04-04-2012, 08:27 AM | #32 | |
Flywheel bolts I am using ARP flywheel bolt set for a 4age
http://allies-drift.blogspot.com/ |
04-07-2012, 06:50 AM | #33 |
Also another update. I ended up using a ACT 6 puck clutch disc from an sr20det. The fitment is great!
I also had to have my Z33's trans bellhousing machined down 5/8 of an inch to compensate for the adapter plates thickness. Z trans mated up OBX/ebay Shorty headers for a 4.7L tundra with a 2uz-fe. Passenger side fits perfect after the flange is cut off. Driver side is a different story and is going to be a bitch because of the steering shaft Whipped up some motor mounts(1/8 plate-1.75 tube cut at a 40 degree angle to use oem 1uz engine mount) and also realized how shitty the driver side header is going to be. Finally all fitted in place. Hope this helps some people out being there isnt much info out there yet. If there is enough interest I will make a more detailed build thread
04-07-2012, 11:37 AM | #34 |
Nice to see this thread is still on going. Still interested in the swap in the future.
04-15-2012, 09:34 PM | #36 |
flicktitty didn't even realize you had this thread when I was messaging you about the 2jz and 1uz swaps..
I am hoping to go to a junkyard and pull a 1uz within the next month or so. Really excited for this swap. Although all the videos I've seen are either exhaust sounds or drifting. Wanna see how an s13 with this swap would handle other things
time for a v8 |
04-16-2012, 06:40 AM | #37 |
04-17-2012, 02:58 PM | #38 |
How many of you guys think this swap would/could make for a possible DD?
i know the 1uz can be extremely reliable but obviously this is no ordinary 1uz appliance
time for a v8 |
04-18-2012, 06:35 PM | #39 |
I should get my little tax return in a month and I will start my swap then if everything is on the up and up. I'm gonna shoot for a budget around $2,500. I know someone who has done it for under $2,000 (using stock tundra/sequoia exhaust manifolds). Im gonna do a build thread but I'm bad at that kinda stuff. Someone with the skills should do a really detailed one almost like a diy to prove just how easy it really is so we can make this a more of a commin swap.
04-30-2012, 11:43 PM | #40 |
using a stock 5vz or 3sgte flywheel and a ka/sr/z33 clutch disc&transmission along with oem tundra exhaust manifolds, im sure this swap can be done under a budget cap.
05-01-2012, 05:34 AM | #41 |
how will this swap affect the handling of the s13 chassis? i have an SOHC in my 89 hatch and i love the way it handles, but the 1uz swap is very interesting to me. i used to work for a Lexus dealership and i have NEVER seen a blown 1uz. these engines are very reliable. i recommend changing the starter while it`s on an engine stand because they are a pain once it`s in the car.
05-04-2012, 04:01 PM | #42 | |
05-07-2012, 07:40 AM | #43 |
Get onto Facebook and look up Justin barber from Goldsboro, Nc. He did a 5 speed swap on his 1uz into his sc400. I believe he used a mk4 supra tranny. He did it from the ground up as well. He's a huge yota guy and he knows his shit. Sorry it's a outta forum reference but like I said. He's extremely knowledgable about yota/lexus stuff. Here's some pics of his car.
ImageUploadedByTapatalk1336397981.422931.jpg ImageUploadedByTapatalk1336398023.254247.jpg
WHAT WHEEL GAP?? |
06-20-2012, 05:30 AM | #44 |
Some more updates/pics of the swap...
Motor is finally in for good Modified driverside header to clear steering shaft
07-30-2012, 06:58 AM | #48 |
I was going to go LSx, but I don't think I can pass up $2,000ish swapped for a v8 (even though 256whp is a little low)
Also thought you guys might want to check this out. Bullet Cars - Supercharger Kits Toyota 1UZFE Bullet supercharged of Australia, offers a m90 supercharger kit ($300-600 used s/c) that would be good to add another 170 or so hp. What are you guys using for engine management for your stuff?
07-30-2012, 10:26 AM | #49 |
Trader Rating: (33)
Feedback Score: 33 reviews
I had followed the S14 swap which was done in the Red Kouki years ago and was wondering if the swap was going to catch anyone else's attention. Glad this setup is becoming more popular since as noted, the motor is an absolute charm in stock form. I myself have also not seen one blown and I have known a couple of older gear heads who were all about Toyota power.
08-01-2012, 03:40 PM | #50 |
I'm going to pull this motor out of a ls400 TODAY! I cant beat the price 300 bucks, she has 180k her but from everyone i talked to that's nonething. I'm going to put my SR transmission on the back of her and keep her mostly stock. I have a nitrous kit sitting in the closet. I may just hook that up and plumb a 100 shot then call it a day.
09-17-2012, 08:07 AM | #52 |
Did you use a crown ecu or how did you bypass the key start interlock immobilizer thingy? Also want to know what parts you used in your swap and HP if you got any ideas. I know the gs400's were rated at 300 crank so maybe 300whp with headers n full exhaust?
01-29-2013, 10:05 AM | #55 | |
I always thought a VVTI UZ would be an awesome setup.
02-09-2013, 08:21 AM | #57 |
Im planning on doing this swap into my S13 coupe. Does anyone have more info on running the KADE trany? I just need to know what flywheel, clutch, bearing to run. I have a fresh white bunny clutch and flywheel for my KADE sitting here that I'd like to use.
02-10-2013, 03:50 AM | #58 |
toyota 3v or 5v flywheel, turbo mr2(3sgte) pressure plate and sr20det disc with 4age flywheel bolts.
02-10-2013, 03:51 PM | #60 |
pilot bushing needs to be made as far as i know. some one might be selling them though. as far as the trans and drive shaft, if you stick with the ka, no mods required. although i read about the throw out bearing falling off the sleeve due to over extension, i think if the ka trans bell housing gets machined so that the same thickness of the adapter can be removes, it might fix the issue. not sure though.
