02-26-2010, 11:34 AM | #511 | |
You really need to figure out where your roll centers and front and rear centers of gravity are to modify your roll center/roll axis properly. I'd imagine without some sort of drop-knuckle front, you'll need to modify your upper control arm pivot points if you intend on using the driftworks knuckles in the rear. Just a guess though.
02-28-2010, 05:32 AM | #512 |
Is the ideal roll couple zero?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
03-01-2010, 08:08 AM | #513 |
No sir, you want your roll center under your center of gravity. Your car will handle weird if your roll center is even with or above your center of gravity.
03-01-2010, 12:59 PM | #514 |
I dont know if these have been mentioned at all.
I am pretty against megan products but they sell these. Megan Racing MR-6465 Rear Roll Center Adjuster Nissan 240SX S13 89-94 for the front and the rear. i really like the DW spindles but right now they are a little out of my budget... would these be effective? |
03-01-2010, 01:11 PM | #515 |
^ it was discussed on nissan road racing, but I believe the conclusion is no. The improvement is only limited to being visual, because the pivot point in the roll center adjuster is moved upward, yet the mount where the spindle meets taper does not change.
.25 till 3 |
03-01-2010, 05:52 PM | #517 |
Before you do, it was noted by DEF that the rear multilink design doesn't require much RC adjustment due to the RC vs CG distance during cornering to be much less radical compared to the front macpherson strut design. So you could probably put the money elsewhere for better results (take a look at nissan road racing forum and read up on threads concerning roll center adjustment for the front).
Although I'm doing it because: 1. I'm curious - You'll never know till you try it, 2. I can afford it for now, and 3. If it does work to my benefit I can be that much more faster on the track. So for me it was a gamble worth taking. Good luck!
.25 till 3 |
03-02-2010, 05:40 AM | #518 |
mmdb,
Have you considered modeling the 240sx's suspension? If you have the time and money... You'd need a good set of corner scales to determine you actual front and rear CG, and then some decent software. But you might find it more helpful then adding random parts.
03-02-2010, 12:36 PM | #519 | |
Yeah, from my basic calculations, the DW knuckles put the roll centers at about ideal locations. You have to take into account the slope of the Roll axis versus the mass axis, as this determines some of your basic handling characteristics.
So it really all depends on how much you're lowering, but the rear roll center is not raised as much as you would think when you take into account the instant centers and where the CG is in the back. Take a look at 95KA's rear lower arm; With something like that angle, the roll center is way down in the ground. It needs the kind of adjustment the DW knuckles provide. Quote:
This would be awesome.
03-02-2010, 01:47 PM | #520 | |
.25 till 3 Last edited by mmdb; 03-03-2010 at 11:17 AM.. |
03-02-2010, 08:45 PM | #521 |
fair enough!
03-03-2010, 12:16 AM | #522 |
Well, I might just end up modifying some LCAs and maybe that by itself will help? Might have the upper link that connects to the upper control arm up front shortened so that the front upper control arm sits flatter. I figure if the arms don't need much roll center adjusting, it may be as simple as welding in sleeves, pressing in ball joints, and running new longer shanks, similar to what Otto did on some arms he worked on, to make a significant improvement at my height.
03-03-2010, 09:33 AM | #523 | |
03-03-2010, 09:50 AM | #524 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
ok...so they other day...(whilst slightly intoxicated and beyond tired) i was over hearing a conversation dealing with modifying the location of the steering rack to allow less wheel lock... im pretty sure i fucked something up in that sentence...but can someone explain to me...how moving the steering rack, say 1 1/2'' foward would actually help this?
or should i just sit down and shut up with the dunce cap on...lol
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
03-03-2010, 10:31 AM | #525 |
^ Go back one page, PoorMans180sx already explained why.
03-03-2010, 09:42 PM | #527 |
That looks like a pretty big notch, what are you going to do about giving that corner back its structural integrity?
03-03-2010, 09:57 PM | #528 |
I went ahead and fitted the fronts with the same cups as the rears. I was going to make full tubular FLCA but I just figured this will be a lot faster lol
03-03-2010, 10:18 PM | #529 |
Skullworks are going to using a half cut tube and weld it around the e-brake cable. I assume if that's not enough further structural pieces will need to be added to reinforce it.
.25 till 3 |
03-04-2010, 08:20 AM | #530 | |
That works. Just wondering because that was a huge chunk taken out. |
03-04-2010, 10:11 AM | #531 | |||
what software are you talking about? I'd love to get my hands on a copy of Wingeo. Quote:
take them to one of the fabricators we know and reinforce them |
03-04-2010, 10:03 PM | #532 | |
I actually just ordered some new 3/4 to 5/8ths reducers that will work way better. I am trying to figure out my tie rod situation up front right now. I am using a custom M16 aurora heim joint tie rod right now but the stud part has me stumped as I cannot find a high misalignment spacer that doesn't reduce it to a M12. I think I might have to drill out my spacers to accept a M14......or bite the bullet and get some 5/8ths heim joints and redo the whole set up and just run the same shank I have in my LCAs - then drill out the spindle again. I am going to order some spacers and attempt to calculate my instant and roll centers and adjust the LCAs properly....or I might just space the front out more then the rear and hope it feels good, HAHA!
Instagram - SJKnoop |
03-05-2010, 07:45 AM | #533 |
Here's a interesting discussion on some software.
Automotive suspension engineering - Software for Suspension Design They can get CRAZY$$$$, but I know there's a simpler/more affordable one I saw somewhere. It's going to be a while till my LSx swap is done, so I'm not too concerned about it till then. But it is interesting.
03-05-2010, 10:33 AM | #534 |
95KAturbo - dude, you should have told me like, last week, before I ordered the raw materials.
I am making a turnbuckle for M14x1.5 to 5/8-18 to use on Tein S-chassis tie rods, using 5/8" bolts for the tie rod ends. I'm using the 2 piece QA1 rod ends that allows for 64 degrees of misalignment too, so that should be plenty. Only thing is, I'm still on stock knuckles, so I will be making the turnbuckle as short as possible so that I won't have an issue of having massive toe in due to the overall length of the tie rods + tie rod ends being too long. I'm going to have a machine shop do this for me, so if you're interested, let me know, I already know where to get everything and will have the plans drawn out with the machine shop, so it's just a matter of if you want this done, I can get it done for you in no time for not a whole lot of dough either. PM me for more details if you are interested. |
03-05-2010, 02:40 PM | #536 |
Why are you guys not using SPL tie rod ends? You making them cheaper or something?
Just thought I'd share this speedhunters article on the Garage Ito R34. Coolest suspension design that I have seen pictures of: CAR FEATURE>> GARAGE ITO WITH PROSTOCK GT-R - Speedhunters
03-05-2010, 02:47 PM | #537 |
not giving a fuck
i think im just gonna go home tonight and read this thead begining to fucking end...
03-05-2010, 05:53 PM | #539 | |
Super baller, custom work from well known companies = $$$$$$$$$$$$ We were given an early Porsche tiptronic transmission and told to take it apart and replace whatever we could with titanium about 15 parts and a barrel of money later we were able to shave about 11lbs off tranny was disposed of I can't imagine ever having that much money |
03-06-2010, 12:11 AM | #540 |
Any opinions on this? I've only seen the washer type spacers like what SPL sells. Apparently you only use 1 of these on the passenger side. Do you guys that use modded knuckles use steering spacers as well? |
Tags |
anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
