08-27-2010, 07:11 PM | #1561 |
How? like details on how?
I'm sitting here with my girlfriend getting ready to go to a movie and just yelled out, "What the fuck!? How!?" So, pwease do tell<3 Ordering soon Dan. |
08-29-2010, 03:19 PM | #1562 |
I'm still interested in how much the average person is cutting off of their knuckles. Everyone says that it depends on the wheel combo, but I'd imagine the average would be something like a x9 or a x9.5 +0 up front?
So would something like 2.5" shorter be a ball park or what? Aside from that, everyone seems to be up in arms about their front roll center and and trying to achieve great roll center or whatever, but then most are rocking the rear stock/stockish. To me it seems like it would be best to leave both alone, and then try to change all of it at once, because changing only the front will disrupt front to rear balance.
08-29-2010, 03:56 PM | #1563 | |
I spaced my front lower balljoints down ~1.625"(probably about 1.25" more than stock), and raised the rear subframe up to the framerails with SPL bushings. Feels great to me, but the front could probably use a bit more correction.
08-29-2010, 06:01 PM | #1564 | |
Trader Rating: (58)
Feedback Score: 58 reviews
This is exactly what I have done as well - the car rides better than it ever has...all I'm awaiting now are the SPL outer tie rod ends to make some of the bumpsteer go away and we're set.
08-30-2010, 01:34 AM | #1566 |
To summarize what's spread out in my posts in this thread, I use the MAX Super Angle Kit installed like this:
MAX SAK Tommy Roberts Spec That in combo with the prototype long tie rods and long lower control arms produces that angle without letting the knuckles steering arm line up with the tie rod. A wheel spacer eliminates hitting the wheel on the frame and tie rod. There are no aftermarket steering rack parts and the rack has not been moved.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
08-30-2010, 06:52 AM | #1567 |
So if that black thing (looks like a massive zip tie?) was in line with the tie rod as well, that would be over centering?
Instagram - SJKnoop |
08-30-2010, 07:12 AM | #1568 | |
It's impressive that you did all of that without over centering... Shoot, I was getting ready to move my rack forward and stuff too. Btw, do you have an ETA for the Tie Rods? I figure the LCA's are probably a few months out still? |
08-30-2010, 10:27 AM | #1569 |
Yup. I think it's a metal straightedge though? Hahahah.
08-30-2010, 01:09 PM | #1570 |
The metal ruler is the effective new knuckle steering arm angle determined by the mounting position of the MAX SAK. Exactly, if that was in line with the tie rod they would be centered, or mechanically locked due to the rack having no leverage angle to turn the knuckle.
08-30-2010, 01:43 PM | #1571 |
How many degrees of caster are you running on the S15 Dan?
08-30-2010, 02:00 PM | #1573 | |
In the above photo with the new FLCA, are you running the normal SAK or the T.R. SAK's? I have the normal SAK, don't know whether I should wait to get the FLCA or send my knuckles in.
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
08-30-2010, 02:17 PM | #1574 |
He's running the Tommy-spec ones. He says it in the quote. Less ackerman, roll center corrected 25mm.
08-31-2010, 07:15 AM | #1575 | |
The only downers are the ADD bumpsteer, as steering length changes with more lock. The distance between centers of the rack end and tie rod end. This isnt so bad as stock does this, but this is reversed now. It adds dead ahead bumpsteer too, Ie when your driving straight ahead. Your ackeman is now dynamic too, changing with amounts of lock. Can you post up a picture that shows both wheels at full lock ?(underneath, midslide, hard parked etc) once again not a huge problem, but if its not spot on you will get anti ackerman quickly. But IMO it still fixes many of the problems that we face when drifting, and the good outways the bad IMO. And reps for just working out the binding knuckle secret. |
08-31-2010, 07:36 AM | #1576 |
You, good sir, should read through the last several pages of this thread. The PSM knuckles are very well developed, and correct for bumpsteer and roll center. They also have less ackerman, but nowhere near anti-ackerman.
08-31-2010, 07:42 AM | #1577 |
Not to mention, if there is some super secret you should be talking about it, not talking from a pedestal. This thread isn't to show off what you know, its to share what you know with others so people who know more then you can assist with your ideas and make them better.
