#31 | |
as far as the knuckle from scratch. it will be a full sheet metal fabricated part (not to be confused with plate style like the drift works ones) i find that in the drifting world steering angle is much like suspension travel in the offroad world. its mostly a big pissing contest. they mess up all the geometry trying to get more travel. give me half the travel and let me set the car geometry up and you get a faster car through the desert. give me 45 degrees and set it up right through out the turning radius you have a much better drift car then the guy with 1000 degrees of angle. that being said i plan on trying to match some to the competions angle in the High 50 degrees and improve on driveablity on the inbetween stuff. if i cant i will remove a bit of angle to get better drivability. I hope you can see my logic here. thats basicly how im going to go about it. the ideas are still just on paper i havent started anything in CAD yet. Last edited by Bink Industries; 01-28-2013 at 01:40 PM.. Reason: adding someting |
#32 |
i just finished reading the rule book again just to be sure my part is full legal
the other TDP/ WISEFAB style ones are not because the relocate the the strut. 8.3.2.2. Original suspension design type must remain: Double wishbone, MacPherson strut etc. Suspension relocation brackets that move suspension points or pivots regardless if they are bolt in to the chassis will not be allowed. |
#34 | |
AFC #1
![]() Join Date: Oct 2003
Any more photos of it installed? Can't see much from that top down shot.
#35 | ||
#36 | |
that billet aluminum part is more then likley heavier then my part ![]() i dont want to say for sure (anyone have a weight on that one?) and mine is chomolly so im running really thin material. again im lighter than stock!!!! thats pretty damn light. AND i have plans for even lighter ![]() I have no feedback on theres being stronger than mine but i would be willing to put mine up to stress test in CAD if they will and i dont think I would be suprised by the results ![]() you could slide right into the side of a wall and I would very confident in saying that would be the last thing I would think would break. there is a reason you dont see trophy trucks with billet lowers.... they cant make them as strong as sheet metal fabricated parts. i thought about goin billet but new i could make a lighter stronger part with sheet metal. cnc is VERY accurate but mine is welded in a jig so theres no movement when welded. and I dont think i would be able to tell the differance. CNC deffinatly looks bad ass. I hope this helps. I dont really want to give away exactlly how I designed the part as there are some secrets to its light weightness and strength. |
#37 | |
![]() that is really light though. gunna be hard to beat thats for sure. looks like they got the cup angle right ![]() |
#38 | |
and here is two more pictures for you guys. |
#40 | |
![]() Join Date: May 2009
#43 |
the only thing i could see wrong would be the possibility of it being too strong. if i were to crash my car i would rather bend a control arm than damage a subframe or tweak the chassis, i think that is why most companies stick with the tubular design
#44 | |
and that is exactly why I used aluminum rod ends ![]() when you crash the arm will be fine.......your car will be fine.... you just replace some rod ends that you broke and your back in business (and what ever else broke of coarse) dont confuss these rod ends as weak they are bigger than any other arm but the are the intentional weak point so you dont trash your car. these are the little things that you have to pay attention to that alot of others seem to skip. |
#45 |
This is a really interesting design you have. I also feel as if you are onto something here. By chance would you happen to have any videos with the control arm on?
#47 | |
This will be being tested on a seasoned drivers Formula drift car along with my front and rear sway bar (hopefully sooner then later) and possibly being debuted in april on the formula drift circuit. we have found alot of short comings with competitions products and mine have been found superior to them. |
#51 | |
i have purchased everything just not launched it. taking product pics as of current and finishing up the logo i will post as soon as i have something up online untill then this is the spot to look. |
#54 | |
![]() Quote:
What would assist in positive commentary and interest, are the parts installed on a car, in action, tons of pics and video and demonstrating the benefits of the upgrade. I wish you luck with this endeavor, keep it up! ![]() |
#55 |
![]() Join Date: Jan 2009
Lets see, 900$ accomplishes nothing, I'll pass. That thing looks just beefy enough that I'll have fun bending my front sub frame rather than an easily replaced arm. My modified stock arms will clear just about as much angle as one would ever need.
#56 | |
You were having so much fun in ms paint you probably forgot to notice that the adjustable caster arms on your 240 pose the same problem. Hahahaha see I'm on no ones side. Congrats on the new product, it looks sick, just a little expensive. May want to outsource those ball joints to china lol |
#57 |
#58 |
#60 | |
I will also be offering a discount on a replacment arm if you find a way to break one as long as you send in the broken one for inspection so i can hope to improve on the design. If your happy with the amount of angle from your modded stock FLCA then great ![]() ![]() |
Tags |
flca, major angle, s13 240sx, steering angle |
