24 to ship
$10 Battery junction terminal. Near new condtion (Use this to connect cable through firewall)
Picture from 2014
Picture from 2014
Picture from 2014
SOLD$55 rear traction arms MR
SOLD$25 5 speed cross member
SOLD$50 sr20det ecu. E6
SOLD$200 wildwood hydro rear brake kit : bolt on.
SOLD$60 solid engine mounts. (+10 ship)
SOLD$60 NISMO transmission mount
SOLD$30 Clutch pedal
SOLD$220 Engine bay wiring, with switches and kill switch.
SOLD$140 Dashboard (slightly modified, cut at bottom of radio for easier removal and installation)
SOLD$120 SR20DET wiring harness.
SOLD$110 Starter.
SOLD$100 Gas tank
SOLD$60 Walboro fuel gas pump
SOLD$240 Koyo 3 row radiator & Flex lite fans with shroud.
SOLD$40 ignition coils
SOLD$460 SR20DET longblock. With intake mani, throttle body, alternator, PS pump, CAS, and TRUST downpipe
SOLD$80 Z32 MAF, pigtail about 6 inches.
SOLD$10 Transmission MPH speed sensor.
SOLD$240 5 speed tranny, shifts perfect in every gear.
SOLD$50 NISMO tranny mounts.
SOLD$30 NISMO tranny pivot for fork. (3 track days)
SOLD$100 Shell only nothing attached
SOLD$120 ~ Doors, hatch, ~ Hood ~ Quarter panel glass and windshield ~ Back bumper
SOLDBumper $100
SOLD$150 NISMO power front brace. Tension rod brackets.
SOLD$360 Front crossmember, knuckles, and F&R Sway bars.
SOLD$15 NISMO Cap and Greddy Shift knob
SOLD$900 NISMO 2 way LSD
SOLD$100 Fenders
SOLD$540 Enthalpy, 640 cc Deutschworks. NISMO regulator. Rail
SOLD$200 Rear sub-frame. solid bushing
SOLD$40 Passenger rear knuckle.
SOLD$60 ARP flywheel bolts.
SOLD$260 Flywheel and Brand new SS line
SOLD$80 89K Gauge cluster
SOLD$150 Origin rear bumper
SOLD$20 SR fan shroud
SOLD$180 FLCA
SOLD$40 axles, RLCA
SOLD$50 front hubs
SOLD$175 COR Front tension rods
SOLD$50 all 29 T-Clamps
SOLD $20 for all 6 led bulbs.
SOLD$90 Apexi AVCR AVC-R Electronic Boost Controller actuator valve type-r
SOLD$160 B&M shifter kit. Best shifter! for Works for SR and KA
SOLD$200 Re-manufactured rack&peanut
SOLD$20 turn signals and wiper switch.
SOLD$80 ~6-puck 450 ft lbs rated clutch kit by "SPEC". Kevlar friction material and high torque sprung hub.
SOLD$35 Interior harness
SOLD$58 .09BTC SS PS hose. 6/23/16
SOLD$600 Tein Type flex
SOLD$20 x2 Pair of coilover Tein spanner wrench
SOLD$60 brake calipers. Hawk pads.
SOLD$80 KTS rear upper control arms. 7330
SOLD$35 BN oil cooler
SOLD$24 Water & Oil lines for turbo.
SOLD$50 intercooler piping & couplers & clamps
SOLD$36 Custom made Headlights
SOLD$150 Rear BNIB KTS Toe arms.
SOLD$100 Sportline lower control arms
SOLD$55 Wastegate actuator bnib
SOLD$140 KTS Front T Rods
SOLD$60 sportline RLCA
SOLD$60 MR rear toe arms
Old 11-19-2015, 10:36 PM   #3
Hashiriya415
Trader Rating: (22)
I give away sometimes free stuff when you come to buy something... Might be a box full of hardware. Might be misc car parts... Used tires...
Old 11-20-2015, 02:35 AM   #4
Bashar_finalstage
Bashar_finalstage is an unknown quantity at this point
Got the break lines ?
