Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-13-2011, 10:42 AM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (78)
IMPORTIMAGE is an unknown quantity at this point
Feedback Score: 78 reviews
Send a message via AIM to IMPORTIMAGE
BE A HERO! GoPro now @ Import Image Racing!!!****************************************
WE ARE PROUD TO BRING YOU THE LEADER IN AUDIO/VISUAL TECHNOLOGY FOR MOTORSPORTS AND MORE
MOTORSPORTS AND HELMET CAMS
**SHIP FREE FOR Zilvia MEMBERS**
IN THE LOWER 48 USA
Import Image Racing OFFERS THE ENTIRE GOPRO LINEUP, BUT HERE ARE SOME OF THE CREAM OF THE CROP
HD MOTORSPORTS HERO $299
STD DEF $149.99
ABOUT:
GoPro’s HD Motorsports HERO is the world’s highest performance 1080p HD on board video and still photo racing camera. Professional quality 1080p, 960p, and 720p HD resolutions records the action at 30 frames per second (60 fps in 720p). The HD Motorsports HERO easily mounts to any helmet, motorcycle, ATV, car, plane, jet ski, boat, snowmobile or other vehicle. The camera’s quick-release mounting design makes it easy to re-position the camera around your vehicle for professional quality HD video from several angles.
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
GoPro’s obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor…not the drone of the wind and road.
The camera can also shoot automatic 5MP time lapse photos at 2/5/10/30 and 60 second intervals during your drive or ride, hands free. Press the shutter button once and record up to 2.5 hours of on board action with poster-print quality photos.
Included are mounts for two helmets and three vehicles, as well as a suction cup for maximum versatility and convenience. Also included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
Waterproof to 180’ / 60m and protected from rocks and other hazards thanks to its removable polycarbonate housing. Replacement housings and lens kits are available, making repairs or refurbishing your HD HERO camera affordable and convenient.
WHAT COMES WITH IT?
1 HD HERO Camera (5 megapixel)
1 Rechargable 1100 mAh Lithium-Ion Battery
1 Waterproof Quick-Release Housing (180’/60 m)
3 Flat, 3M™ Adhesive Mounts
2 Curved, 3M™ Adhesive Mounts
2 Quick-Release Buckles
1 Vertical Surface “J-Hook” Buckle
1 Suction Cup Mount
1 Three-Way Pivoting Side Arm Assembly
1 USB Cable
1 Component Video (HDTV) Cable
1 Composite Video + Audio Out Cable
Warranty: One Year
TECH SPECS:
Camera Optics
  • Lens Type: Fixed Focus (2ft/.6m – ∞), glass
  • Aperture: f/2.8 (high performance in low-light situations)
  • Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
  • Angle of View: 127º wide angle in 1080p mode
Video
  • HD Video Resolution Modes: (subject to change, pending final firmware release)
    • 1080p = 1920×1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
    • 960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
    • 720p = 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate
    • 720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
    • WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
  • Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
  • Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
  • Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
  • Exposure Control: Auto with user selectable center weighted average and spot metering settings
  • White Balance: Auto
Audio
  • Microphone: Built-in, mono with AGC (automatic gain control)
  • Audio Format: 48 kHz, AAC audio compression
  • Resolution: 5 megapixel
  • Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
  • Memory: SD card (SDHC), up to 32GB capacity (not included)[/CENTER]
  • Average recording times (using 32GB SD card):[/CENTER]
    • 1080p (30 fps): 4h 21m
    • 960p (30 fps): 5h 26m
    • 720p (60 fps): 4h 21
    • 720p (30 fps): 8h 09m
    • WVGA (60 fps): 8h 09m
Camera Connectors & Cables
  • PC Connection: USB 2.0 (data connection and battery charging)
  • HDTV Out: HD NTSC & PAL (component cable incl.)
