Old 08-27-2014, 04:17 PM   #1
cjfraser21
cjfraser21 is an unknown quantity at this point
ac delete now car wont start
so i removed the condenser, the ac can, the little fan in front of the condenser (not rad fans) and two lines from the one from the fire wall and another from the pump. i also snipped a 4 wires that plug in to the ac can. once i removed all of this i tried to start the engine and and the starter wont turn at all. i checked grounds and everything that i can think of and it just wont start im not sure which fuse is for the starter but from what i checked i didnt see any that were blown also i forgot to unplug the battery like a jackass but the lights and everything else has power any help? also the wire colors are green, green with a red stripe, green with a black stripe, and green with a white stripe im also fairly new with the sr engines so if you could dumb everything down that would be awesome
cjfraser21 is offline   Reply With Quote
Old 08-27-2014, 04:19 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
You had to have messed with something that didn't go to the A/C system...
Did you unplug any of the harness connectors that are next to the battery? No main fuses are blown? Does everything else work? Radio turns on, lights, sounds etc..
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 08-27-2014, 04:30 PM   #3
cjfraser21
Yea I just can't figure out what it is and yea the lights work horn works im just out of ideas of things to check was wonder if any one else had this problem before and none of the fuses that I checked were blown and also idk what harness connectors to check because the battery was relocated to the back and the wiring in this is a mess and i suck with wiring
Old 08-27-2014, 08:27 PM   #4
rastaman
rastaman is an unknown quantity at this point
240s can't run without AC..put it back in it will start up.
rastaman is offline   Reply With Quote
Old 08-28-2014, 03:36 AM   #5
cjfraser21
So there's no way to do an ac delete? Cause it doesn't work so I figured there's no reason to have the weight and might as well remove it
Old 08-28-2014, 03:39 AM   #6
cjfraser21
Or could I take it to an auto electric place and have them override the ac
a/c, ac delete, starter, wont start
