#61 | |
![]() Join Date: Jun 2008
and it will be a slug with only a stock exhaust. After i steped outa my car and got into my buddys Sohc KA i couldnt even tell the difference between 1/4 throttle and wide open. it needs some boost to make decent power. with it all stock im pretty sure you will have to constantly kick the clutch jus to keep the tires turning over due to lack of power.but since u wanna go all motor JWT sell a cam for that motor and get headers and find a bigger throttle body if they make one for it. |
#62 |
Banned from the Marketplace
![]() Join Date: Jul 2009
yeah fo sho<3 i mean for me the ka24e is waaaaay stronger then my civic d16 non vtec lol, but i also had a few cars i messed with before, 350z & bmw m3 coupe 06 SMG <3<3<3
but from what ive seen and know, i dont like following with the crowd, cause by the end if i would drive there cars they would say , "whoa i didnt know my car could do that". lolz <3 |
#63 |
Hi Lilly
![]() Sorry I didn't realize it was you who started this thread. 1. Make sure the motor is running in tip top shape 2. Lots of track time to get a feel for the stock motor 3. Turbo that bitch through Jonathan after you get to know the car. By far the most bang for the buck for torque |
#64 | |
![]() Join Date: Sep 2006
Several of us with experience here have stated what your saying isnt true. just stop. And to the OP. I wouldnt get a lightened flywheel for drift. with the lower HP engines you want to have all the momentum and weight of that flywheel spinning so your clutch kicks are more effective. good choice on the KA as a learner engine. see you on the track and ask us KA guys out there for some advice. Its a little different in a KA car then a SR and we have certain tricks (especially for tandem). |
#66 | |
![]() Join Date: Apr 2004
Mine has been running for 2 years now and I don't know where he is on his. Another option if you want to be different. |
#68 |
I forgot to add one more piece of advice. It was given to me by a good friend of mine.
Learn as much as you can with a stock ka, it doesn't matter if it has one or two cams. Do not fear 3rd gear entries. Do not fear bouncing off the rev limiter. Do not fear clutch kicking through your firewall. Do not fear embarrassment for sucking on the track. You need to learn to take full advantage of ALL ~120whp in order to drift, there is no room for error and no room for pussies. Once you learn to make the most out of every ounce of torque and are able to do it consistently you will be ready to begin to add more expensive parts in order to gain more power. DO NOT listen to all these fanboys telling you to swap or spend hundred if not thousands of dollars to turbo the engine. If your goal is to learn and perfect the tecnique of drift then you need to look no further because you have the perfect beginers engine sitting in your car. If your goal is to impress posers are carmeets or be an internet tough guy with big $$$ dumped into a car that will never see real track use.... by all means waste your money and time. It has been proven time and time again that a stock KA is a GREAT platform to start with and the cheapest drift car to fund PERIOD. I'm MORE than willing to help anyone with what i know if they are motivated to drift. If you have questions feel free to contact me. Eric Castro and Jorge Castro drifting n/a ka tandems. Someday it WILL happen and it WILL be sweet hahaha. Examples: ![]() ![]() ![]() ![]() |
#69 | |
![]() Join Date: Dec 2007
haha to late she is coming over on friday she rather pay and have it done right =P |
#70 | |
just all in your technique, and if you can drift a less hp car. imagine how easy it is to swing around a power drift car. besides look at it this way... keiichi tsuchiya learn in a under power 86 corolla. |
#74 | |
and for sure i will learn about my car more, it is basiclly still stock and i love it! it gets me places and turns heads as well hehe<3 In my opinion i like the single cam better, couple of my friends have dual cam but i dont really feel the difference besides the rpms go higher of course but i also have another question, my clutch is going out, and im wondering bout a new clutch? which is better for the buck? i already have a excedy stage 1 clutch but of course its time to change it before i go on the track and mess around with it and blow it some how lol |
#75 |
I have a stock replacement exedy clutch and pressure plate, it does teh job quite well for the abuse i give it. In terms of cheap yet effective any reputable and tested/proven brand stock replacement clutch will do. The same goes for a stage 1 if you are looking for a bit more "bite" and/or pedal feel. I always recommend a sprung clutchplate over unsprung.
