Old 01-28-2010, 02:57 PM   #451
WISH ONE
^samesies...........
Old 01-28-2010, 02:58 PM   #452
WISH ONE
why is S0apgun always pinked????
Old 01-28-2010, 03:24 PM   #453
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
because he started a useful thread that removed a lot of clutter from the board.
oh, wait. that is the exact opposite reason why some one would NOT get pinked. i have no idea.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 01-28-2010, 05:14 PM   #454
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
I have a handful of small questions:
1. What kind of flare are these? (S13, lines to steering rack)
2. Is there a tool I can use to make them at home?
3. How do you "unbend" steel tubing to bend it to a different shape?
4. Do I have to use steel lines/fittings for power steering?
5. Not sure of the name for this, but I know what it does. Is it absolutely necessary?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 01-28-2010, 05:25 PM   #455
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
1. Can't remember. Someone else chime in!
2. Look for a "flaring kit"
Brake Pipe Flaring Kit
3. Not sure if you could without weakening the metal. But if you could I would assume pipe bender would work.
https://www.europaspares.com/BRAKE_P...PBT__2707.html
4. Again, not 100% positive.
5. No, get rid of it.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-28-2010, 05:28 PM   #456
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
because he speaks his mind about idiots and uses words that aren't approved here.
http://bhworld.wordpress.com/
Old 01-28-2010, 07:16 PM   #457
blacknblue
blacknblue is an unknown quantity at this point
I feel really stupid about asking this...
Where is the distributor center cable on the KA24DE?? It's an s14 if that makes a difference.
blacknblue is offline   Reply With Quote
Old 01-28-2010, 09:09 PM   #458
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
^harness or spark plug wires?
if the spark plug wire... its in the center if the distributor...
WheelsDirty
Old 01-28-2010, 11:58 PM   #459
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
Which year model s14's came with the steering wheel with the stitching across the grip? I believe it was a s14 wheel I saw.
thanks
s13pignose is offline   Reply With Quote
Old 01-29-2010, 11:22 AM   #460
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
i tried to check the tps on my redtop(thats running like shit) black to ground and red to the middle wire of tps. turn on ignition i get nothing. no voltage everidle or WOT..
is my tps dead? obviously?
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 01-29-2010, 02:04 PM   #461
My$800S14
My$800S14's Avatar
My$800S14 is an unknown quantity at this point
Originally Posted by My$800S14 View Post
Does the SOHC Transmission have shorter gears than the DOHC Transmission on a 240sx? and also, will a SOHC transmission bolt up to a DOHC block, or DOHC bell housing? what would need to be done to do this, obviously it would only be worth it if the gear ratio inside of the transmission was different.
Nobody knows?
My$800S14 is offline   Reply With Quote
Old 01-29-2010, 02:11 PM   #462
Antihero983
Antihero983's Avatar
The KA trannies are identical. They bolt up to either SOHC or DOHC.
Have a pleasant day.
Old 01-29-2010, 02:52 PM   #463
drftkng951
drftkng951's Avatar
drftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond repute
does anyone know where i can find the key code for the ignition?
J.SUN
drftkng951 is offline   Reply With Quote
Old 01-29-2010, 03:23 PM   #464
stinky_180
stinky_180's Avatar
Trader Rating: (26)
^usually in the glove box. sometimes in the oem manual
WheelsDirty
Old 01-29-2010, 03:24 PM   #465
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Originally Posted by stinky_180 View Post
Any differences between SOHC/DOHC KA24 rear crankshaft main seals? (interchangeable?)
and about 49hrs later, no answer. so here it is again
WheelsDirty
Old 01-29-2010, 03:28 PM   #466
NeedCAforS13
NeedCAforS13's Avatar
NeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura about
Send a message via AIM to NeedCAforS13
I would say yes it should be, but it's not exactly a part you want to have to replace twice.
And honestly, what does a rear main seal cost? $20? Just get the right one...
