Old 05-03-2014, 10:16 PM   #1
Gill 180sx
Gill 180sx is an unknown quantity at this point
My rb25 s13 build
So after lurking around for a while, finally decided to make my own build thread. After seeing a lot of half assed builds, I really wanted to build something that would blow all others out of the water. (Don't get me wrong, I don't mean all the builds, but the majority).
So after looking around for many months, I finally found what I was looking in New York. Made the 11 hour bus ride down and drove her back up to Canada.
This is how she looked when I picked her up.
Did a lot to the car over the past year and a lot to come. I'll add a list of current parts include some pictures for now.
Engine:
RB25DET S2
Tomei pon cams
Exedy exhaust cam gear
Tomei springs
Cosmetic Gasket kit
Apr head studs
isis intake manifold
ISIS M-Spec Intercooler
Apexi power fc
AEM afr
HKS boost gauge
Aeromotive Fuel Pressure Regulator
ISIS dual blast pipes
Mishimoto Thermostat
Interior:
Bride zeta 3 type xl driver
Circuit Sports Super Low Double Lock Seat Rail
Bride Ergo passenger
Bride seat rail
Tomei shift knob
NRG steering wheel
NRG short hub
NRG slim quick release
Roll bar
Race equip harness
Brand new carpet
Suspension/Brakes:
Rebuilt Z32 calipers
Slotted and dimpled rotors
5 lug conversion
Braided lines all around
BC racing type BR coilovers
Isis rear multi link
J30 vlsd
Energy Suspension Bushing Kit
Stance Subframe Riser Bushings
Body/Rims:
Origin aggressive type 2 body kit
Origin front 20mm fenders
Origin rear 50mm over fenders
Work meister S1 3p
18 x 9.5 -1
18 x 11.5 -9
I'll try to get some recent pictures and dig up some old pictures.
Parts to come:
GT35r
top mount manifold (possibly full race)
Raw brokerage fuel rail and 1000cc injectors
Chase bays bmc and interior lines
Audio system
Tires
few missing things
Gill 180sx is offline   Reply With Quote
Old 05-08-2014, 01:21 PM   #2
Gill 180sx
Had some free time and got a few things done on my subframe.
This is how my subframe looked before
Cleaned the differential, than primed and painted.
Installed the subframe solid bushings and put the differential back on.
Old 05-10-2014, 12:53 AM   #3
Gill 180sx
Small update, cleaned the under of the car with a wire brush and undercoated.
Also got the rear fenders ready for over fenders.
Some help from a friend.
I still need to weld the loose pieces to the body. Also deciding weather to make the cuts a bit higher, near the middle.
Also did a test of my fenders
Origin 50mm rear overs
Origin 20mm front fenders
Sorry for the mess in the pictures, a lot going on in the garage. Overall I'm pretty happy with the fitment, rear is going to need some small adjustments. Front is pretty spot on.
Going to try and get these installed today so I can put my subframe back together.
Also mounted my Bride zeta to the circuit sports rail and did a quick test fit.
I am really pleased with how it sits. For being 6"1, I was expecting to have some head room issues, but the seat sits super low.
Old 05-10-2014, 09:56 AM   #4
nickmat619
nickmat619 is an unknown quantity at this point
looks awesome so far man good luck with the build
nickmat619 is offline   Reply With Quote
Old 05-17-2014, 02:52 PM   #5
Gill 180sx
So had a quick question, I can't find any info online, were the subframe bushings put in the right way? There in pretty solid but don't want to take any risks.
Old 06-10-2014, 12:53 AM   #6
Gill 180sx
Sorry for no update, I've been really busy with work and school lately.
I ended up making spacers to put under the bushings for extra support.
All reassembled
First time seeing daylight in over 8 months
Going to the body shop to get body kit and overs molded. Also getting engine bay painted.
I forgot to take pictures of the body kit but its Authentic Origin Aggressive Body kit. Along with origin fenders
While the cars in the shop, I cleaned up the engine head and sent it off to the machine shop. I decided to keep a stock block this year and thinking about going rb30 block next year.
Also got this in the mail
It's a cxracing manifold and downpipe kit. Overall im pretty impressed with new design and welds arn't to bad. Fits perfect to.
Here's some updates from the body shop
And here's a cool picture I found from last summer
Old 06-10-2014, 11:40 PM   #7
Ka24Power
Ka24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud ofKa24Power has much to be proud of
You have the subframe risers in backwards right now, they need to have the extra aluminum coming out the bottom in order for it to tighten the subframe up against the car correctly. With them flipped you've just lowered your subframe as opposed to moving it closer to the body as originally intended.
Everything else looks great, glad to see another clean build coming out of Ontario
Ka24Power is offline   Reply With Quote
Old 06-20-2014, 11:31 PM   #8
kevinzhou
kevinzhou is an unknown quantity at this point
wow this car has been around
kevinzhou is offline   Reply With Quote
Old 06-21-2014, 12:04 AM   #9
tricky_ab
tricky_ab's Avatar
Hmm, was a picture of this car (with the kit test fitted) posted on Sons?
