Old 06-22-2013, 12:36 PM   #1
FriknAndre
FriknAndre's Avatar
FriknAndre is an unknown quantity at this point
Question Need help replacing the clutch.
Its my first time replacing the clutch and I dont know where to start. If you can help me I'd really appreciate it, thank you.
FriknAndre is offline   Reply With Quote
Old 06-22-2013, 12:45 PM   #2
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
first time dont do it alone,
Properly secure the car for you will be underneath it.
1. detach slave cyl set it aside (2) bolts
2. remove drive shaft
3. remove shifter
4. remove transmission bolts
5. use a jack or somthing to support the trans then remove the trans cross member
6. wiggle out trans
7. remove pressure plate bolts and remove the pressure plate clutch disc should more than likely fall out with the pressure plate.
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 06-22-2013, 01:07 PM   #3
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Also I recommend disconnecting your header where it meets the fake cat. It really does help you have more room to wiggle the transmission in and out. You can use the header as leverage to pull down your engine so you have clearance.
SilviaSR20DET is offline   Reply With Quote
Old 06-22-2013, 01:38 PM   #4
shift_down
shift_down is an unknown quantity at this point
There is a great writeup with pictures of how to do it. That's the way I was able to do mine for the first time. I will edit this post with the link once I find it.
Edit: awesome write up
http://forums.nicoclub.com/240sx-clu...p-t168578.html
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
shift_down is offline   Reply With Quote
Old 06-22-2013, 05:17 PM   #5
FriknAndre
FriknAndre's Avatar
Thanks alot guys I really appreciate this info.
clutch, clutch assembly, clutch issue, help!, tranny
