Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 07-28-2014, 11:59 AM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
JZ to VQ/350z/G35 transmission adapters!!!!
Introducing the Maverick Motorsports JZ/VQ 6 speed Adapter Kit!
This kit allows you to easily bolt on a stronger, better shifting, and cheaper 350z/370z/g35/g37 6 speed transmission to ANY JZ engine.
Similar to our other kits, we provide a CNC cut, CAD designed adapter plate made from 6061-T6 aluminum. We also include a pilot bearing sleeve to adapt the Nissan pilot bearing in the JZ crank. Additionally we include all the hardware needed(engine bolts, transmission bolts, and flywheel bolts).
The other crucial part of the swap is the custom flywheel made specifically for this swap kit. It is an aluminum 6061-T6 billet machined flywheel with a replaceable friction surface. At 14lbs, it is HALF of the weight of an OEM flywheel.
Best of all, any single plate 350z clutch will bolt right up to it. You are free to choose any clutch manufacturer that makes a kit for a 350z. Holding capacities of 740tq+ available from clutch makers! We also have a 1400tq+ twin disc option as well.
As with our other kits you will still need:
-Bellhousing machining($80)
-Shifter bracket relocation($125)
-Custom Transmission mount(availability TBD).
-Clutch line
-Driveshaft
All adapter plates are Laser scanned, CAD designed, CNC machined and real world tested. All scanning and machining is done in an ISO9001:2008 certified machine shop who specializes in MilSpec/Aerospace/Medical machining.
If you previously used one of my SR/KA kits all you need is the adapter and flywheel. The bellhousing mod and shifter mod are identical. It saves you money from doing the work twice!
Please contact [email protected] for further details.
Thank you!
George
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 07-28-2014, 12:06 PM   #2
maverickmotorsports
Here is Geralds 630whp Soarer running our swap along with a SPEC twin.
-George Marstanovic
Old 07-28-2014, 12:08 PM   #3
maverickmotorsports
Josh's JZ swapped S13. He opted for the VQ trans with our kit. His setup is using our flywheel with a 350z clutch kit. The kit allows you to choose whatever 350z clutch you want to go with.
-George Marstanovic
Old 07-28-2014, 12:22 PM   #4
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
^^^ sup with the shifter on the S13? DO you sell the kit for that? Trans bracket?
BiG MiKE86 is offline   Reply With Quote
Old 07-28-2014, 12:46 PM   #5
laurel4
laurel4 is an unknown quantity at this point
Any plans for an adapter to run a VQ transmission on an RB? Would definitely open up some choices. Always amazed no one makes one already.
laurel4 is offline   Reply With Quote
Old 07-28-2014, 03:59 PM   #6
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
ditto on the shifter set up on the s13
*I have this adapter setup and I am pleased with it
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 07-29-2014, 06:48 AM   #7
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
With this plate can you still bolt/unbolt the starter without takin the tranny off? I know with the Collins adapter you have to remove the tranny, unless you weld bolts onto the adapter plate. And how much do you need to machine the bell housing?
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
Old 07-29-2014, 12:21 PM   #8
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
Do you sell the flywheel alone?
My iTrader rating!
babowc is offline   Reply With Quote
Old 07-29-2014, 01:18 PM   #9
maverickmotorsports
Yes you can. The transmission does not need to come off to take the starter out.
I do not. The stack height and everything else is specifically made to work with our adapter.
Testing both parts out right now. The jig for the shifter should be done soon and available. The trans bracket is a bit more difficult because there are so many variations of the JZ mount kit out there.
-George Marstanovic
Old 07-29-2014, 03:14 PM   #10
klummpy
klummpy is an unknown quantity at this point
This would catch my attention after i just completed mine using the collins adapter... Better hope my starter lasts for a while
klummpy is offline   Reply With Quote
Old 07-31-2014, 10:06 AM   #11
gripROYAL
gripROYAL's Avatar
gripROYAL is an unknown quantity at this point
Awesome products! I absolutely love this kit and the z33 trans on my sr! Thanks George!
gripROYAL is offline   Reply With Quote
Old 10-05-2014, 12:11 PM   #12
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
How much for the complete kit with twin disc?
And do you guys offer a driveshaft and trans mount?
For an s14 shipped to 29906
turbob16ef is offline   Reply With Quote
