#123 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Coolant pipe put back together
![]() Mounted on engine ![]() ![]() Drive shaft arrived ![]() Installed... but Im curious as to if this gap is normal?! ![]() Sway Bar Fitment ![]() Re-Ran the body harness and heres how she sits ![]() ![]() ![]()
#126 | |
I was told there should be 2.5" from seal to yoke by the mfg so ill measure it and see
#129 | |
#131 |
Thanks
![]() Anyone know what the drive shaft bolt sizes are?
#133 | |
#134 |
Picked up a fuel regulator bracket from Freed Engineering
![]() ![]() 2JZGTE Fuel Pressure Regulator Mount | Freed Engineering Will install this weekend along with some other junk
#136 | |
#139 |
Got a new drive shaft in with beefier joints and the correct length
![]() ![]() Installed ![]() Baller hardware holding shaft in place ![]() Installed Freed Engineering FPR mount - awesome part ![]() Started tucking the fender harness on both sides as well ![]() ![]() Tucked the harness on the passenger side as well ![]() ![]() Started putting the front end back on ![]() ![]() Expecting Suspicious Garage Brake lines in from ACE UP MOTORSPORTS tomorrow ill install and update some more ![]()
#140 |
Looks great man!
I got a buddy who can machine that throttle body down to about half the size to delete the throttle/traction control stuff if youre interested. Itd keep things clean,.. like youre doing already
cONtRol FReAkS |
#142 |
^^ im interested also!
Build is looking good mike! |
#144 | |
Thanks
Yes that's the get nuts lab kit
#145 |
Started getting front end back on her
![]() Picked up a set of these so I can see at night (looking to do the Hella H7 projector retrofit) ![]() Sent the throttle body out to Nocturnal Motorworks in Missouri to a fellow Zilvian for some weight reduction ![]() Got wiringspecialties harness about 90% installed now ![]() Just need to make fuel lines this weekend to finish bolting up the intake manifold.. Got some -6AN Nylon braided line and fittings ![]() Ordered this radiator hard pipe from CX Racing.. Hopefully get the cooling system buttoned up this week ![]()
#146 |
awesome stuff man!
In rare cases do projectors look better than bricks,. I expect nothing but awesome tho!
cONtRol FReAkS |
#147 | |
![]() Clearance from head to firewall ![]() Clearance around starter ![]() ![]() More coming soon ![]()
#148 |
Had some time today to do a few things
Installed radiator with cheapo ISIS fans on the outside. I flipped the blades on the fans and gulped the polarity on em to run them as pushers. Bearings on em sound like shit - we'll see how long they last. ![]() ![]() Made all of the engine bay fuel lines - just need to run to 2 lines to the tank now ![]() Ran both lines right to the bottom of the firewall into the "Y" fitting ![]() ![]() Random pics of the lines and routing ![]() ![]() ![]()
#149 |
Picked up some much needed driveshaft bolts from NISSAN - Nothing like shiny new OEM hardware
![]() Then the throttle body came in from Nocturnal MotorWorks came back all machined and ready to be mated back to the intake manifold ![]() ![]() ![]() Going to be ordering an Aeromotive or equivalent inline fuel filter tomorrow. Thinking of going with a 10 micron filter element unless anyone has any reason I shouldn't
#150 |
Just got an OEM lower radiator hose from TOYOTA for $15
![]() ![]() I'll be fitting this up along with the CXRacing upper radiator pipe tomorrow and ill post my findings ![]()
