Old 05-19-2010, 04:59 AM   #1591
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
i was about to edit my post.
im just running it for stock RB20 setup for now. 7 PSI stock but good up to 10-12 PSI
but i heard this BOV dont hold over 14 psi?
killer240 is offline   Reply With Quote
Old 05-19-2010, 05:58 AM   #1592
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
Despite being stronger/harder, do any aftermarket tie rod ends have more threads on the rack side for spacers?
Or are they the same as stock?
sonomadrifter is offline   Reply With Quote
Old 05-19-2010, 06:50 AM   #1593
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
If that's the case, your fine. You can also swap out for a Bosch BOV (~$30-40 at Advanced Auto). Search google for specs and install, very popular.
Corbic is offline   Reply With Quote
Old 05-19-2010, 06:54 AM   #1594
Corbic
Corbic's Avatar
Yes/No
Check out Phase2Motortrend
There is a good selection of tie-rods with built in spacing, no need for washers and that crap.
I have Pike Peaks, not bad.
Old 05-19-2010, 08:25 AM   #1595
sqd
sqd's Avatar
sqd is an unknown quantity at this point
I think I read something about this before, but now I don't remember what the answer was - when I lower my car w/ my coilovers, I get a clunking sound coming from the front, drivers side, when going over bumps. When I raise it a bit, it disappears. Why?
sqd is offline   Reply With Quote
Old 05-19-2010, 09:28 AM   #1596
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
^check the locking collars (unsure if i used the correct term)
Will the harbor freight valve spring compressor work with the valves springs in a KA motor?
it looks similar to:
reason why i ask is because; in the fsm, it shows a completely different type of valve spring compressor along with an adapter:
the head is already removed from the block, if that makes a difference.
WheelsDirty
Old 05-19-2010, 10:13 AM   #1597
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
edit: nevermind
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 05-19-2010, 11:29 AM   #1598
SERUM
SERUM's Avatar
SERUM is an unknown quantity at this point
ka24de, 3in. piping with stock muffler. How does this sound? Anyone tried it?
SERUM is offline   Reply With Quote
Old 05-19-2010, 11:41 AM   #1599
sdterrible1
sdterrible1's Avatar
sdterrible1 is an unknown quantity at this point
I just made a exhaust out of 2 3/8 straight through to stock muff. It sounds okay; I haven’t driven the car yet, but will in a few days. It’s not exactly deep sounding. It’s quiet at idle though.
sdterrible1 is offline   Reply With Quote
Old 05-19-2010, 04:56 PM   #1600
killer240
killer240's Avatar
Trader Rating: (24)
power steering/cooler question
ok so i made a p/s cooler. the one with blue fitting goes to the cooler to the can.
the other one with with polish fitting is the one i bought from rawbrokerage, the other end of it is suppose to go on where the blue fitting is and the other end is suppose to go to the pump. so the blue fitting is suppose to go to where the polished fitting is. but they got different thread size.
either way i still have to buy another fitting. but i want to know if it matters if i just dont switch it
Old 05-19-2010, 06:06 PM   #1601
Corbic
Corbic's Avatar
What do these plug into?
It was a year ago when I pulled this thing apart.
The plugs covered in foam and you can't see go to the cigarette lighter, this is under the center console in a S13 btw.
Old 05-19-2010, 06:20 PM   #1602
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
isn't one of them the mirror switch? it's been a while since i've seen and S13 center console.
Old 05-19-2010, 06:21 PM   #1603
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
it's the auto seatbelt control unit.
shiftdrift is offline   Reply With Quote
Old 05-19-2010, 06:22 PM   #1604
stinky_180
stinky_180's Avatar
Trader Rating: (26)
^^i think it goes to the automatic seatbelt control unit thingy
WheelsDirty
Old 05-19-2010, 06:52 PM   #1605
Corbic
Corbic's Avatar
That's the ticket, thanks!
Old 05-20-2010, 12:45 AM   #1606
J3123MY
J3123MY is an unknown quantity at this point
question
I have a couple of quick questions.
I have some coil overs, but they are seized. What is the best method of unseizing them?
Also, while I was changing my water pump gasket, I lost the radiator cap. I know, but shit happens. I bought some caps from auto zone, but after driving a while, the coolant goes into the reservoir and doesn't go back down until the car has cooled down considerably. Biggest headache ever. So, I got the highest level psi auto zone sold, but I think the size of the gasket is incorrect. Basically, how do I get a working cap? BTW, I was told by the previous owner that it is not an OEM radiator.
