Old 07-11-2015, 07:56 PM   #1
Halfamazing
Halfamazing's Avatar
Halfamazing is an unknown quantity at this point
Cool Sr20 parts/manley rods/meth kit/Sard FPR/Built motor
I still have sr20 stuff up for grabs. Prices OBO shipping and PP fees not included. Thanks.
$2250 OBO S14 sr20det built motor
Weisco pistons 86.5mm 9:1
Manley rods
acl bearings
arp main and Head studs
tomei MLS
Head ported and Polished
Supertech dual valve springs and retainers
This motor is getting blowby and needs rings. Still runs though.
$320 OBO Sr20det Manley Rods BNIB. Only opened to look at them.
$250 Sr five speed trans with isis short shifter. Shifts great. Has a intermittent grind going into 4th, happens once in a while.
$75 Intercooler core. No leaks or major bent fins. Held boost perfect. Bottom has a little bend from tow truck loading my car a long time ago.
SOLD $50 CAS worked fine.
$75 used SR starter. Worked fine when pulled.
$150 S14 sr20det cam gears.
$65 Sr20 Stock flywheel. 2k miles on resurface.
SOLD $65 SR20 AC compressor.
SOLD $70 Sr20 alternator. Worked when pulled fine.
$100 Apexi harness adapter for power fc dejetro. model 4E73G015
$250 Devils own water meth kit. Bought from a member a while ago with plans to run with my sards but never did. Really nice kit with progressive controller.
$20 purple water pump pulley.
$90 Yashio factory water pump pulley.
$50 Sr20 fan and clutch .
$ 70 Greddy boost control solenoid.
SOLD $100 Sard adjustable FPR .
SOLD $120 S14 sr20det Valve cover painted intense money green. Has scratches on back side from R & R motor without removal. you can't see them with motor installed though. Still looks nice.
Sr20 igniter chips $ 50 each. All work.
$190 Polished s14 sr20det intake manifold, upper and lower with polished TB.
$100 stock SR pistons and rods
SOLD $300 S14 sr20det block : Was hot tanked / decked/ and honed for reuse of stock pistons. Was used for literally 3 miles and removed and torn down. I recommend having it bored .20 over and using 86.5 mm pistons. This is for a bare block with caps and girdle.
SOLD $160 Sr20det crank used in stock rebuild. All journals in excellent condition.
Halfamazing is offline   Reply With Quote
Old 07-11-2015, 11:27 PM   #2
jerry v
jerry v's Avatar
jerry v is an unknown quantity at this point
What brand is the intercooler? and how much to ship 91910? What's the size of it?
jerry v is offline   Reply With Quote
Old 07-12-2015, 10:09 AM   #3
Halfamazing
It is intense power's intercooler. No name brand. Measures 3inch x 32inch inlet to outlet. Openings are 3inch.
Old 07-12-2015, 01:55 PM   #4
risetovengence
risetovengence's Avatar
risetovengence is an unknown quantity at this point
Are any of these parts available for pickup?
Sent from my SM-N900T using Tapatalk
Muh Kouki
risetovengence is offline   Reply With Quote
Old 07-12-2015, 01:58 PM   #5
Halfamazing
All can be picked up in Vegas no problem.
Old 07-13-2015, 05:33 PM   #6
Halfamazing
Bump it up! You buy now
Old 07-13-2015, 07:11 PM   #7
Z32TwinTurbo
Z32TwinTurbo can only hope to improve
Do you have a s14 sr maf?
Z32TwinTurbo is offline   Reply With Quote
Old 07-13-2015, 09:35 PM   #8
Halfamazing
No maf as i used a map sensor tune.
Old 07-14-2015, 03:00 PM   #9
95s14zenki
95s14zenki is an unknown quantity at this point
is the crank still stock? or was it polished by a machine shop for larger bearings?
95s14zenki is offline   Reply With Quote
Old 07-14-2015, 03:40 PM   #10
Halfamazing
Stock, and polish is different from grinding to resize for bearings.
Old 07-14-2015, 04:24 PM   #11
JAStirrett
JAStirrett's Avatar
JAStirrett is an unknown quantity at this point
Do you happen to have the A/C line that goes from the compressor to the first hookup going behind the engine?
JAStirrett is offline   Reply With Quote
Old 07-14-2015, 04:36 PM   #12
Halfamazing
I have the low pressure line, but I'm holding it for a friend.
Old 07-14-2015, 05:01 PM   #13
JAStirrett
JAStirrett's Avatar
I wasn't sure which one it was, I haven't A/C in so long! Thanks though...
Old 07-15-2015, 09:30 PM   #14
Halfamazing
CAS sold, Valve cover sold.
Old 07-15-2015, 11:44 PM   #15
will9408
will9408 is an unknown quantity at this point
Do you have drive shaft you for sale?
Enviado desde mi iPhone utilizando Tapatalk
will9408 is offline   Reply With Quote
Old 07-16-2015, 07:06 PM   #16
Halfamazing
I do have it , s14 non abs drive shaft but I don't know about shipping.
Old 07-18-2015, 07:59 PM   #17
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
How much to ship crank to 06512 ct?
スカイライン
vw203 is offline   Reply With Quote
Old 07-18-2015, 08:48 PM   #18
Halfamazing
Pmed you bro
Old 07-20-2015, 09:27 PM   #19
Halfamazing
Still have stuff for sale
Old 07-21-2015, 09:55 PM   #20
Halfamazing
Up papapapapap
Old 07-23-2015, 06:25 PM   #21
Halfamazing
Alternator and A/C compressor sold. Lets get this other stuff sold.
Old 07-30-2015, 05:53 PM   #22
Halfamazing
Block and Crank sold
Old 07-31-2015, 06:35 AM   #23
SidewayzAsFck
SidewayzAsFck can only hope to improve
Interested in meth kit
SidewayzAsFck is offline   Reply With Quote
Old 07-31-2015, 09:44 AM   #24
Halfamazing
Cool lets deal. Pm me any questions you might have. Thanks.
Old 08-01-2015, 05:32 PM   #25
Hustler5
Hustler5 is an unknown quantity at this point
Intercooler still Available?
Hustler5 is offline   Reply With Quote
Old 08-01-2015, 06:16 PM   #26
Halfamazing
Yes I still have it.
Old 08-02-2015, 09:09 PM   #27
Halfamazing
Sard FPR sold!
built, crank, rods, s14, sr20det
