Old 06-18-2012, 04:03 PM   #4291
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
i recently got done with my LCA/knuckle combo (based on Def's how-to). i used knuckles which were professionally cut and TIG'd for greater steering angle. i drilled out the knuckle to 3/4" and used shims totalling ≈1.7" (≈42mm) of roll center correction. i also drilled out the tie rod pickup point to 5/8" to use a heim joint and fine tune it's drop down distance (aka bumpsteer correction) with various collars and washers. the final product looks nice and made LOTS of angle compared to stock.
the only down side is the shorter pickup point on the knuckle gives less steering leverage, making it very hard for me to steer without power steering. sooooo i converted back to stock LCAs and knuckles for the time being. i may convert back to power steering later, we'll see.
in the meantime, if someone wants to buy this setup (modded LCA's, modded s13 knuckles, outer tie rods, and all the nuts/bolts/spacers/shims/etc), PM me. i'd consider selling it all as a complete bolt-in setup and just sticking with the simplicity of my stock stuff for now.
i wish i had taken a pic when everything was installed. lotsss of angle! haha
jaysgottaredtop is offline   Reply With Quote
Old 06-19-2012, 02:03 AM   #4292
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
Wow they dont even look modified!
I dont get overcentering right now because it is running stock caster but I do need to relocate the steering rack because it will definately overcenter once I have solved the clearence issues
Originally Posted by frifox View Post
i30 ones are 35mm longer than s14 tie rods, which in turn are longer than s13 tie rods by 10mm (?).
The s14 has longer lower control arms so it should also have longer tie rods, but they could have just made outer ones longer too
Motary is offline   Reply With Quote
Old 06-19-2012, 06:24 AM   #4293
jaysgottaredtop
yeah, the shop did a crazy clean job of welding and grinding to make the knuckle look damn near OEM!
Old 06-19-2012, 06:27 PM   #4294
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Top is Z32
Bottom is S14
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 06-19-2012, 09:27 PM   #4295
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Have you attempted using the knuckles with stock S13/S14 LCA's?
While the shorter pickup probably did make steering a bit more difficult, if you ran a lot of negative camber thanks to those adjustable LCA's, that may have been the main culprit.
Old 06-19-2012, 09:46 PM   #4296
jaysgottaredtop
^ i tried driving around with the LCAs adjusted to roughly s14ish length. not crazy amounts of camber and toe was zeroed out. simply too hard to turn a tight corner without that leverage on the knuckle and without power steering to assist.
Old 06-19-2012, 09:52 PM   #4297
Matej
Trader Rating: (39)
Good to know. Guess I will keep my knuckles stock for now.
Old 06-20-2012, 01:59 AM   #4298
Motary
Motary's Avatar
I installed inner tie rods from that of Nissan Maxima A32, they are the same as I30. They are much longer than X-trail ones but still I have 10mm of thread engagement so I am planning to fit a rack spacer. Have any of you had problems with offset rack spacers? Removing the front crossmember seems a bit pain
I also adjusted my camber plates to max negative camber with min. caster ( rotated them toward inside), tyre looks quite flat on the ground
Old 06-20-2012, 02:50 AM   #4299
STR8E180
STR8E180 is an unknown quantity at this point
Originally Posted by PerilousActs View Post
What is this from? Details?
Any reason to use those knuckles over the z32/r32 style like MotoIQ has been doing on the old XS Engineering long a-arm setup?
its the MCA time attack car from Australia
STR8E180 is offline   Reply With Quote
Old 06-20-2012, 10:24 AM   #4300
swiftmini
swiftmini is an unknown quantity at this point
why not just make some longer?
[SIGPIC][/SIGPIC]
swiftmini is offline   Reply With Quote
Old 06-21-2012, 06:23 AM   #4301
Motary
Motary's Avatar
It was a question of time which I didnt have. I am moving my car home back to my personal workshop, keeping it with me in the city is useless because the garage is about half a meter of space to both sides lol
Adding a spacer will also increase rack travel but I have to make a custom lower control arm and I am unsure how to proceed.
