Wanted to Buy Post your needs and wants here. |
![]() Join Date: Sep 2013
![]() Looking for a build KA for my S13.
Decided it might be cheaper if I can find a already built engine instead of buying the parts & paying someone to install them. If you have a built KA24DE you're looking to sell in Florida please send me a PM. Thanks |
#2 | |
GM2 (SW/AW)
If you've got a stock motor to trade id do $1200 for a built KA-t with everything you need. $1100 for your stock KA with motor harness and ecu.
15,000 on a rebuilt motor with a t3/t4 turbo last dyno'd at 312rwhp @ 7psi currently running 11psi on a new tail waste gate & spring.
KA-T for life! Current for sale advertisement ![]() |
![]() Join Date: Sep 2008
![]() Feedback Score: 17 reviews
FS fully built ka25de (not a mistake)
All new freeze plugs New oem oil pressure relief valve New oem lower cover/oil pump Arp main studs Clevite77 main and rod bearings Eagle h beam rods Wiseco pistons 9:1 Block Cnc decked Bored .060 over New front and rear main seals New timing set Cnc milled head Custom cometic hg to retain factory deck height 3angle valve job New oem valves New valve seals New valve guides Bc dual valve springs w/titanium retainers Full race port and polish with bowl blending Crower .280/.280 cams Jim wolf adjustable cam gears 11mm oversized arp head studs Steel timecerts in the exhaust bolt holes New water pump New thermostat Trendstone cast t3/4 manifold Copper exhaust gasket New felpro intake mani gasket -10an tapped oil pan Turbo and lines not included $2000 ![]() |
240sx, built, florida, ka24de, s13 |
