Old 06-10-2012, 12:03 PM   #901
mattigat17
mattigat17 is an unknown quantity at this point
I am in need of major help, my coil pack on cylinder 1 keeps melting! I've replaced the plug, coil pack and bought a new wiring specialties coil pack harness and it still does it. Could it be the ignitor? Any ideas are appriciated. Thanks!
mattigat17 is offline   Reply With Quote
Old 06-11-2012, 04:50 PM   #902
datsunnazi
datsunnazi's Avatar
datsunnazi is an unknown quantity at this point
Send a message via MSN to datsunnazi
sounds like you have the 12v and the ground wires switched.
datsunnazi is offline   Reply With Quote
Old 06-22-2012, 02:50 PM   #903
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
what kind of hose can i use for the oil drain from the turbo to block?
d0pe240 is offline   Reply With Quote
Old 06-23-2012, 04:15 AM   #904
GSXRJJordan
GSXRJJordan's Avatar
Anything that'll take the heat and not get kinked. Not as bad with RB's as SR's or KA-T's, but ideally you'd use a piece of bent hose with heat wrap around it.
Old 06-23-2012, 12:44 PM   #905
d0pe240
would heater hose be alright to use? i know that the turbo gets hot and want to make sure haha.
Old 06-26-2012, 12:41 AM   #906
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
Originally Posted by ka24deturbo View Post
Do you guys know where I can get help with wiring? Thanks!
drift freaq: I'm gonna need my A/C & P/S so help a brotha out! Let me know what you can do for me as far as parts! Thanks!
Wiring Specialties, Chase Bays possibly.
zneubauer is offline   Reply With Quote
Old 07-15-2012, 01:27 PM   #907
Superaison
Superaison is an unknown quantity at this point
Just noticed this thread... damn. Just did a RB25DET Series 1 swap in my 1995 240SX SE.
My 2 cents on the swap(I did do lots.. lots and lots of research.. but I learned the most from actually doing the swap)
I got my motor from Zerolift with their swap package (engine, mounts, driveshaft).
But my biggest problem was I REALLY didn't want to use conversion angle crap brackets to hold my engine i just spent thousands on.
So I asked myself, why can't I use their trans mount with the R33 Crossmember that I picked up? Only way to find out is to try. So I did and Well, to sum it up.. NO you can't just BOLT IN the r33 xmember and expect everything to be sweet(Yes it will fit though after hammering firewall, but it needs adjusted) You MUST bring the engine back an inch (and down an inch). The shifter was about an inch forward and the zerolift bracket didn't line up on the trans.
What I did
Redrilled the engine mount holes on the crossmember one inch back towards the firewall.
The shifter was right in the middle, and the zerolift tranny mount bolted up perfectly, and as did the driveshaft. Steering shaft clearence sucks, but its not hitting, I have yet to drop my engine an inch and see how its clearing.
The wiring aspect is EASY, seriously( The hardest part is making sure wires aren't too short or too long, and fixing any damaged plugs or pins[all my pins were pulled from my o2 and my oil pres plug had the yellow pin pulled lmfao]). I may post my own complete writeup if I have time. I reached some tricky parts due to lack of information but figured it out with the help of the fsm.
Superaison is offline   Reply With Quote
Old 07-15-2012, 01:58 PM   #908
GSXRJJordan
^^^ I've used the Zerolift brackets (back when they were Ruckus) a couple times, they're just fine, and I loved the engine location vs the R33 crossmember.
Old 07-15-2012, 02:16 PM   #909
Superaison
I didn't run them honestly because I didn't have another stock ka/sr engine mount. I only had drivers side haha, I may try them some day, but I doubt it i'll probably throw them up here on the forums for cheap see if anyone wants em
Old 07-20-2012, 10:13 AM   #910
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
$30 Drain Kit Used -10an hose wrapped it in Dei heat wrap. Perfect!!
TopHat kit.
BlewByYou is offline   Reply With Quote
Old 07-22-2012, 01:02 AM   #911
Majorwood76
Majorwood76's Avatar
Majorwood76 is an unknown quantity at this point
Never mind edited my post
Majorwood76 is offline   Reply With Quote
Old 07-22-2012, 01:45 PM   #912
TwoHarbors240
TwoHarbors240 is an unknown quantity at this point
Just wondering if all the RB25 blocks are the same? I have an RB25neo right now and am in need of a new block, as far as i understand the only difference is the head. Would be much easier knowing that i can buy any RB block. thanks
TwoHarbors240 is offline   Reply With Quote
Old 07-22-2012, 02:15 PM   #913
BlewByYou
BlewByYou's Avatar
Block are way diff. Oil pick up, dipstick, Alot of other stuff
Old 07-26-2012, 06:18 PM   #914
the a3k
the a3k is an unknown quantity at this point
on my rb25, im getting rid of the stock crossover type intake manifold and installing the greddy one. here is a pic of the stock piping
http://i.ebayimg.com/t/RB25DET-INTAK...pZw~~60_57.JPG
with the greddy one eliminating all the extra piping, i need a pipe from the intercooler to have a spot for the BOV and the IACV hose (or whatever its called) cxracing has something like this. in the picture, its the pipe right under the intercooler
anyone have experience with these or know of another company that makes these or will i have to go custom?