Picture of ride height and arm position:
Before:
After:
Maybe make an arm like Nigel's
Old 06-21-2012, 08:33 AM   #4302
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Alright, so here's the scoop. I installed Megan Racing roll center adjusters all around on my car a while back, basically just as a replacement for the ball joints (since I know that they do nothing to actually correct roll center.) I've decided to do something about that, and purchased some Ikeya Formula front LCAs for the car to help with the roll center and keeping the arms level to the ground.
I had hoped to score a set of Ikeya Formula RLCA, but I lost out on that deal. I am now in the market for some PBM RLCAs to correct roll center, but for another reason as well. My rear wheels that I recently had rebuilt are a bit too aggressive for my tastes, so I am planning to have the back pad shaved down 5mm to get closer to the look I want. However, I am not sure that will be enough.
I emailed PBM and found that the track width with their arms can be adjusted up to 10% in from stock (7mm), or up to 90% out (wider) from stock. If I were to adjust my rear track width inward 7mm with these arms, this would reduce the rear camber I have to run to clear the fender, correct? I found a similar situation on Joel of C's Garage's car, where they shortened his RLCA to remove some negative camber:
My other question is: I need to run different tie rod ends, such as SPL, in addtion to the Ikeya FLCA that adjust roll center, correct?
Appreciate any insight- I've done my research and am in the process of doing some more, but I would love to hear some experienced opinions.
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 06-21-2012, 09:05 AM   #4303
Motary
Motary's Avatar
1) yes
2) You need to run Ikeya tie rods aswell, psm ones for pro kit are quite similar, perhaps those could work
Old 06-21-2012, 09:31 AM   #4304
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Motary, what kind of joint is Nigel using on the front LCA where the tension rod bolts to it?
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 06-21-2012, 10:17 AM   #4305
PoorMans180SX
PoorMans180SX's Avatar
I had hoped to score a set of Ikeya Formula RLCA, but I lost out on that deal. I am now in the market for some PBM RLCAs to correct roll center.
PSM rear control arms don't actually adjust roll center, because you don't really want to do it with the lower arm anyway. You'd either want to get PSM/SPL subframe risers, or their rear knuckle, although for your setup just the risers should be fine, as you're not correcting that much in the front.
Old 06-21-2012, 10:25 AM   #4306
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
This.
Though, the arms do come with a little (5mm?) spacer to correct a bit.
thefro526 is offline   Reply With Quote
Old 06-21-2012, 10:47 PM   #4307
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
What benefit would there be to a narrower rear track besides fitting wheels? How would that effect the suspension's travel? I heard a rumor that some of the top level guys have their rear track narrower than stock and I can't wrap my head around why that would be better.
DJPimpFlex is offline   Reply With Quote
Old 06-22-2012, 01:18 AM   #4308
Matej
Trader Rating: (39)
It mainly has to do with how narrow the rear track is in proportion to how wide the front is, I believe. I know I have read an article a long time ago claiming that the narrower the rear track, the better the car will drift. Unfortunately I do not remember any of the technical explanations, just said conclusion.
That is why more and more drift cars are looking like this.
http://www.youtube.com/watch?v=prxyE1k03q8&showinfo=0&iv_load_policy=3&vq=hd1080
Old 06-22-2012, 06:45 AM   #4309
Lutz Performance
Lutz Performance is an unknown quantity at this point
I would think that have a smaller rear track would help the car to swing around.
It should be the same as it is on road racing applications. great front track helps to rotate the car, so maybe they are using that instead of adding rear toe in.
ex b: more mechanical grip, so you dont have to run as big of a tire up front (i believe)
http://www.youtube.com/watch?v=MNvtuOWhljQ
Parts Sales
Email [email protected]
Phone 813 949 3540
Lutz Performance is offline   Reply With Quote
Old 06-22-2012, 08:35 AM   #4310
CamryOnBronze
Wow, really? The shank on their rear lower arms looks a ton longer than the factory ball joints. Maybe I am just seeing things? The reason for my concern is that Ikeya Formula recommends running their front and rear arms together, and says you should not run only the front or only the rear. However, I do have the PBM risers out back right now, so maybe that is enough to allow me to run the Ikeya front arms alone?
