08-31-2014, 10:50 AM | #1 |
2005 G35 twin turbo parts list
Put this together quick for a friend. Thought I would share it. OBVIOUSLY none of it is set in stone. It is literally a first draft that took 15 minutes to write up. I know it has been done already and I do not care. Feel free to comment and discuss.
Would be badass if he finally actually decided to say eff it and pull the trigger on this.. Infiniti G35 VQ35DE Twin Turbo build: Turbo Manifolds - $600? gaskets (manifolds, flanges, and outlets) - $70 Turbos, 2x GT2560R (V-Band for exhaust simplification) - $2,000 PTP Turbo Blankets - $350 Tapped oil pan - $20 + weld Oil pan gasket - $20 RTV - $20 Tapped coolant and oil - $50 SS oil and coolant turbo lines - $200 CX Racing dual 2.5" in x one 3" out IC - $200 Air filters - $100 Induction piping - $100 A lot of couplers - $50 2.5" IC piping, turbo to IC - $100 3" IC piping, IC to IM - $75 BOV and recirc tubing (y to inducers) - $300 vacuum tubing - $25 MBC - $25 2.5" Turbo elbows to stock downpipes: 2.5" V-band elbows - $200 2.5" Downpipes - $150 Dual 2.5" Cats between DP and X - $600 2.5" - 3.0" X - $40 Gaskets - $50 Oil Cooler w/fan (remote and dual filters?): Upgrade to dual filters and fan = $300 Maybe even trans. cooler with fan - $100 bolts and washers - $50 Bosch 044 Fuel Pump - $250 Injectors - $600 Adjustable fuel pressure regulator w/ gauge - $200 spark plugs - $50 for 2 sets Ignition setup (stock? Convert?) Oil, filter(s) - $25 Gauges: Oil pressure - $70 Fuel pressure - $200 Water temp. - $50 Wideband AFR - $200 Boost/Vac - $60 Wiring and connectors for gauges - $100 JWT or AEM ECU and TUNES! Target HP would be 525whp and 450+ ft pounds Cost - ~8-10ish, probably more... |
08-31-2014, 12:07 PM | #2 | |
Future Moderator
525whp on a VQ35? If this is a stock engine, sounds like a good way to blow it.
08-31-2014, 02:49 PM | #3 | |
He does not want to touch the internals. So, if and when he is not making the power levels we are talking about. We'll tear into it... Note/For record: If I do open it up, ACL bearings, Carillo or Manley rods, and 9:1 CP pistons will find their way in there. I, personally, at that point, would like to see this thing lay down 700 wheel on race gas and earn its self a couple time slips... |
09-01-2014, 06:03 AM | #6 |
It's one thing to sit and type out a "parts list", but actually DOING this process is much more involved. If this is for budgeting purposes, take your current estimate and multiply 1.5 or 2x.
09-01-2014, 08:05 AM | #7 | |
But like I said... It's not my money...
"Simplicity is the key to brilliance." - Bruce Lee |
09-01-2014, 09:02 AM | #8 | ||
Right on. We shall see. If he even decides to do this... Quote:
I just thought to myself, if I can not sway him one way or another and he has the cash to blow, I will do just what he asks and probably a little better.. Would still be cool. Would still be beastly. |
09-01-2014, 04:16 PM | #9 |
Yeah man... I feel that if you can't appreciate the VQ35 as an N/A motor, you should probably look elsewhere for more power. I mean, a newer 3.5L engine that pops its guts at power levels that SR's & KA's are capable of? That's unacceptable, IMO.
09-04-2014, 03:39 PM | #12 |
Rods will bend first on a VQ35DE.
Use UpREV for tuning. PM me to buy injectors, I have new sets in stock that flow between 560cc and 660cc depending on your power goals for less than $600.00. I would also recommend a return fuel system. PM me if you are interested in learning more about that as well (I'm developing one now). Other than that, plan for extra expense. |
Tags |
g35, twin turbo, vq35de, vq35dett |
