Old 07-13-2012, 11:35 PM   #91
onehundredoctane
onehundredoctane's Avatar
Wow there is more to that thing than I expected! Looks heavy
KEEP IT UP!!!!!!!!!
Old 07-15-2012, 09:00 PM   #92
pokey_
pokey_ is an unknown quantity at this point
Ugh. Upgraded the 1'MC to a 1-1/16" MC. ME and my son get in the car to make a test drive started it and my son says "The brake pedal just went to the floor by itself!". Now I need a booster. Any recommendations? Get a new s13 stock one or put my s14's automatic one on there. I know how the hell could I be building an AWD 240 and not know the simple stuff. I feel the same way. :-(
pokey_ is offline   Reply With Quote
Old 07-15-2012, 10:26 PM   #93
funnyscreenname
funnyscreenname's Avatar
funnyscreenname is an unknown quantity at this point
what kinda rubber is that you've used between the metal to metal surfaces? did you just cut the rubber that was there as needed or what?
funnyscreenname is offline   Reply With Quote
Old 07-16-2012, 05:27 PM   #94
pokey_
I assume you are talking about the AC part? With the AC box after I cut the plastic loosening the fitting allowed it to be turned to the new position. In the firewall I am cutting the firewall holes to the same dimensions in the new locations and using the factory rubber to protect it...
Old 07-17-2012, 08:09 PM   #95
pokey_
Well the weather hasn't worked with me these last few days. Got the r34 xmember and here is the first test fit. Frame rail and x-member will need modification.
Got a spline count on r32 front axles and they are different. Now my thinking is that the hubs can be swapped with the maxima's. Hunting down that answer now....
Old 07-17-2012, 09:39 PM   #96
onehundredoctane
Work being done! I hate you for this project btw, I mentioned this exact same idea to a friend last year and he talked me out of it
On the axles. . . can you use the Maxima outter where it goes into the knuckle, and just have the rest of the half shaft made? Most places that made axles can made anything from scratch if you absolutely have to have them.
Old 07-17-2012, 09:51 PM   #97
pokey_
Custom can be made. Sad thing is that the custom axles cost almost as much as the car did!!! If I must I must but trying to find the most cost effective way. I hope this is the first of many AWD 240 projects.
Old 07-17-2012, 10:44 PM   #98
Superaison
Superaison is an unknown quantity at this point
yes for sure! I'd like to see this build continue!!!
Superaison is offline   Reply With Quote
Old 07-18-2012, 05:56 AM   #99
onehundredoctane
With other engine configurations too?
Old 07-18-2012, 10:49 AM   #100
Breakbeat93
Breakbeat93 is an unknown quantity at this point
Subscribed...sick
Breakbeat93 is offline   Reply With Quote
Old 07-18-2012, 11:56 AM   #101
JdmGtDriver
JdmGtDriver's Avatar
Trader Rating: (28)
JdmGtDriver can only hope to improve
Feedback Score: 28 reviews
Send a message via AIM to JdmGtDriver Send a message via Yahoo to JdmGtDriver
Subscribed!!!
Dream to achieve!!!
JdmGtDriver is offline   Reply With Quote
Old 08-01-2012, 07:06 PM   #102
pokey_
Well between 100+ degree days, thunderstorms and/or late nights at work I haven't been able to get out and work on the car. I pulled the vh45's factory oil pan (it will need some trimming on the passenger side) and used my floor jack to lift the hacked up GTR diff somewhat into place (in reference to the engine). I am getting more motivated as it looks like I can get the diff in and still have a starter! Once I get the lower control arms I will be able to positively locate the GTR subframe and Diff.
Old 08-01-2012, 07:22 PM   #103
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
interesting.
P-Funk alot is offline   Reply With Quote
Old 08-08-2012, 07:20 PM   #104
pokey_
This is Louisiana so AC is not an option (for me). GTR axles are on their way finally. Here are some progress pics for the quest for a VH45 build with working AC.
Old 08-08-2012, 07:22 PM   #105
pokey_
Once the lower control arms show up I can finish up the crossmember placement and pull the engine to start chopping vh45 oilpan to clear the skyline diff....
Old 08-08-2012, 07:39 PM   #106
pokey_
Did some more trimming on the diff so I wouldn't have to do as much hacking on the VH45 oilpan.
Old 08-08-2012, 07:49 PM   #107
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
This is one of the most interesting builds I've ever seen on Zilvia. Kudos to you, good sir. I hope I get to see it running around LA some day.
-Kyle
Old 08-08-2012, 09:08 PM   #108
h2v7
h2v7 is an unknown quantity at this point
bump dooooo etttt
h2v7 is offline   Reply With Quote
Old 08-09-2012, 06:19 AM   #109
onehundredoctane
Hurray progress!
Old 08-24-2012, 07:33 PM   #110
pokey_
Well parts are my big hold up. Bought and paid for axles then they call back and say they don't have them. Bought subframe and LCA's, subframe came in but the LCA's haven't showed up yet. First one thing and then another, guess this is the way it goes with custom projects. Finally got the subframe modified to bolt to one pair of the original s14 bolts, once it is up and square I will drill new holes in the frame for the other 3 bolts per side to go in the same way the factory is setup.
Also got the holes drilled to mount the clutch master cylinder.
Old 08-24-2012, 08:11 PM   #111
pokey_
Old 08-24-2012, 09:39 PM   #112
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
im glad you didnt just beat the hell out of your fire wall with a large object lol
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 08-25-2012, 02:47 AM   #113
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
just can't comprehend it all...
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 10-04-2012, 03:39 PM   #114
ReaperBJJ
ReaperBJJ's Avatar
ReaperBJJ is an unknown quantity at this point
Is this project still breathing?????
'89 240sx-Track monster in progress
'03 Grand Prix GTP-pepped up DD.
ReaperBJJ is offline   Reply With Quote
Old 10-04-2012, 08:11 PM   #115
TheRealSy90
TheRealSy90's Avatar
I have faith that this will be finished.
Such a good signature.
Old 10-04-2012, 08:27 PM   #116
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
He needs Skyline axles and can't find any, anywhere.
SLiDe_WaYz is offline   Reply With Quote
Old 10-05-2012, 08:29 AM   #117
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
call elitejdm in philly, he has tons of complete skyline subframes...maybe he will be willing to part some of it out.
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 10-05-2012, 08:34 AM   #118
SLiDe_WaYz
SLiDe_WaYz's Avatar
If I'm not mistaken he has te subframe already just needs the axles for the spindles.
Old 10-05-2012, 01:28 PM   #119
pokey_
Still working on it.
I have been having issues locating front axles. Once I have those in I can make a huge leap forward. (Un)fortunately since I bought a R34 subframe instead of an R32 my Maxima Knuckles won't work so I am going the custom route, so I need the axles so I can fab the knuckles.
Old 10-05-2012, 02:53 PM   #120
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Why not take the easy way and go the r32 since the knuckles will work?
450sx, awd
