Old 10-01-2014, 09:30 AM   #1
jrmto
jrmto is an unknown quantity at this point
Need some info regarding a 5speed swap
Just got a whole set up for my 5 speed swap on ka dual cam, which included new fidanza flywheel and exedy stage 1 clutch. I want to know if everything will match up perfectly. If it doesn't what else would I have to buy to make it happen?
jrmto is offline   Reply With Quote
Old 10-01-2014, 10:45 AM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
I'm confused on what your asking..but the flywheel will work with that clutch setup.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 10-01-2014, 10:54 AM   #3
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Bolts. You will need lots of bolts. From nissan dealership
Ilya is offline   Reply With Quote
Old 10-01-2014, 10:57 AM   #4
jrmto
Alright, will a stock pilot bearing fit fidanza flywheel
Old 10-01-2014, 02:59 PM   #5
angel mkiv
angel mkiv's Avatar
The pilot bearing gets pressed into the crank not the flywheel so I don't see why not