One more question. I need to change my exhaust manifold gasket, but the sensor that goes into the engine is in the way, which to take off is blocked by the heat shield. Should I just cut the wire? and do I need the heat shield in my engine bay or can I go wihtout it?
J3123MY is offline   Reply With Quote
Old 05-20-2010, 01:17 AM   #1607
Jwow
Jwow is an unknown quantity at this point
How often do I need to change the rear differential fluid? Like oil change is like between 3000-4000 miles.
Jwow is offline   Reply With Quote
Old 05-20-2010, 01:25 AM   #1608
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
Stupid question, I know, but will an S15 turbo work with an RB20det? My turbo is blown and I have this S15 turbo on my shelf...
www.realize-jp.net
Old 05-20-2010, 05:47 AM   #1609
Corbic
Corbic's Avatar
Rule of thumb-
Engine 4,000 miles
Trans 60,000 miles
Diff 100,000 miles
Rad Hoses 5 years
Waterpump 100,000 miles
Timing belt 50-90,000 (very vehicle dependent)
Accessory Belts - Visually/5 years
Balljoints 10yrs/100,000
Bushing 10yrs/100,000
Old 05-20-2010, 07:30 AM   #1610
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
For my daily, I change my diff fluid about once a year (15,000 miles). Same with the trans. Both are pretty darn simple to change.
If you are going to events, I would change it after every event or two.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 05-20-2010, 09:06 AM   #1611
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
Originally Posted by Smurf_240SX View Post
They fit I have them on mine
aha that looks super nice
i checked it out and bolt pattern is 5x120, idk how that fits but apparently it does haha. is it a little loose cos i think the holes are significantly bigger than the studs
btw i'm pretty sure thatss the parking garage where the new-er kaiser hospital is in ontario lol am i right?
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 05-20-2010, 08:31 PM   #1612
I LUV MY S13
I LUV MY S13's Avatar
i have no power inside the car; seatbelts, head lamp, gauge cluster, stereo
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 05-20-2010, 09:18 PM   #1613
Bob_Sagat
Bob_Sagat's Avatar
Bob_Sagat is an unknown quantity at this point
My dashlights wont come on (cluster/ hvac). Ive already replaced the TCU and all the fuses are fine. What else would cause this?
Bob_Sagat is offline   Reply With Quote
Old 05-21-2010, 12:40 AM   #1614
Jwow
How come every time I try to pull my key out i have to press that pin thing? How can I fix it? What do I need to purchase? Thanks for helping!
Old 05-21-2010, 12:51 AM   #1615
Teddy
Teddy's Avatar
Trader Rating: (44)
That's there for a reason. It's factory Nissan. Everyone has it.
www.realize-jp.net
Old 05-21-2010, 12:51 AM   #1616
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
haha, that's the key lock. it's oem on 240's dude. it's not a big deal.
Old 05-21-2010, 01:20 AM   #1617
Bwayan
Bwayan's Avatar
Bwayan is an unknown quantity at this point
Send a message via AIM to Bwayan
Originally Posted by hOngsterr View Post
iirc lack of post, you have to have a min of # of post to be able to give others trader ratings.
doh! Thank you sir.
Bwayan is offline   Reply With Quote
Old 05-21-2010, 07:06 AM   #1618
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
Ok heres one...
Im swapping in an SR in a few months, and the rear main seal on my KA (my daily driver) has started to leak. I think its been leaking for a while, but has just recently started to make the clutch slip on very hot days. For the most part, the clutch is fine, i just have a bit of oil coming out between the block and trans. Until now, Ive always run synthetic oil. Would it be in my benefit to switch to conventional? I would assume conventional wouldnt leak as badly. I lose about a quart between oil changes. And theres no way im pulling the trans to fix it if ive got an SR sitting in my garage just waiting to go in.
So conventional or synthetic?
Is it worth trying one of those "Rear Main Seal Fix in a Bottle" things?
How long you think i've got before I need to borrow another daily, or swap it? aka How long until my clutch starts slipping to much to drive it?
sirfallsalot243 is offline   Reply With Quote
Old 05-21-2010, 02:56 PM   #1619
Jwow
Is it possible to pull the key out without pressing that pin? It's kinda annoying. Thanks for helping again.
Old 05-21-2010, 03:17 PM   #1620
GunmetalSR
GunmetalSR is an unknown quantity at this point
Originally Posted by sirfallsalot243 View Post
Ok heres one...
drop a quart of lucas oil stabilizer...that should thicken the living shit out of the oil and slow the leak as well as protect that ka a lil better
GunmetalSR is offline   Reply With Quote
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