Edit, appears to be the same.
http://www.courtesyparts.com/240sx-p...1420_1423.html
NeedCAforS13 is offline   Reply With Quote
Old 01-29-2010, 03:29 PM   #467
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
Im 99% sure they are the same. To double check just go to an auto parts website and see if they use the same part number.
instagram: madness_garages14
mothon is offline   Reply With Quote
Old 01-29-2010, 04:00 PM   #468
stinky_180
stinky_180's Avatar
Trader Rating: (26)
yea, i accidentally bought a DOHC one for my SOHC. just wanting to confirm. thanks for the answer fellas, much appreciated!
WheelsDirty
Old 01-29-2010, 07:47 PM   #469
xBtony
xBtony's Avatar
xBtony is an unknown quantity at this point
Kinda of a vauge question. but what bolts/nuts/washers or anything, do i need to bolt up the stock exhaust. the exhaust manifold is already on the block. but all the rest isnt on. lol.
xBtony is offline   Reply With Quote
Old 01-29-2010, 09:19 PM   #470
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
When doing an Auto to 5 Speed swap can you avoid having to do the little bit of extra wiring if you remove the Automatic lower harness and replace it with the 5 Speed lower harness?
Old 01-29-2010, 10:06 PM   #471
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
hmm.. maybe vague, but
get the bolts and nuts to bolt onto the manifold o.o
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 01-29-2010, 10:09 PM   #472
NINJASPY
NINJASPY is on a distinguished road
are ka24de truck blocks the same as s14 blocks?
I found a brand new bare shortblock for sale.
NINJASPY is offline   Reply With Quote
Old 01-29-2010, 10:42 PM   #473
93superHICAS
93superHICAS's Avatar
93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice93superHICAS is just really nice
Send a message via AIM to 93superHICAS Send a message via Yahoo to 93superHICAS
when doing auto to manual the only wiring needed to be done is connecting the inhibitor(sp) wire together and your optional reverse lights.
when life gets hard, i pick up the card with the smiley face
93superHICAS is offline   Reply With Quote
Old 01-29-2010, 11:28 PM   #474
xBtony
xBtony's Avatar
lol. yeaaaa. but some cars and things need weirdo exhaust bolts with springs and random shit. and i really wanted to know the size and thread pitch.
Old 01-29-2010, 11:58 PM   #475
Dazzla
Dazzla is an unknown quantity at this point
What will happen if I remove this interlock cable? Will my key still come out of the ignition or will it be locked?
Dazzla is offline   Reply With Quote
Old 01-30-2010, 12:46 AM   #476
Mister.E
Mister.E's Avatar
Trader Rating: (53)
so if i was going to swap in an SR, having a harness that was originally auto wouldn't matter, correct? i am under the impression that it wouldn't but i just want to make sure.
Old 01-30-2010, 10:24 AM   #477
sac_norcal_916
sac_norcal_916 is an unknown quantity at this point
is there a convertible thread?
sac_norcal_916 is offline   Reply With Quote
Old 01-30-2010, 10:42 AM   #478
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
I have two questions:
1 what number wedge bulbs do I need to replace my stock indicater bulbs in my gauge cluster. I'm doing an LED swap. I already bought the big 194 bulbs for the backlighting.(i still have to buy a red 194 for the batt. indicater)
2 I've heard that the LED bulbs for the green blinker indicater arrows aren't compatible because of the anolog signal. or is it wired into the turn signal switch, wich clicks on and off like a digital signal?? thanx in advance!
joshls2 is offline   Reply With Quote
Old 01-30-2010, 11:32 AM   #479
coww-cho!!!!!
coww-cho!!!!!'s Avatar
coww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the rough
Send a message via AIM to coww-cho!!!!!
one of my favorite threads
http://zilvia.net/f/chat/212964-dope-vert-thead.html
**CoUpe LOve** #3
coww-cho!!!!! is offline   Reply With Quote
Old 01-30-2010, 12:37 PM   #480
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
no.
well when i broke my studs on my cat i just drilled it out and got bolts that fit and used it, i dont recall springs lol.
- Hong
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