Regardless, I have decided to just have the wheels modified for now, and not mess with the rear lower arm at this time. Appreciate the info and insight guys- lots of great info in here.
CamryOnBronze.com
Old 06-22-2012, 08:47 AM   #4311
thefro526
thefro526's Avatar
That initiation was so weird. I can't tell if he just under-steered a ton or what, looks like his car is setup really awkwardly.
Old 06-22-2012, 10:36 AM   #4312
PoorMans180SX
It's all a big compromise depending on what you want to do or how you want the car to drive. A wider front track gives more front end lateral grip and a narrower rear does the opposite basically. Since lateral grip doesn't matter so much when you're drifting, they can shorten the track to help the car initiate.
Shortening the rear lower arms helps with dynamic camber change a little as well, at least if you don't have much roll center correction.
Well, rear toe in is generally for more forward bite on suspension compression, and that car doesn't look like it actually has much front grip, he's throttle steering after initiation for sure. He just knows his car really well.
Yes, you'll be just fine with the risers in the rear and Ikeya's up front.
Yeah man, that car looks like it would be kinda sketchy to drive unless you were doing backwards entries all the time. I'm guessing the car is setup so that it has both massive understeer and oversteer, which tends to happen when you go to extremes like that.
Also, his steering is probably so quick that he can turn the wheel that far in with a flick of the wrist probably.
Definitely looks cool, hahah. Like I said above, it's all in what you want the car to do.
Old 06-22-2012, 07:24 PM   #4313
IsBettyBish
IsBettyBish is an unknown quantity at this point
That looks like a shallow faint initiation. I see it all the time here in Japan. Especially in street drifting where the roads are narrow. That shit looks Boss to me.
IsBettyBish is offline   Reply With Quote
Old 06-22-2012, 07:50 PM   #4314
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
I think it has a lot to do with his narrow ass tires and toe out. Probably running such narrow wheels and tires and spaced so far out to get that much angle.
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 06-27-2012, 04:05 PM   #4315
240sxr
240sxr is an unknown quantity at this point
ok so, i'm going to get an alignment
i have D-max coil overs,extended LCAs,maxima/i35 tie rods,and PBM SAK
im going to use my coils to adjust caster and the LCAs to set camber,
its mainly a drift car,with little street use,any tips on how should i set my caster,camber and toe
thx
240sxr is offline   Reply With Quote
Old 06-27-2012, 04:14 PM   #4316
thefro526
thefro526's Avatar
You're totally right.
I think what messed my head up was the bit of understeer on turn in combined with the amount of body roll he had. I'm used to cars that are way stiffer than that.
That car really make me want to reconsider my whole love of wide wheels up front, that thing looks like it has a tonne of angle and probably just has hammered fenderwells.
Old 06-29-2012, 05:45 AM   #4317
Motary
Motary's Avatar
by the way, Poorman, do you sometimes update the front page? It would be quite beneficial to make a list of mods to improve roll centers, camber curves and max steering locks and perhaps use my graph of rc mod effectiveness so people would know how to improve their suspension spending a reasonable amount of money
Old 06-29-2012, 06:44 AM   #4318
PoorMans180SX
Yes, I really need to edit the first two posts. The info is quite outdated now. I'll try and get around to that next week when I have a few days off.
Old 06-29-2012, 08:10 AM   #4319
Lutz Performance
Does anyone have some spare bumper steer correction endlinks for sale?
looking to replace the ones on my hatch, but oem stuff wont cut it for more than 3-4 months
Parts Sales
Phone 813 949 3540
Old 06-30-2012, 07:45 PM   #4320
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
thx
i like slight toe out up front (1/8 or less), -4.5 camber, 7 caster. rear i do 1/4 inch toe in, -0.4 camber
travypoo is offline   Reply With Quote
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
