Old 12-25-2011, 01:26 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
(2) S15 SR 6-Speed Transmissions
I have two S15 6-speed transmissions for sale. One of them is out of my own car. I ran it for 4 years with 400whp without a single issue. It includes the following:
  • 6-speed transmission
  • Slave cylinder
  • Stainless line
  • Transmission cross-member
  • Bell housing plate
Asking $400 OBO... will ship at buyers expense.
The second one I picked up from a friend out of a parts car. It includes the following:
  • 6-Speed transmission
Asking $350 OBO... will ship at buyers expense.
I also have an OEM S15 SR 6-speed clutch I would give away with either transmission. On top of that I have an unknown steel driveshaft for this transmission into an S13... most likely a Driveshaft Shop. But since I do not know the brand I will also give it away with one of the transmissions.
Or $650 for everything I have listed
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-25-2011, 04:46 PM   #2
KravingAKouki
KravingAKouki is an unknown quantity at this point
was the 6 speed you had in your own car from your s14? I wish i saw that sooner cuz i want one so bad. GLWS
KravingAKouki is offline   Reply With Quote
Old 12-25-2011, 05:11 PM   #3
Spencer dougherty
Trader Rating: (65)
Feedback Score: 65 reviews
wow... prices are off the hook!!!! damn good deal
Old 12-25-2011, 05:58 PM   #4
Broadfield
Broadfield's Avatar
It's out of my S13... I have never owned an S14!?!
My Portfolio
Please Share
Check Out My Builds
Old 12-25-2011, 06:38 PM   #5
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Will this bolt onto a KA after the bellhousing from a KA is swapped on?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 12-25-2011, 06:44 PM   #6
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
no, it will not.
Toby, I know you are trying to keep it with the transmissions...however, whenever/if you change your mind I will still gladly purchase the transmission cross member for the 6spd.
sidewaysil80 is offline   Reply With Quote
Old 12-25-2011, 07:04 PM   #7
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
Wow.. What a steal..free drive shaft too
gunmetalr32 is offline   Reply With Quote
Old 12-25-2011, 09:01 PM   #8
zombiewolf513
Awesome deal. GLWS
Old 12-25-2011, 10:45 PM   #9
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Send a message via AIM to ship2236
Wow well priced man. Glws!
ship2236 is offline   Reply With Quote
Old 12-26-2011, 08:20 AM   #10
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
Any idea on mileage? I'm currently looking for a transmission and have went thru 3. Wasn't sure if I would go with this or a z33. This is obviously the cheaper option, I'm just worried about another one going out on me. Do you need the rear end for the 6th gear to work?
1quk240 is offline   Reply With Quote
Old 12-26-2011, 09:02 AM   #11
zombiewolf513
Short answer: no.
Long answer: You need the rear end and a dakota digital box to make your speedo work. But if you're running an ABS Model S13 you should be able to tap into your abs diff housing and get the signal from the abs sensor, Then you'd need a driveshaft (driveshaft shop). You also need the s15 transmission bolts to mate with the SR20. I'm not sure if you need the dual mass flywheel but I'm almost positive you do + the flywheel bolts for an s15 because they're longer for the dual mass flywheel. And you'll need the 6 Speed Trans. cross member. I'm doing the total opposite swap right now (S15 SR Engine to S14 SR Trans) and what I told you is basically the opposite of everything I had to do.
Old 12-27-2011, 12:08 AM   #12
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
Is that 650 for 2 tranny and the spare parts you listed?
Ch
Sent from my DROID RAZR using Tapatalk
heychris is offline   Reply With Quote
Old 12-27-2011, 07:21 AM   #13
Broadfield
Broadfield's Avatar
Not sure on mileage. I put around 10,000 miles on mine since it came from Japan. I can't speak for the "other" trans. I'm not sure what 6th gear working has to do with the rear-end.... but no, you do not need the S15 rear-end to get it to work.
Ch
Correct, for everything I have listed!
My Portfolio
Please Share
Check Out My Builds
broadfield, s13, s15 sr 6-speed, transmission
