#2401 |
i wouldn't go bigger than 275 if going for stretch look! im not into the crazy over stretched look and i had 275 on my 11.5's and even for me it wasn't enough stretch i will go down to 265
fd3s fc3s mr2 s13 s13 s13 s14 s13vert aristo2jzgte bmw-e46 |
#2402 | ||
![]() Join Date: Oct 2003
I'm really looking for pictures of tire width.. Quote:
2011 BMW F11 5-series and 2003 Nissan 350Z |
#2403 |
Man w/ CTSV & a Car Seat
Do me a favor, put the wheels on, put a jack under the wheel to load it, take a picture and post it. I'm curious to see how much poke is on it first.
These were 265/35-18s on 18x11s. ![]() |
#2404 |
this is the only one i have left cant see much of the tire, i took the tires off right away after seeing that its not enough stretch, but really 265/35 would be best for that size
#2407 | ||
![]() Quote:
Thanks for the picture. I belive 275/35-17 will look nice.
#2408 |
Question! Figured I'd ask here
Anyone have experience redrilling their wheels? I wanna run Enkei nt03+M's in 18x10 for the rear of my s14, but they only make them in 5x120. I don't want to run a giant adapter so I'm looking into redrilling them? Is this a good idea or safe? Anyone have input? I got a lot of mixed reactions when I searched.. Thanks! |
#2409 | |
whether it would be okay is anyones guess, without all the testing and analysis techniques that enkei go through to make sure, im not entirely sure its worth risking a relatively pricey set of wheels and your health etc ![]() worse you can do with decent quality adapters is where wheel bearing out faster :S although i have seen people redrill a set of volk te37 (shudder) from 5 x 100 to 5 x 114.3 and they turned out okay, it was only 6 months before it got totalled though so hardly a long term test. ![]() |
#2410 | |
![]() Join Date: Mar 2012
#2411 | |
I was hoping not to run the 10.5's, but I guess it's either that or a square setup. Thanks |
#2412 |
I've got some 18x11 +1 going on the rear of my s14 soon. I was wondering... with a 245/35 Federal tire and -4.5 degrees how aggressive will my pull have to be? I just wanna get an idea of what I will be dealing with? Also I do not have the wheel currently, otherwise I would just put the wheel on and figure it that way lol.
#2413 | |
#2414 |
Hm... yeah it'll poke a bit. How much camber were you running at the time, do you rremember? I will evebtually get overs, but for now if I can do a pull as a temporary fix I wouldn't mind. It does seem really tough though. Also, I am about 5mm from tucking rim, so that doesn't help me either haha. Maybe the stretched sidewall will help fitment as well...
#2415 |
![]() Join Date: Jun 2012
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
240sx Hatch!
I wanna run 19x10.5 -20's in the rear of my hatch, what size overfenders would be able to accomodate these, and get it to tuck? a 50 should be good, right?
#2417 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
Just go with the typical size and roll with it. No matter what, you're not going to be "different". 17x9.5 +15 225/40 all around. Mod your fenders to how you want your alignment to be. |
#2418 | |
I'm thinking 235/40 or 245/40 all around? |
#2419 |
Trader Rating: (38)
Because MB Battles in 9" don't come in offsets that fit well on the S-Chassis, PERIOD. The only way to get the fronts to fit is with the use of spacers.
If you really want 9's, don't go for the stagger, run wide enough to clear your coilovers, run your desired tire size then mod your fenders accordingly. You're really oxymoronic in a sense that you're in a wheel fitment thread yet you're not setting your car up for it. And fwiw, wider tires will not save you from potholes either. |
#2420 | ||
#2421 |
Hey guy, don't really post on here just read a lot I hope I posted in the right place. Just want a little fitment help because I am stuck...
Car -s13 Fenders ( have not bought them yet) Front-50 Rear -50 Or Front -30 Rear -50 Looking to run 19x11 in the front et 8 Looking to run 19x12.5 in the rear et-12 currently running 17x9.75 Stock fenders rolled in front and pulled in the rear 22mm spacer in front 32mm in the back The current size is just an idea so you understand I have no problem doing the work to make them fit. But I would like to stay away from tubing the front end and keep the camber down if possible ( lol ) Thanks! Looking forward to your guys responses! |
#2422 | |||
#2423 |
From all the searching I have been doing there is a lot of conflicting information. From what I have read on these forums is that with a 18x9 wheel you want to be around the +15 to +20 offset range to clear the suspension, but I have a friend running 18x9 +35 all around with no rubbing issues.
I am a fan of having my wheels flush with the stock fenders without crazy camber, and it seems like the +35 does just that. I have driven said car (235/40 front and 255/35 rear) and there is no rubbing issues, yet according to everything I have read here it should be rubbing the suspension. Suspension wise said car isn't dropped all that much, just springs/shocks/struts not coilovers. * I should note that the car is a S14 Kouki.
2006 Holden Monaro - 700+whp ; 2014 Holden Commodore SSV - 400whp |
#2424 | |
#2425 |
Okay, well I did some more searching and found an offset setup that I like and seems like it'll clear most suspension setups. It is the sizes/offset on justs13's S14. He is running 18x8 +20 front and 18x9 +20 rear, though I'd probably go for a little less positive offset in the rear to make it a bit more flush. Although I would also like a wider wheel up front to get a fatter tire, but that can always be calculated by using the 8" ET20 as a base.
Here are links to some pictures versus embedding them and taking up page space. http://zilvia.net/f/attachments/whee...0-imag0252.jpg http://zilvia.net/f/attachments/cars...e-imag0649.jpg http://zilvia.net/f/attachments/cars...mag0652-1-.jpg http://zilvia.net/f/attachments/cars...e-imag0647.jpg http://zilvia.net/f/attachments/cars...e-imag0646.jpg http://zilvia.net/f/attachments/cars...e-imag0645.jpg This is the type of look I prefer since it is flush with the fenders and has no extreme negative camber going on.
#2426 |
There is on point on running 8js on these cars. Atleast run 9j all around. You can dial in 9/10 staggered setup with no camber if you know what you're doing. But a lil bit of camber up front is okay, no more than 2* isnt gonna kill your alignment.
#2427 |
I completely agree, I want to go at least 9" wide up front. I may go 10" wide in the rear, but the car will be bone stock power wise for quite a while and it may be too much.
#2428 |
What is everyone running with extended lower control arms? I am at currently around -7 front wheel/tire 9.5 17" 225/45, origin 20mm fronts. (s13 w/ s14 lca btw). What should i run to make my tire not completely destroy my fender, I cant even lower the car all the way.
Want to still keep same ride height. |
#2429 |
Another set up question.
18x10 et20 18x12 et20 What size over fenders would I need these would be going on an s13 Tires: 245/40/18, 275/35/18 Also how much camber if any needed? Input please! Thanks! ( any pics would be great!) Last edited by Khoda; 06-01-2013 at 02:05 AM.. Reason: Camber! |
#2430 | |
Wider fenders up front will help you with some clearance but wont fix it all. 20mm fenders are the norm but 30mm is be better if you can find it. Rears, you'd need atleast 50mm with some bowing out. |
