#61 | |
timing wheels of that size are very common |
#62 |
![]() Join Date: Aug 2006
I got so exited seeing the picture of the complete engine I think I'm about to give birth..
LOOKING AWESOME
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd ![]() Boycott Berkeley and code pink |
#65 |
amazing work
gorgeous engine,gorgeous car's body what about the chassis? we know that you put on Zeal coilovers,but did you change something about brakes,suspension's elements? |
#66 |
![]() Join Date: Jun 2008
Thanx for the warm comments fellas.
Boyu2... I'm currently weighting between either Alcon 6 or Endless 6 for the front and GTR for the rear (either running a full subrame transplant or just running hydraulic handbrake). With the previous power and setup I found the standard s15 brakes with endless pads is adequate for what the car was used for. Suspension wise as per 1st post it running whiteline adjustable swaybars, front tension, nismo powerbrace etc etc. Which again are adequate for what the car was used for. The new setup will be the same bar some inclusion of front ikeya formula lower control arm/tension rod and rear toe arms, and then I take it from there. |
#70 | |
Really appreciated your comments guys...but I think Scorch S15 is the sickest of all S15. ![]() |
#76 |
Any way you could take pictures of the mazworx parts installed? I'm thinking about doing the vvl. head and would like to have a visual of what it should look like(ie the water neck, did they tap the side of the head, things of that nature?
#78 |
![]() Join Date: Oct 2006
you dont tap the head - the solenoids are remote.
Its simpler than a LS-Vtec.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#79 |
I never seen soooooo long duration on a turbo equipped engine O_o!
What about your idle? ^^ For Scorch's s15,It was make in a different way,I mean,in a different purpose (I think so) ![]() |
#80 |
boyou... it has 2 lobes - the low cam is like 240... just like a honda.
it'll idle similar to stock.
#82 | ||||
Just a quick comparison between SR20VE cams ![]() |
#86 |
Thanks fellas.
Currently the engine is sitting in the shipper local warehouse awaiting custom clearance. Due to them stuffing around with the shipping it arrived over a wk late with alot of confusion in the shipping tracking. Anyway hopes to have it delivered in the next few days. |
#90 | |
![]() Join Date: Sep 2008
YESSSSS!!!! ![]() |
