Old 06-15-2011, 02:06 PM   #1
mooreracing240sx
mooreracing240sx is an unknown quantity at this point
Mazda RX7 Rotary 13BTT New Built Engine
Engine Building Standard Engine Assembly $800.00-------------------------------------------------------------------------------------------------------------------------------------------------
Street Port Street Porting Intake & Exhaust $200.00 ------------------------------------------------------------------------------------------------------------------------------------------------
Water Passage... Water passage Porting (30% More flow) $100-------------------------------------------------------------------------------------------------------------------------------------
3MM Rotors 3MM Apex Machining 1 @ 350.00 = $350 ------------------------------------------------------------------------------------------------------------------------------------------
8DFE-10-271 Gasket Set 93-95 FD $699.90------------------------------------------------------------------------------------------------------------------------------------------------------
N304-11-300 Apex Seal (3mm) 6 @ 96.85 = $581.10--------------------------------------------------------------------------------------------------------------------------------------------
1757-11-304 Apex Springs (3mm) 6 @ 4.45 = $26.70--------------------------------------------------------------------------------------------------------------------------------------------
N225-11-321 Corner Seal (3mm) 12 @ 5.45 = $65.40--------------------------------------------------------------------------------------------------------------------------------------------
NFO1-11-C24 HD Corner Seal Spring 12 @ 3.65 = $43.80--------------------------------------------------------------------------------------------------------------------------------------
N3Y1-11-C11 Side Seals 12 @ 13.85 = $166.20-------------------------------------------------------------------------------------------------------------------------------------------------
NF01-11-C17 Side Seal Springs 12 @ 7.20 = $86.40---------------------------------------------------------------------------------------------------------------------------------------------
N3Z1-11-S10A Oil Control Rings 4 @ 90.55 = $362.20------------------------------------------------------------------------------------------------------------------------------------------
0820-11-341 Oil Control O-Rings (Inner) Green 4 @ 21.70 = $86.80-----------------------------------------------------------------------------------------------------------------------------
1202-11-343 Oil Control O-Rings (outer) Green 4 @ 21.45 = $85.80------------------------------------------------------------------------------------------------------------------------------
N3Y2-10-S70 Rotor Housing (Front) $900.00------------------------------------------------------------------------------------------------------------------------------------------------------
N3Y2-10-S80 Rotor Housing (Rear) $ 900.00------------------------------------------------------------------------------------------------------------------------------------------------------
N3A1-10-507 Main Oil Seal (Front) $10.60--------------------------------------------------------------------------------------------------------------------------------------------------------
1668-10-556A Main Oil Seal (Rear) $14.78--------------------------------------------------------------------------------------------------------------------------------------------------------
N326-11-D15 Thermo Pellet 86/96 $57.20---------------------------------------------------------------------------------------------------------------------------------------------------------
31229 Blitz # 550cc Fuel Injector (Pri) FD 2 @ 229.20 = $458.40----------------------------------------------------------------------------------------------------------------------------------
Clean & Cal. I... Clean & Calibrate Fuel Injectors 2 @ 28.50 = $57.00-----------------------------------------------------------------------------------------------------------------------------
N3A1-14-660 Tube (Oil Metering) FD $33.20------------------------------------------------------------------------------------------------------------------------------------------------------
N3A1-14-670 Tube (Oil Metering) FD $33.20------------------------------------------------------------------------------------------------------------------------------------------------------
Extractit Remove broken bolts ect. by Electronic Disintegration 2 @ 29.95 = $59.90-----------------------------------------------------------------------------------------------------------------
N3J1-14-631 Oil Injector 2 @ 32.30 = $64.60-----------------------------------------------------------------------------------------------------------------------------------------------------
External Engi... Oil Pan $130.00---------------------------------------------------------------------------------------------------------------------------------------------------------------------
N3A1-20-285 Twin solenoid valve wastegate control $160.40---------------------------------------------------------------------------------------------------------------------------------------
Labor Misc. Install parts on engine 6 @ 80.00=$480.00-------------------------------------------------------------------------------------------------------------------------------------------
Total Build: $7, 013.58
http://s1218.photobucket.com/albums/...4-22131206.jpg
http://s1218.photobucket.com/albums/...4-22130653.jpg
http://s1218.photobucket.com/albums/...4-06175922.jpg
http://s1218.photobucket.com/albums/...4-04134618.jpg
http://s1218.photobucket.com/albums/...4-04134537.jpg
http://s1218.photobucket.com/albums/...4-27193233.jpg
http://s1218.photobucket.com/albums/...4-04135547.jpg
http://s1218.photobucket.com/albums/...4-27192825.jpg
http://s1218.photobucket.com/albums/...4-27193034.jpg
Email me @ [email protected]
mooreracing240sx is offline   Reply With Quote
Old 06-15-2011, 02:27 PM   #2
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
hey how about a price, maybe a little more information, who built it, what else it comes with? is it really that hard to do?
sidewaysil80 is offline   Reply With Quote
13b, engine, mazda, rotary, rx7
