Old 04-13-2014, 09:18 PM   #1
akaina240
akaina240 is an unknown quantity at this point
Help installing speakers
So got everything off for a 6.5 Hybrid Audio speakers to replace front OEM.
I am stuck here though...
and seems like I might need an adapter plate?
Or do i just go to a stereo shop and fork out the dough?
Thought this would be a sinch
akaina240 is offline   Reply With Quote
Old 04-13-2014, 09:48 PM   #2
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
Your missing the factory speaker plastic pod.
http://i485.photobucket.com/albums/r...ry/pics209.jpg
eek is offline   Reply With Quote
Old 04-13-2014, 10:13 PM   #3
akaina240
i already took that off. my new speakers wont fit in there flush with the holes.
Old 04-13-2014, 10:14 PM   #4
jscherf92
jscherf92 is an unknown quantity at this point
just make an adapter plate and be done. a dremel and plexiglas or some people even cheap out and use plywood.
jscherf92 is offline   Reply With Quote
Old 04-13-2014, 10:21 PM   #5
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
They have adapter plates to fit 6.5 in s13s on eBay. Just type in 240sx speaker adapter or someshit
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 04-13-2014, 10:33 PM   #6
akaina240
im not too worried about the adapter plate. i can prob as mentioned above go to a stereo shop/ebay and mount it.
my question is the wiring....
in the pic posted, you can see the white socket and then a brown connector to the left of it.
Thing is my new speakers dont have the same white socket for an easy plugin...
Old 04-13-2014, 11:29 PM   #7
eek
Trader Rating: (29)
Wow really? You didn't mention anything about wiring in your OP. So how are we supposed to know what you need help with? We are not mind readers.
Anyhow cut the connector off and solder or use crimp connectors to wire up your new speakers. Done.
You could of simply cut you some slack off the connector, wire it back up the factory speaker and used a 9 or 12v battery to pop the speaker to see if the polarity is correct. When the speaker pops forward is the correct polarity. From there you can figure out which color wire is pos and neg.
Here is a video that will demonstrate how to check for polarity.
http://www.youtube.com/watch?v=TFlwINTNFqg
OR
You can be lazy and spend a lil money and just buy the plug and play speaker connector.
http://www.amazon.com/Metra-72-7400-.../dp/B0002BEQX4
I'm going to assume you want me to give you a wiring diagram for the speaker wires too?
Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Blue Right Front (+) White Right Front (-) Black
Compliments of: http://www.the12volt.com/installbay/...tail/1598.html
BTW
All this was found on Google in like less than 30 seconds.
Old 04-13-2014, 11:34 PM   #8
akaina240
Wow really? You didn't mention anything about wiring in your OP. Anyhow cut the connector off and solder or use crimp connectors to wire up your new speakers. Done.
I'm assuming you want us to give you a wiring diagram for the speaker wires too?
thanks sir! my bad mate.
Too bad im a complete noob to solder/crimp connecting...so I guess I gotta go to a stereo shop
Old 04-13-2014, 11:49 PM   #9
eek
Trader Rating: (29)
Its a crimp how hard can it be? Buy some connectors use a wire cutter that has a crimp nub and squeeze it together.
Strip the wire of the plastic insulation, place bare metal part of wire into connector, use tool and depress on the crimp move on to the next wire.
How hard is that?
I use both of these:
http://www.amazon.com/Klein-Tools-In...=klein+crimper
or
http://www.amazon.com/Channellock-90...=klein+crimper
I have both, they both work fine. Comes in handy if you ever do any type of wiring esp after market car radios.
If you don't want to buy tools to crimp just solder its easy as well just a lil more time consuming but it is worth it. It will guarantee your connection for both wires are good.
Video on how to solder: http://www.youtube.com/watch?v=HdbFduodOuo
You don't need a fancy soldering iron either, a basic one will work fine. Solder is cheap, you can buy it at radio shack, fry's electronics, any electronics store will have it.
All the tools mentioned should be basics in any tool box esp if you are getting into car audio or heck even working on cars themselves. If you do not have any of the above items I suggest you invest in them unless you have lots of money to continue to pay people and shops to fix everything on your car.
Old 04-15-2014, 05:54 AM   #10
prettztxyers
prettztxyers is an unknown quantity at this point
yes,They have adapter plates to fit 6.5 in s13s on eBay. Just type in 240sx speaker adapter or someshit
prettztxyers is offline   Reply With Quote
Old 04-15-2014, 06:35 AM   #11
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
Hey my old speakers!
When I had them installed on my s14 I snapped the small plastic corner pieces off so the speakers would sit flat against the plastic housing. I then made 1/4" spacers out of MDF to space them out a little. You probably don't need to do this though since those speakers are not that deep. There are existing holes in the plastic housing for screws to hold the speakers in place.
These speakers do use spade style terminals so just crimp some of those on and you'll be set.
az_240 is offline   Reply With Quote
Old 04-15-2014, 06:37 AM   #12
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
you can solder spade connecters to the speaker wires and insert them into your OEM connector, thats what I did.
Two wires....man....two wires.
Cant wait till a post comes out on how to connect an oxygen sensor...
Ilya is offline   Reply With Quote
Old 04-15-2014, 06:41 AM   #13
FLG
FLG's Avatar
FLG is an unknown quantity at this point
Don't waste money at a shop.
Crimping a wire is easy (takes like 2 seconds)
https://www.youtube.com/watch?v=zdZuBw_wLX4#t=82
FLG is offline   Reply With Quote