08-31-2010, 07:44 AM | #1578 | |
A genuine plot on an aligner. I can see the ackerman a few pages back now, but as stated in my post, please measure ackerman at all steering wheel positions, not just MAX lock. Lock to lock ackerman will be identical, and if the car is aligned it will have 0 at center too, but measure the dynamic, I suspect it will grow and shrink on the each side independently. |
08-31-2010, 07:57 AM | #1579 |
I am not sure about the total removal of bumpsteer, but they have bumpsteer correction built into their knuckles. You can see it in this picture:
08-31-2010, 07:58 AM | #1580 | |
Im not trying to start a pissing fight, sorry. Just the province of bumpsteer removal without figures doesnt sit well. I have a suspension tuning business in Aus, been playing with these for a while now. I have never really cared about the cash in it, don't worry about that :P Here is a WIY FCA kit, most of the components came from the US anyway, hahaha |
08-31-2010, 08:15 AM | #1581 | |
I'm pretty sure you're confusing ackerman with toe and dynamic toe? There will never be any ackerman at center, on any car, ever. And of course changing ackerman will change dynamic toe, they're basically interchangable. It's a pretty simple curve of the tie rod end, nothing crazy. So the above is a kit to make FLCA's like the PSM ones I take it? Except with modified stock arms and bearing cups for the ball joint ends, yeah? Just to let you know, Ikeya Formula was the first to design arms like that.
08-31-2010, 08:49 AM | #1582 |
How about we all take the ego out of this thread and just talk about what matters?
THE GODAMNED SUSPENSION. Not who the fuck came up with who first. Nissan obviously came up with this shit first, as they made the fucking car. I just don't think they gave a shit with drifting and how the car's suspension would be in a lowered car, or else their knuckles wouldn't be the way they are. |
08-31-2010, 09:03 AM | #1583 |
Im not trying to emphasise who came up with it first, just that more research has been done than in this thread, and there are reasons that it is bad practice.
Im not confusing the 2 don't worry. Due to the new tie rod end angle, when your wheel is centered your tie rod ends now angle inwards (the angle is level to the ground stock) As you turn wheels your tie rod/ rack length alters. You can see here, the tie rod end no longer points to the ground at straight ahead. Now you can imagine/see what happens at full lock either way. Instead of being equal angle both sides, it is now different lock to lock. It makes the car feel a bit odd, and WONT remove bumpsteer. Nissan spent alot of time getting this stuff dead perfect, to alter a few points and angles really upsets things. As far as the FLCA, it was the dentsport items that I based them off, I never said they were new. Just easily rebuilt once made. No use of the stock arm, and they use a 3/4 bolt not a small taper bolt. Ive seen too many fail when the taper was incorrect, or the finish on the material was too coarse. Def hasn't had issues with the 3/4s so far, and its a similar kit, but witha 7/8 bearing, and youll see the Roll center cones sit in the bearing, removing (reducing significantly) lateral load on the bolt. |
08-31-2010, 09:34 AM | #1584 |
The whole point of the Parts Shop MAX knuckle is to make the tie rods level to the ground when the car is on the ground.
Then you can use the other parts to bring the FLCA pivot points parallel with the tie rod pivot points. Thus, eliminating bumpsteer.
08-31-2010, 09:58 AM | #1585 | |
That wheel is turned brah. Why don't you ask questions and THEN give your input instead of assuming? I also think you have a misconstrued way of how bumpsteer works? or maybe you're not explaining yourself properly? |
08-31-2010, 10:16 AM | #1586 | |
That doesn't matter one bit as long as you aren't binding the tie rod stud while steering. Bumpsteer occurs due to different arcs of the FLCA and tie rod(for a strut car like ours) during suspension travel. Once both pivots are in line with each other, they follow the same arc, and you don't have toe changes with suspension travel. What do you think bumpsteer is, because that doesn't sound like what you're referencing.
08-31-2010, 10:32 AM | #1587 | |
I can go out and take a bunch of pictures of random bearings and bolts and shit and call it my kit too. Honestly, you come in here on your high horse, calling everyone out, but your high horse is just a little donkey. Get real or get out. |
08-31-2010, 03:07 PM | #1589 |
^ aint fighting,..just hittin people with knowledge.
some idea's and inventions are created off debates! im nothin' special but i for one cant wait for these to go public........the science and rigorous testing and Q&A that seems to go into these and all other PBM parts sold me long ago
cONtRol FReAkS |
08-31-2010, 04:35 PM | #1590 | ||
Just to clarify, there is only one SAK and the difference is how much towards the outside you rotate it before its welded in. The more you rotate it out the less ackerman you get. So when I say Tommy Roberts Spec, I say that because its the first one we rotated to that extreme (still not zero, it still has 10 degrees of difference between innner and outer tire angles) And the front roll center is a separate mod, no kit for that just custom labor $150+return shipping. Tommy does not have the new LCA, and I do so thats an independant mod too, compromise being you will loose negative camber ability without a longer LCA while having the roll center adjusted knuckle. Quote:
There was some pictures clearly showing both wheels on previous pages. Next event is at the end of next month so maybe we'll get some cool action shots. Thanks!
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-31-2010 at 05:09 PM.. |