Research the "white bunny" clutch/flywheel/pressureplate setup. IIRC it is a decent improvement over stock clamping force by increasing the contact patch of the clutch. It's mainly composed of stock parts IIRC and will not break the bank. I have read it will also retain the stock pedal feel so daily driving will not be affected in the least. Hopefully someone with real word experience about this setup will chime in. Consider doing the throwout bearing and pilot bushing while you're down there. |
#76 |
Ive worked on Ka-t's and rode in them so dont get my age confued with what i do. it is more wise for her to boost it after she gets a feel for it, and a NA ka dosent make more torque than a SR maybe u didnt see where i put that. it only makes more torque vs a na sr
#77 |
yeah i know someday i will turbo my ka, cause i want to see what a real monster can be, and just to see what my car goes tho it will be a fun experience with this s13<3
and yes! i hope someone on here that has experience with the "white bunny" can give me a good idea how to start it as well put them in right and find the right combinations with the products. AND THANK YOU GUYS FOR NOT TELLING ME TO GO ON FORUMS AND FIGURE OUT MYSELF, I LIKE ASKING PERSONAL QUESTIONS FOR ME, I LEARN BETTER THAT WAY, AND I DONT REALLY CARE IF I GET PUT ON THE SPOT FOR IT, CAUSE IT DOESNT HURT TO ASK A QUESTION, EXSPECIALLY IF ANOTHER PERSON IS ASKING THE SAME QUESTION, OR U CAN ALWAYS BURN SOMEONE THAT DOESNT KNOW WHAT THERE TALKING BOUT ^____________^ HEHE<3 THANK YOU ALL AGAIN!!!!! ![]() |
#78 | |||
then I'd recommend the OEM Nissan, from the dealer, clutch price is right and over many clutch jobs I've been involved in, it still works the best. Quote:
I have the set up on my S14 D21 flywheel and Exedy OEM clutch search my posts about it for the details but again, its a set up that retains OEM feel and lets you hold more torque, ideal for KA-T in your case you don't seem to need it my advice, again, is to stay stock for the time being Quote:
#79 | |
I would just go with a stock clutch as well.
I put a autozone clutch in at the track 2 years ago and it is still holding up. I do over 1 event everymonth as well. And kick the shit out of the clutch and bounce the rev limiter. So if you wanna save a few bucks, just get a regular clutch since the cars not getting any big HP numbers. Quote:
It may have changed in the last couple years, idk. So maybe i am wrong. But from my understanding it has to do with having more real race parts for NA build. (And that happened because alot of race series wouldnt let the DOHC version in.) They have a higher compression. (you can swap sohc's pistons into a dohc bottom but still dont match the sohc numbers) SOHC engines breath much better. (mainly the head) If you pull up old drag race forum threads, you can get alot of really good knowledge on all motor KA builds. Plus, back in the early 2000's, a lot more people were doing N/A KA builds. |
#80 | ||||
it made more sense to develop the 3 valve SOHC KA Quote:
but I've had SOHC KA and so have friends I've ridden in a couple of DOHC KA with SOHC pistons and 248 intake/exhaust cams and their is no comparison for a cheap build, daily driver, cali smog nazi friendly, inconspicuous set up the latter is the way to go we're not far from you Eric when we get my friends car running again (spun bearing) maybe you can come and take a ride in it and see for yourself? Quote:
and that head flow isn't a limiting factor in KA NA power Quote:
one has been a head builder going back to the 70s and worked on various of the early Datsun racing ventures worked for TRD worked for Nismo during the GT3 KA development his name is Rick Kemph and has his shop in San Pedro B-Line Racing is across from him, Giancarlo - the development director of B-Line, owns a tube-framed SOHC KA powered GT3 240sx you're correct in that it's easier to build a non-streetable SOHC KA than it is to build a DOHC SOHC is legacy and has been fully optimized through the last 20 years the parts/knowledge exists if you know where to look and got $$$$ but both Rick and Giancarlo agree that the DOHC is a much better platform to build from, you will need to the leg work though. |
#81 |
![]() Join Date: Dec 2004
SOHCs are always frowned upon.
I hate that because everyone is so quick to judge and hate. Retards forget it was Nissan's flagship motor back when. Beat the shit outta that motor. Go balls deep! |
#82 |
hehe fo shure!<3
and yeah i drove my friends s13 and its all stock compared to mine, but i love the way his clutch feels, mine is hard and u have to be ruff with it, and the stock u just go how u want to go. and to like u all say, you can save money $$$! And when i get my motor in tip-top shape again by next month and buying new tires im going to start learning more about my car and driving it ^_______^ i hope i get to see u guys on the road!!!!<3<3<3 |
#83 | |
#86 | |
lol, thats great! lol Hey ManoNegra, I would love to check that out! just PM me and i will come out when its all together. I need more power than a NA build is gonna get me at this point but talking about it reminds me of building NA 510's and I am getting all excited. I absolutely love the sound and power of small NA cars. nothing like it. Maybe imma have to buy a 510 to daily so i can build a peppy NA KA with ITBs and headers. (guessing thats a 8 HP gain total, lol) |
#89 | |
we're in the process of putting it back together should be done in a few days so possible after the holidays break since my friend is going to drive it to Arizona again (yeah, he doesn't learn) Dave (drift freak) stopped by for a bit and he's also a an old school 510/Datsun guy all this Datsun talk makes me want to get a 240z |
