11-13-2011, 02:11 AM | #1 |
Don't put your hardware in a dirty hole! ARP head stud, main stud install trick
I'm sure this is not a new idea to most of you, just thought i'd share this simple little DIY trick with my favorite message board! Great free way to prep threads before installing new hardware such as ARP head studs, main studs, rod bolts etc.
Brewed Motorsports How to clean threads for free before installing new hardware for engine building, EG: cylinder head, rods, main studs, etc. Hope this helps someone |
11-13-2011, 09:07 AM | #3 |
I chase the threads with a tap, then blow them out with brake clean and air.
11-13-2011, 11:26 PM | #6 |
i use the same trick on semi stripped spark plug holes. i cut two grooves using a cutting wheel on a die grinder on an old spark plug and coat it with anti seize to capture the shavings. done it a few times with good results.
11-14-2011, 12:16 AM | #7 | |
One benefit to this technique vs using a tap set is the modified bolt will not cut the threads like a tap does it will only scrap them clean of any debris. Don't worry my friend so long you use some common sense when it comes to force needed while threading the bolt in and out you won't have any problems *** NOTE*** You would not ever want to re use the modified piece of hardware for anything but cleaning threads |
11-26-2011, 06:27 PM | #10 |
Trader Rating: (58)
Feedback Score: 58 reviews
This is a great shop tip for sure; something I actually leaned in the military. It's a handy trick!
04-29-2012, 10:30 PM | #11 |
Just used this again the other day as finding some tools here in Thailand can be a huge pain in the A$$
Very interesting to hear you also learned this trick in the military, I suppose it would come in handy for any field work/repairs that need to happen away from a shop full of tools. |
05-02-2012, 12:57 PM | #12 |
I just use my de-greaser air gun to blow all of the crap out of there..
i totally agree with the previous poster, that i wouldnt shove a modified bolt into the block.. i would hate to strip it out
05-03-2012, 07:26 PM | #13 | |
Yes a de greaser gun works great to get the bulk of the crap out. This is something you would do after you blow out the hole/threads with a de greaser gun. The gun alone will never clean out all the crap in the threads.
This is a tried and proven method for cleaning threads, I'm not posting up a new idea here by any means Any one who's spent a good amount of time in a machine shop will verify. |
06-11-2012, 02:08 AM | #15 |
this thread blew spambot jason8's mind!
i like this trick, never heard of it before! however, i wonder if there is any detriment in using this trick specifically with USED torque to yield fasteners. since torque to yield bolts are stretched when required torque is applied, perhaps it could damage the threads in the bolt/stud hole? i have no idea, just something that came to mind
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
06-12-2012, 12:25 AM | #16 |
Not a bad thought at all my friend! however the "stretching" of hardware is so minute it should not effect how the hardware threads into something (for example rod bolt stretch is normally .003-.006")
Of course always be careful, and remember it should not take much force/effort to thread one of these modified pieces of hardware in or out. |
06-12-2012, 12:32 AM | #17 |
lol 3-6 thousandths of an inch. yeah id say thats pretty minute. but, you know how wondering & wandering minds liike to exaggerate, making little things into big deals.
arp, engine build, head gasket, head studs |
