#151 |
![]() Join Date: Sep 2005
![]() ![]() Feedback Score: 2 reviews
Kognition in which way did the JIC team modify the rear toe mount? Did they rotate it so the pick up point is lower?
#153 | |
![]() Join Date: Nov 2005
That's a good idea. Moving the steering rack forward by moving that whole chunk of subframe forward.
Well, looks like I won't ever be competing in Forumula D. Oh well, I never did like FD. I can see the modification thing, but no strengthening? I think that's kinda stupid. Made some changes to the OG post.
#154 | |
![]() Join Date: Jan 2005
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
Tons of people out there running modded subframes, as well as the S14 subframe in the S13 chassis or s15 subframe in the S14. Now the rules do state that you can get an exception from Formula D, but the pick up points can not be moved more than an inch. I also remember a quote from one of the crew cheifs I ran across saying..." It's our job to cheat and it is their job to catch us." |
#155 | |
Pretty dumb. Clearly the front pickups were modified on the JIC S15. They must have got an exception.
#156 |
![]() Join Date: May 2004
Remember that the S15 left the states sometime late last year. Maybe Oct or Dec. I don't follow the Drifting rules in FD, as i am not a drifter. But maybe they did not have rules restricting it at the time? How much did the car drift? I only know it from time attack. But in any case, it's gone now. And i think that they only have the S14 now. Which has been at the fabricators forever.
#157 | |
GOT IT! so basically if youre car is fucking slammed with driftworks or psm knucklesyou may not have perfect roll center, but its going to be ALOT better than stock knuckles because on the driftworks/psm knuckles the part that hooks up to the links is much lower than stock. is that right? |
#159 | ||||
Found this stuff on PDM Racing PDM Racing - Battle Version Suspension Parts Tension Rods: Quote:
#161 |
Hahaha, It's cool man. I know how that is.
#163 |
2010 formula D rules state that the subframe can be modded for the exception of one member. What does that mean? They leave it kind vauged for the teams. NASA and SCCA 2010 rule books also do this. Different folks will interprit the rules the way they want. In any type of motorsport "Teams WIll Find an advantage" if there is not a rule. Thats why every year the rules have to be updated. Now there are ofcourse exception to any of these rules. Grandfathered laws and hate to say this but money.
I would think people want to build a track car following the latest rule books. Just makes sense!!!!
1994 FD3S Drift // 945garage // |
#164 | |
Amazon.com: How to Make Your Car Handle (0075478000012): Fred Puhn: Books I GOT THIS GIVING TO ME BY A FORMULA D TECH GUY. GREAT BOOK Home DECENT SITE ON ANGLE |
#165 | |
Trader Rating: (29)
The new exception rule states: 8.3.8 Provisions for vehicles with Vehicle Identification numbers 0-129 Competition vehicles with VID numbers 0-129 can opt for exemption from sections 8.1.1.1, 8.3.1, 8.3.2, 8.3.3, and 8.3.4. In such case the following is true: • Previously approved modifications of the firewall, subframe and transmission tunnel, as indicted in the vehicles technical record are allowed. • Suspension pick-up points may be moved to within 1” of the OEM location • Stock hubs must be used. “Pre 130” vehicles wishing not to use the 8.3.8 exemption must request a new VID. As for the member modification...The way I am interpeting it is that the sub frame may be modified, but can not be compleatly cut in in half, as to retain stock dimentions side to side. For instance this sub frame... ![]() would be illegal since it had been cut compleatly into three parts and welded back together, but if you did not cut the front plane and just cut out the rack mounting and moved it, then it would be legal. The only reason I can figure that they went with this is to keep competitors from widening the pick up points. |
#166 | |
Allan Staniforth's Competition Car Suspension: A Practical Handbook Amazon.com: Competition Car Suspension: A practical handbook (9781844253289): Allan Staniforth: Books |
#167 |
Well, that doesn't make it sound so bad.
#168 | |
#169 |
so you chopped it in 3 peices and welded it back? That would not pass tech in 2010. I dont want to turn this into a rulebook debate. More talk about suspension.
#172 |
Trader Rating: (29)
If you cut into two as long as the front plane was not cut then you are good to go. In the pic it looks like it was cut into three pieces. Sweet job, and great idea. How did it work out?
I did some major mods on some Ae86 lower control arms today. Added Battle Version adjusters, moved the holes for the TC rods 25mm inboard, built new adjustable sway bar mount, and plated the crap out of them. Should have cost a forture, but he is my sponsored driver. Now for some pics... ![]() ![]() ![]() ![]() |
#173 |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
How would you adjust the rear roll center on a car that has a RUCA but no RLCA like this?
![]() Would you have to modify the knuckle and/or raise the subframe? Thanks.
Holding it and...WHEEL POPS OFF! O^O^O |
#174 |
Couldn't you just alter the mounting point on the struts (custom housings) to raise the spindle. There's already a guy that makes custom housings, but I was thinking you could alter the mounting location to put the spindle wherever you wanted it, and use more minor adjustments on the LCA.
Just a thought........... |
#176 |
![]() Join Date: Jul 2005
What kind of car is that?
You can do this for your lower arms (you'll have to weld in some flat metal on the one with a hole in it): ![]() It looks like there's another arm on top of the spindle? You would need to correct that as well. Changing the strut length will just raise the car up higher, which would correct the geometry - but defeat the purpose.
![]() Instagram - SJKnoop |
#177 |
![]() Join Date: Apr 2004
That's similar to an E36/E46 rear suspension(BMW) - most of those guys just raise up the subframe as much as possible and call it good in the rear.
In our cars, the roll center doesn't drop as quickly in the rear as the front, so a huge amount of correction is not needed back there like the front.
#178 |
![]() Join Date: Oct 2004
Awesome thread guys... THose books could be found on google books. Here's a link to one.
How to make your car handle - Google Books
#180 | |