  • Audio Out: Combo 2.5mm jack with stereo audio and composite video out
  • PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
  • Battery Type: Rechargeable 1100 mAh lithium-ion
  • Battery Life: Approx. 2.5 hrs
  • Charging: via USB to computer or optional power adapter
  • Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
  • Depth Rating: Up to 180 feet / 60 meters
  • Construction: Polycarbonate and stainless steel
  • Hardware: Stainless steel
Size & Weight
  • Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
  • Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
WHAT ELSE IS AVAILABLE!!??
HD HELMET HERO $299
STD DEF 149.99
ROLL BAR MOUNT FOR GO PRO $29.99
HEAD STRAP ACCESSORY $14.99
ADDITIONAL SUCTION CUP MOUNT $29.99
TRIPOD ADAPTOR FOR GOPRO $7.99
GRAB BAG EXTRA QUICK RELEASES, MOUNTS ETC.. $19.99
THESE AND SO MANY MORE ACCESSORIES, BATTERIES ETC... ARE AVAILABLE NOW FROM IIR.
ANY QUESTIONS PM OR EMAIL
[email protected]
AIM: ImportImageBilly
Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others.
Direct Line: 804-690-2452
Shop Line: 239-540-6385
Visa/Mastercard/Discover/Paypal and (amex) Google checkout![/B][/CENTER]
TIME TO TAKE SOME AMAZING PHOTOS, VIDEOS AND MORE ALL IN ONE SPOT SAFELY
FOR YOUR VEHICLE.
CUSTOMERS BE SURE TO SHARE YOUR VIDEOS AND PICS WITH US IN THIS THREAD!
opcorn:
SAMPLE GOPRO HD VIDEO, ALL SHOT WITH GOPRO EQUIPMENT SOLD RIGHT HERE
PIKES PEAK 2011
http://www.youtube.com/watch?v=MBaIl...layer_embedded
HELMET CAM, GOES WHERE YOU GO
GoPro HD: Skateboard Big Air with Andy Mac - X Games 16 - YouTube
Questions: Billy (804)-690-2452
(email)[email protected]
AIM- importimagebilly
IMPORTIMAGE is offline   Reply With Quote
Old 09-15-2011, 10:19 AM   #2
IMPORTIMAGE
Trader Rating: (78)
Thursday Bump! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Be sure check out our facebook page as well!
Regards,
[email protected]
ImportImageRacing | Discount Peformance Parts | Subaru, Mazda, and more...
Import Image Racing - Automobiles and Parts - Cape Coral | Facebook
Old 09-26-2011, 09:44 AM   #3
IMPORTIMAGE
Trader Rating: (78)
I'm back!
Want to make a combo deal? NO PROBLEM let us know what you need
Regards,
[email protected]
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda
Old 09-28-2011, 10:55 AM   #4
IMPORTIMAGE
Trader Rating: (78)
Wednesday bump
Regards,
[email protected]
Old 10-04-2011, 01:30 PM   #5
IMPORTIMAGE
Trader Rating: (78)
It's Tuesday and you know what that means! Awesome deals
Hit us up for your car part needs.
Regards,
[email protected]
www.importimageracing.com
Old 10-06-2011, 10:32 AM   #6
IMPORTIMAGE
Trader Rating: (78)
Who's ready for the weekend?
I know I am! Start the weekend off right with some new parts!
Regards,
[email protected]
Old 10-10-2011, 09:17 AM   #7
IMPORTIMAGE
Trader Rating: (78)
We hope everyone had a great weekend!
Come on in for Columbus Day sales
Regards,
[email protected]
Old 10-11-2011, 08:16 AM   #8
IMPORTIMAGE
Trader Rating: (78)
Ask us for suspension and exhaust deals today!
Regards,
[email protected]
Old 10-13-2011, 11:09 AM   #9
IMPORTIMAGE
Trader Rating: (78)
We offer multiple part discounts!