BUY MY STUFF
the a3k is offline   Reply With Quote
Old 07-27-2012, 04:44 PM   #915
gearhead55
gearhead55's Avatar
why do RB25s always seem to have cracked dipstick handles? What causes this? where can i find a replacement?
gearhead55 is offline   Reply With Quote
Old 07-27-2012, 04:46 PM   #916
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Heat and plastic dont mix. Buy a new replacement from Nissan.cc
CLICK HERE!!!
Old 07-29-2012, 02:18 PM   #917
gearhead55
gearhead55's Avatar
thanks. goddamn shipping costs more than the part.
Old 08-12-2012, 11:05 AM   #918
barry32
barry32's Avatar
barry32 is an unknown quantity at this point
Send a message via AIM to barry32
I have a question I have a s13 wit a rb20 and im getting a rb26 was wondering if the tranny I have now will bolt up to the 26?
barry32 is offline   Reply With Quote
Old 08-12-2012, 11:15 AM   #919
BlewByYou
BlewByYou's Avatar
It should but that's not what u wanna do, again that's not what u wanna do. Way to weak will break under a load
Old 08-22-2012, 07:06 PM   #920
dj6923
dj6923 is an unknown quantity at this point
This is quoted from NICO also but I can vouch for this because I used it on my RB25.
My new find with all this trial and error is that the vq35 slave cylinder out of the 05 Maxima and 350z will fit the pattern and is bolt on. No drilling is required but you will find that it is a bit more round on the back and the stock bolts aren't long enough to fit. That is no problem easy fix. Extended bolts and spacers. I just did this and works beautifully.
Advance Auto Parts # 900043
2 M10-1.50 x 40mm Bolts (17mm hex head) Lowe's Item Number 138219
2 bags of 10mm Flat washers Lowe's Item Number 138377
2 10mm lock washers Lowe's Item Number 138380
Take your old one off.
Put in the new bolts 1 lock washer on each head and then 5 flat washers behind each and reassemble. This will push it all out and line up the way it should. Works great and for $33.48 you can have it that same day. Hope this helps everyone instead of drilling everything and paying an arm and a leg.
Goodluck,
David
dj6923 is offline   Reply With Quote
Old 08-23-2012, 07:09 PM   #921
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Any of you RB25 guys running the PBM Cobra flex downpipe with Syko mounts? It says on PBM's website it will fit with McKinney Mounts. I PM'd Dan from PBM and he said he's unsure if it will fit with the Syko mounts and doesn't know of anyone with that combo....Any help would be appreciated.
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 09-07-2012, 08:20 AM   #922
tschmidt55
tschmidt55 is an unknown quantity at this point
how difficult is it removing a transfer case off a awd rb25 tranny and making it a RWD ?
tschmidt55 is offline   Reply With Quote
Old 09-08-2012, 08:23 PM   #923
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
My rb25 only runs good after 70 degree's Celsius. Anything under and it stalls out an dies. Did a computer reset. Drives a lot better when warmed up but same thing when cold. Could this be from a bad 02?
smoked240 is offline   Reply With Quote
Old 09-09-2012, 07:00 PM   #924
BlewByYou
BlewByYou's Avatar
Maybe if it's not warming itself up!
Old 09-17-2012, 09:41 AM   #925
smoked240
That's kinda what I was thinking. I heard they have a heating element in them? Not sure if it's accurate. But if that's not working then I could see how it could run like crap only cold. A replacement would be a 90-96 300zx tt correct?
Old 09-17-2012, 09:51 AM   #926
fearlessKouki
fearlessKouki is an unknown quantity at this point
i need confirmation on a rb20 powersteering belt number....i searched and their were different sizes/part number....one size i found was # 11950-04U00. is this the right one?
fearlessKouki is offline   Reply With Quote
Old 09-17-2012, 12:13 PM   #927
Majorwood76
My rb20 did this I forgot to wire up the cold start signal, if I reset the ecu it would start fine but after a couple of days it would get worse.. Until it warmed up then it was good, not too sure on the wiring for a rb25 though
Old 09-17-2012, 12:41 PM   #928
Majorwood76
Gates belt K030328 autozone, o Rieley will cross reference it to their belt
Old 09-17-2012, 12:46 PM   #929
fearlessKouki
Thanks alot Majorwood76! getting the belt today after school :P
Old 09-17-2012, 03:08 PM   #930
smoked240
Jordan innovations wired mine up. I don't think it's the wiring it's been done for almost 2 years and ran fine up until mid summer this year.