Bashar_finalstage is offline   Reply With Quote
Old 11-20-2015, 03:14 AM   #5
Hashiriya415
Trader Rating: (22)
The ones that's posted
Old 11-20-2015, 09:14 PM   #6
Thathatch
Thathatch is an unknown quantity at this point
Still got the cor tension rod? Also shipped to Alaska 99503
Thathatch is offline   Reply With Quote
Old 11-20-2015, 09:18 PM   #7
Hashiriya415
Trader Rating: (22)
Yes 15$ for shipping
Old 11-20-2015, 09:20 PM   #8
Mr.slipngrip
Mr.slipngrip is an unknown quantity at this point
Ill take the steerinf wheel
Mr.slipngrip is offline   Reply With Quote
Old 11-22-2015, 08:49 AM   #9
slowody24
slowody24 is an unknown quantity at this point
Hey buddy steering shaft to rackinpion still available?
slowody24 is offline   Reply With Quote
Old 11-22-2015, 02:27 PM   #10
Hashiriya415
Trader Rating: (22)
Steering wheel, shaft, and rack&peanut are gone.
Old 11-22-2015, 04:07 PM   #11
Mr.slipngrip
Ok how about the light switch and wiper switch?
Old 11-22-2015, 04:09 PM   #12
Hashiriya415
Trader Rating: (22)
$30 shipped for both.
Old 11-22-2015, 06:59 PM   #13
FunnyVictor86
FunnyVictor86's Avatar
FunnyVictor86 is an unknown quantity at this point
Do you have pictures of the other door panel? How much shipped to 91042?
FunnyVictor86 is offline   Reply With Quote
Old 11-22-2015, 09:04 PM   #14
Hashiriya415
Trader Rating: (22)
I doubt shipping panels might be a good idea. If you want affordable shipping, it will get damaged most likely.
If you want me to properly package them so they don't get damaged in case somewhere it gets mishandled during shipping.
$80 would be the cost to package and ship both panels properly.. Plus panels cost.
Both look the same, I took pic of only one, but they are identical condition.
Old 11-22-2015, 09:44 PM   #15
Jnev7
Jnev7's Avatar
Jnev7 is an unknown quantity at this point
You still have the fan control relays with adjustable temp switch?
Jnev7 is offline   Reply With Quote
Old 11-22-2015, 09:55 PM   #16
Jnev7
Jnev7's Avatar
Also are the brake lines for s13 to z33?
Old 11-22-2015, 11:47 PM   #17
Hashiriya415
Trader Rating: (22)
fan controller and have couple of nissan relays I can include. $22 shipped
Old 11-23-2015, 09:16 AM   #18
Mr.slipngrip
Cool ill take both for 30 .
Old 11-23-2015, 11:07 AM   #19
slider2828
slider2828's Avatar
Hey Hashi, you still around!! I haven't seen you in forever... You still going to THill? Still in the City! Good seeing around!
Turn and Burn!
Old 11-24-2015, 10:39 PM   #20
Mr.slipngrip
Payment sent.
Old 11-25-2015, 01:57 AM   #21
Hashiriya415
Trader Rating: (22)
Will get there eventually.. Been a while. Cycling is mostly the sport I'm doing now.
Old 11-25-2015, 12:01 PM   #22
AllThingsGravy
AllThingsGravy's Avatar
AllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her self
15 shipped for the Wheel?
AllThingsGravy is offline   Reply With Quote
Old 11-25-2015, 12:12 PM   #23
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Can you PM a price for the LEDs and the HOT FIRE camber plates?
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 11-28-2015, 11:01 AM   #24
93rbs13
93rbs13 is an unknown quantity at this point
Engine harness sold??
93rbs13 is offline   Reply With Quote
Old 11-28-2015, 11:44 AM   #25
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
is it jsut me or are those tension rods broken in half? lol
Will you ship Tein Flex and wastegate to NoVA?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 11-29-2015, 07:04 AM   #26
Hashiriya415
Trader Rating: (22)
Engine harness is sold.
I have many different tension rods. Brand new KTS $180. COR have one track event $200. Broken ones and couple of cheap low end ones (cheap china)
Shipping will be $35 for coil-overs and extra parts.
Old 12-14-2015, 03:19 AM   #27
Hashiriya415
Trader Rating: (22)
bumppppppppp
Old 12-14-2015, 05:30 AM   #28
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
Got any s13 power window buttons? The ones you have listed are for s14. I'm in need of a driver's side button.
speedgod^s13 is offline   Reply With Quote
Old 12-14-2015, 06:35 AM   #29
Hashiriya415
Trader Rating: (22)
No S13. Only the one posted
Old 12-14-2015, 07:13 AM   #30
speedgod^s13
Okay.
Sent from my A0001 using Tapatalk