Let us know what you need and we'll set you up with an awesome deal
Regards,
[email protected]
Old 10-18-2011, 10:36 AM   #10
IMPORTIMAGE
Trader Rating: (78)
Contact me if you want to save some dollars
Regards,
[email protected]
Old 10-20-2011, 09:06 AM   #11
IMPORTIMAGE
Trader Rating: (78)
Ready to make some deals
Need multiple parts? GREAT we can hook it up!
Regards,
[email protected]
Old 10-21-2011, 12:19 PM   #12
IMPORTIMAGE
Trader Rating: (78)
FREE SHIPPING ALL DAY FRIDAY!!!!
EVERYTHING ON OUR SITE HAS FREE SHIPPING
Regards,
[email protected]
Old 10-25-2011, 08:18 AM   #13
IMPORTIMAGE
Trader Rating: (78)
We do combo pricing! Make your own and we'll get you a great deal
Regards,
[email protected]
Old 10-27-2011, 08:23 AM   #14
IMPORTIMAGE
Trader Rating: (78)
Need a quote? Let us know!
Regards,
[email protected]
Old 10-31-2011, 10:34 AM   #15
IMPORTIMAGE
Trader Rating: (78)
Happy Halloween!
Regards,
[email protected]
Old 11-01-2011, 01:31 PM   #16
IMPORTIMAGE
Trader Rating: (78)
November 1st! Start to a new month.
New deals ahead!
Regards,
[email protected]
Old 11-02-2011, 02:35 PM   #17
IMPORTIMAGE
Trader Rating: (78)
Middle of the week!
Come on in for deals during SEMA week
Regards,
[email protected]
Old 11-03-2011, 01:15 PM   #18
IMPORTIMAGE
Trader Rating: (78)
Thinking about buying multiple parts?
No problem! We offer combo deals!
Regards,
[email protected]
Old 11-04-2011, 09:50 AM   #19
IMPORTIMAGE
Trader Rating: (78)
It's Finally Friday!
Let us know what you need and we'll take care of you
Regards,
[email protected]
Old 11-07-2011, 01:29 PM   #20
IMPORTIMAGE
Trader Rating: (78)
We hope everyone had a great weekend.
Looking forward to your quotes this week!
Regards,
[email protected]
Old 11-08-2011, 12:45 PM   #21
IMPORTIMAGE
Trader Rating: (78)
What can we help you with today?
Regards,
[email protected]
Old 11-09-2011, 12:10 PM   #22
IMPORTIMAGE
Trader Rating: (78)
Midweek bump!
Regards,
[email protected]
Old 11-09-2011, 12:18 PM   #23
raz0rbladez909
raz0rbladez909's Avatar
Do you guys by chance sell the Naked? Or the HD Hero 2? I'm looking at getting the Hero 2 Outdoor Edition and was wondering cost.
2004 Corvette Z06 / 1971 240z
raz0rbladez909 is offline   Reply With Quote
Old 11-14-2011, 07:57 AM   #24
IMPORTIMAGE
Trader Rating: (78)
We will be in about 2 weeks!
Hope everyone had a great weekend!
We're ready to rock
Regards,
[email protected]
Old 11-16-2011, 10:43 AM   #25
IMPORTIMAGE
Trader Rating: (78)
Car parts? We got em!
Regards,
[email protected]
Old 11-22-2011, 09:30 AM   #26
IMPORTIMAGE
Trader Rating: (78)
Thinking about buying multiple parts? We've got you covered!
Regards,
[email protected]
Old 11-23-2011, 09:21 AM   #27
IMPORTIMAGE
Trader Rating: (78)
Wednesday Bump!
Regards,
[email protected]
Old 11-29-2011, 08:04 AM   #28
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
Old 11-30-2011, 02:40 PM   #29
IMPORTIMAGE
Trader Rating: (78)
Middle of the week bump!
Let us give you the best deal
Regards,
[email protected]
Old 12-01-2011, 11:40 AM   #30
IMPORTIMAGE
Trader Rating: (78)
Thursday Bump!
Regards,
[email protected]