Instagram
Back for round two... 4 doors this time around...
Old 07-04-2014, 01:10 AM   #10
Gill 180sx
Yes, could have been me
Old 07-04-2014, 01:38 AM   #11
Gill 180sx
Been busy, sorry for no update
This is the day i went to pick up the car
On its way home
Went with a dark purple for the bay
Looks really weird with widebody and small rims lol
Did some test fits
Needs go to way lower
Winkle coated psp and intake
Relocated to fit bigger turbo
Got some Hankook evo 12 215/35/18 and 245/25/18s
Messing around with the camber lol
Got it fitted to what I want
Needs bit lower on this side
As much we tried could not get the rear tires mounted, going to try 255/35/18
Also got my engine head back from the machine shop, did some test fits
This also just came, was backordered for a month
Its a chasebays Wilwood bmc that eliminates the brake booster and also a interior line kit. Must say quite impressed with the quality of these parts.
Got the head installed
Tomei cams installed
This just came in, Precision 6262 journal bearing .82 ar
Did a quick test fit
Went to pick up a Greddy oil filter and saw this super clean r32 gtr there
I'll leave it at this its pretty late, got the intake and bmc installed. Installed stock rail for now, hopefully ordering raw brokerage rail and injector dynamics 1000cc injectors this weekend.
Old 07-04-2014, 12:13 PM   #12
Ka24Power
Wow, making moves man. Looking great.
When are you getting it painted? Pick a colour yet?
Old 07-04-2014, 12:48 PM   #13
Oakville
Oakville's Avatar
Oakville is an unknown quantity at this point
What!? 9000?!
BNR32 connoisseur // 1990 GT-R
Oakville is offline   Reply With Quote
Old 07-04-2014, 12:52 PM   #14
Gill 180sx
Thanks! I want to get it painted next month, but I still need a few thousand more to get this beast running.
This is the colour scheme I want to go with, or possibly rootbeer
I would also consider the stock colour, as theres not many around, but It wouldn't sit nice with the bay IMO
And here's another shot of how my car would look in black
Old 07-04-2014, 01:23 PM   #15
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
nice, even tho coupes are way better.... I will be picking up that ex mani it looks like..
supersayianjim is offline   Reply With Quote
Old 07-04-2014, 06:17 PM   #16
tricky_ab
tricky_ab's Avatar
Yeah, I recognized the pictures...
...This is quite the build, and I'm watching this thread for sure
Instagram
Old 07-04-2014, 06:41 PM   #17
adams 02rs
adams 02rs's Avatar
Trader Rating: (25)
adams 02rs is an unknown quantity at this point
Feedback Score: 25 reviews
beautiful build bro. keep up the clean work, thumbs up for the hatch.
adams 02rs is offline   Reply With Quote
Old 07-04-2014, 11:33 PM   #18
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
Nice,very well done; cxracing manifolds are good except for the collector. My ka's manifold collector was poorly done but that was a merge that was welded and why they switched to cast, I assume it flows better and is also stronger. But anyways keep up the good work.
bova17 is offline   Reply With Quote
Old 07-13-2014, 12:24 AM   #19
Gill 180sx
Thanks everyone ^ , and I have to say cxracing really stepped up their game with the new designed manifolds. The welds could look a little better but for $500 I can't complain.
I ended up ordering the raw brokerage fuel rail and id1000 injectors on the July 4th Weekend, but apparently there not making the rails for a few months. Went with the Tomei rail for rb26. Should be here any day now, hopefully. Also got a fmic from raw brokerage.
Not to happy with the colour tho, purple would have been cool.
Ordered some new shock cartridges from bc racing, since my old ones were damaged from hitting the ruca.
Installed all the interior brake lines, just need to flare rear brake line.
Need to cut the downpipe to make it shorter and weld a v band on the old straight pipe. Also need to weld a new v band that's specific for the precision turbo.
Also this just came in, my new fuel lines.
Did some mock ups
Took this out to do the harness re locate and brake lines. Also re dyed black.
Hate doing wiring, keeping it simple, labeling and shortening whole harness by 3 feet, Extending few wires ( head lights, rad, lower harness etc)
All this came in yesterday, turbo lines.
Had to order more fittings, 90 degree fitting for the turbo drain to block and turbo feed and 3 90 degree fittings for the fuel setup for better fitment.
Ordered a wiring specialties harness today to, old one was very hacked up.
Hoping to have this on the road by end up July, although I have no idea how i'm going to pass Ontarios bullshit drive clean program. Registered as a hot rod and failed miserably last year cause of the straight pipes. Going to be worse this year with open waste gate, downpipe and cams..Might have to try that stuff you put in the tank to help??
Old 07-13-2014, 02:30 PM   #20
PoorMans180SX
PoorMans180SX's Avatar
Your subframe risers are in upside down.
Old 07-15-2014, 10:09 AM   #21
Ka24Power
You might need to try a cat, lol.
Good luck passing emissions without one
Old 07-17-2014, 01:06 AM   #22
Gill 180sx
Lol no way, going to try ethanol in the tank first, maybe as a last resort
180sx, build, canada, s13
