Old 08-11-2011, 10:37 AM   #1621
tricky_ab
tricky_ab's Avatar
Well at least you had a buddy with a trans. Good to hear that you'll be up and running sooner then later.
Old 08-11-2011, 08:05 PM   #1622
sex14
sex14 is an unknown quantity at this point
did that red 180 use to be from WA? owned by nikoly?
sex14 is offline   Reply With Quote
Old 08-11-2011, 08:06 PM   #1623
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
yup. i bought it
kyles1988 is offline   Reply With Quote
Old 08-11-2011, 10:04 PM   #1624
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
You need to just put that info in your sig, as often as it gets asked.
Z_Spool is offline   Reply With Quote
Old 08-11-2011, 10:12 PM   #1625
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Damon! Sucks about the tranny man, but I'm sure you'll have one in there in no time.
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 08-11-2011, 11:44 PM   #1626
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Yikes. Dealing with the transmission in a garage with jack stands blows. I recently just changed my clutch and I had two other friends of mine help me get it back up. A combination of angle, leverage, twisting, turning, and pushing it all in and hoping it doesn't put up a fight. LOL.
However, I'm not too strong so maybe that was the issue.
Good luck!
Old 08-11-2011, 11:50 PM   #1627
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
^ I had to do that in my girls R32....by myself. I swore lots.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 08-11-2011, 11:58 PM   #1628
Om1kron
Om1kron's Avatar
nothing says panic like having a transmission fall out onto your chest wedged between the transmission tunnel and you on the floor while you live in a state that can have an earthquake at any moment. fun times.
Wayne Edwards
https://om1kron.blogspot.com
Old 08-12-2011, 06:57 AM   #1629
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
For sure, lol. I'm having a friend come out and help me, but I'll probably swing by good ol' Harbor Freight on Monday before I pull the old one out and pick up a transmission jack. No sense in killing ourselves when they make a tool that should solve the problem for the most part, haha.
My chicken arms aren't exactly prepared to manhandle a transmission, lol.
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 08-12-2011, 07:36 AM   #1630
MidwestMyriad
MidwestMyriad's Avatar
MidwestMyriad is making a name for him/her selfMidwestMyriad is making a name for him/her self
Originally Posted by chiboy002 View Post
DOES IT WORK?
Yes, fully functioning AUTO DCC.
Although sacrilegious, wiring it was the only way to have cool lights coming from my dash.
@MMyriad
MidwestMyriad is offline   Reply With Quote
Old 08-12-2011, 08:03 AM   #1631
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
I've always just put a jack on the middle of the transmission and had a friend man part of the trans while I had the other part and we 'monkey fuck' it on and off the motor. Basically grab on and shake the shit out of it and pull/shake the shit out of it and push depending on if it is going on or coming off, lol.
I'm not looking forward to changing the clutch on the LS (whenever that is) as the T56 is significantly heavier then the SR or KA transmission.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 08-12-2011, 02:40 PM   #1632
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Totally bitchin.
http://bhworld.wordpress.com/
Old 08-17-2011, 01:47 PM   #1633
240sxcure
240sxcure is an unknown quantity at this point
I would recommend pulling the engine and transmission as one unit. Removing it while it's in the chassis is one thing, but re-installing the transmission and making sure it lines up properly is a PITA.
Plus other than removing the wiring harness, and cooling system, not much more to removing the whole engine/trans combo.
240sxcure is offline   Reply With Quote
Old 08-17-2011, 02:22 PM   #1634
MikeySand
MikeySand is an unknown quantity at this point
fuck that. taking the whole engine out is not worth it. tilt the motor back a little and putting the trans back in is not that hard. especially if you have another set of hands to help lift or align.
MikeySand is offline   Reply With Quote
Old 08-17-2011, 02:24 PM   #1635
kyles1988
kyles1988's Avatar
The transmission is back on and the car drives fine with the new trans. The motor did not need to be pulled.
Old 08-17-2011, 07:51 PM   #1636
240KAR
240KAR's Avatar
240KAR is an unknown quantity at this point
i've got some pics that i'll post of your car at ia damon... It was nice meeting you..
1989 Nissan Silvia
1989 Nissan Skyline GT-R
240KAR is offline   Reply With Quote
Old 08-17-2011, 08:00 PM   #1637
lflkajfj12123
Damon King of Dope
Old 08-18-2011, 12:56 PM   #1638
CamryOnBronze
Sounds awesome! It was great to meet you too!
Kyle is correct. I picked up the replacement transmission and a transmission jack on Monday after work. My cousin came out and helped me work on it that night- we got the old transmission out after trying to rotate it for a couple of hours. As soon as we loosened the front subframe bolts, it dropped right out. It would have been nice to have discovered that earlier in the night, but oh well, lol.
On Tuesday I started on it right when I got home, and managed to install the new transmission by myself in about 45 minutes. I'm definitely a slow worker- I'm always cautious and nervous about messing something up. The only hard part was getting the transmission onto the jack under the car by myself, since there wasn't enough space under the car to roll it under with the jack already in place. I was shocked that I was able to mount it up by myself though!
My friend Mark came out and helped with the other odds and ends. I also ended up replacing my ignition switch. The car had been taking a few tries to start and the key had to be in a very precise position to send the signal to the starter. The problem had been progressively getting worse for the last month or so. This seems to have solved the problem- everything is good to go for Wekfest now!
Crappy shot Mark took on his phone, lol:
I drove it to work today and everything seems to be good (knock on wood). I can't believe how precise the shifting is now- my old trans was in really bad shape! I'll be leaving tomorrow for Chicago to crash with my brother and attend WekFest.
CamryOnBronze.com
Old 08-25-2011, 11:50 AM   #1639
CamryOnBronze
Well, everything seems to be good with the car at the moment, knock on wood. It made the trip to and from Chicago for WekFest without any issues! I put up some info about the trip/show with some pictures on my blog.
Somehow, I managed to take home the third place stance award, which was pretty cool. I didn't even know they were doing judging or awards at the show, so it was a fun surprise. I don't usually think of my car's stance as being outstanding, but I appreciated the recognition from the judges!
When I got home from the show, I gave the car a bath and messed around taking some shots Sunday afternoon:
I don't have a lot planned until Broadfield's BBQ in October. After that when the weather starts to go South, I'll start tearing into the car. I'm not totally set on what I want to accomplish this winter, but I do have a few things in mind, including cleaning up the engine bay, installing AC, and wiring the DCC. I'll keep you guys posted!
CamryOnBronze.com
Old 08-25-2011, 01:52 PM   #1640
Riq
Riq's Avatar
Riq is an unknown quantity at this point
GReddy oil cooler would be something to do in the winter. It helps the life of your engine and looks great peeking out of the front bumper right next to the intercooler. Z32 brakes front and rear would be a great upgrade too. Keep up the great work, the car looks awesome
Riq is offline   Reply With Quote
Old 08-25-2011, 02:05 PM   #1641
KiLLeR2001
Trader Rating: (46)
How bout some front turn signals to stop that fast blinking action of yours?
Old 08-25-2011, 02:11 PM   #1642
Emeru
Emeru's Avatar
Emeru is an unknown quantity at this point
Cars beautiful, i hope to have my hatch somewhat close to this within a couple years.
Emeru is offline   Reply With Quote
Old 08-25-2011, 02:14 PM   #1643
CamryOnBronze
I've considered an oil cooler in the past, but I never do any track/hard driving for the most part. My oil temps are usually very low, so it's never been something I want to drop cash on. It would probably look cool though for sure!
As for brakes, that is on my radar for sure. The car stops plenty well for street driving with the Q45/Hawk HPS pads/Rotora slotted rotors/SS lines it has on there now, but they are for sure lacking in the looks department. I'd love to do an Endless or Project Mu setup, but I just don't have the coin. I'm still considering a Wilwood kit up there as well, but it's overkill for sure.
Hmmm... I don't have any fast blinking? Turn signals work fine.
Thanks!
CamryOnBronze.com
Old 08-25-2011, 02:48 PM   #1644
Riq
Riq's Avatar
If you're considering bbk's then I would go with 6piston front and 4 piston rear but then again even if you plan on going to the track z32's are plenty on a sub 3000lbs car. I'm running z32's and they are great. As far as an oil cooler goes, although you dont push your car you cant go wrong with an oil cooler.
Old 08-25-2011, 03:10 PM   #1645
KiLLeR2001
Trader Rating: (46)
I was referring to one of the YouTube videos you posted of your car when you triggered the turn signal. It was on fast blink action (due to you not having front turn signals). Did you add resistors to the circuit to mimic the presence of front signals?
Old 08-25-2011, 05:07 PM   #1646
chiboy002
chiboy002 is an unknown quantity at this point
r33 brakes! the only reason i don't want to go up in brake sizes is because then i have to deal with worrying if the damn wheels are going to fit.
if your oil temps dont exceed the temps required for the thermostat to open in an oil cooler, its the same as putting dead weight on the car. Street driving probably won't send the oil much higher than 105*C, if that. Running no thermostat is worse for your engine cause oil temps are stupid low.
DMAX...
street dancer.
GLEAM
Old 08-25-2011, 05:15 PM   #1647
Om1kron
Om1kron's Avatar
LOL and who makes a 4 piston rear bolt on kit for s-chassis?
There is a cheaper alternative from even going with z brakes
http://zilvia.net/f/archive-faqs/291...-calipers.html
Assuming he's an s14 5 lug assembly this should work for him too.
Wayne Edwards
Old 08-25-2011, 05:40 PM   #1648
towlie
Believe it or not stock s14 SE's cleared my (front, not running rears) r33 calipers with no spacers
You may have to toss on a slip-on at all worst
Old 08-25-2011, 06:10 PM   #1649
KiLLeR2001
Trader Rating: (46)
DMAX...
Ah I see, takes the parking light and makes it parking light / turn signal by adding two bulbs.
Old 08-25-2011, 06:14 PM   #1650
Slammed180
Does it bother you that I jank to your car?
Blow me, bitches.
king of dope
