Old 01-07-2009, 02:18 PM   #1
89_silvia
89_silvia is an unknown quantity at this point
s13 5 lug conversion ?
ok im looking for a 5 lug conversion for my s13 but im not sure which way to go. should i go with s14 spindles with 5 lugs or should i go with a conversion kit from like Ichiba? Ive done research on both but i would just like to hear some opions on both.
Thanks
89_silvia is offline   Reply With Quote
Old 01-07-2009, 03:20 PM   #2
projectRDM
projectRDM's Avatar
It's your money, what do you want to do with it?
Ichiba is not OE but it costs less, and it's new.
OE is better quality but more money, especially if bought new.
FORMERLY R240NA
Old 01-07-2009, 05:01 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
as russ said i'd go with oem units, but then again i'm working on mine with 300zx rears since i want drum ebrake.... its all up to you, but i know i'll be getting s14 fronts oem.
Slip Gypsies Blog
not sure if you realize this
Old 01-07-2009, 07:25 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
get some ichiba's and press in new oem bearings. perfect
lexus baby
5t341tH is offline   Reply With Quote
Old 01-07-2009, 08:31 PM   #5
89_silvia
im leaning towards the s14 spindles with 5 lug and 300zx rears just cuz id rather spend the money and have it done good the first time. im always open to hearing opions tho so thanks for the opions guys.
Old 01-07-2009, 09:24 PM   #6
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13
Don't forget to get the S14 ball joint for the S14 spindles!
Hawaiian240 is offline   Reply With Quote
Old 01-07-2009, 10:30 PM   #7
89_silvia
yup i know i need the s14 ball joints, spindles, and lca's. anything else im missing?
Old 01-07-2009, 10:31 PM   #8
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
do you need the LCA's? i thought you swap the S14 ball joint into the S13 LCA...
Old 01-07-2009, 10:54 PM   #9
projectRDM
projectRDM's Avatar
Correct. You can do the LCAs too if you want some more camber, they're 15mm longer.
FORMERLY R240NA
Old 01-12-2009, 06:03 PM   #10
rhd180
rhd180's Avatar
rhd180 is an unknown quantity at this point
would an s15 brake system work on an s13. my friend bought a full front clip with complete brake systems all around. would they work? this is on a 91 180sx RHD if it makes a difference
rhd180 is offline   Reply With Quote
Old 01-12-2009, 06:35 PM   #11
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Yeah Ichiba with OEM bearings is almost as good as OEM.
Because Ichiba's bearing suck.
OEM is so good in fact, I put my OLD bearings into NEW Ichiba hubs.
Old 01-12-2009, 07:17 PM   #12
eazye2000
eazye2000's Avatar
eazye2000 is an unknown quantity at this point
Send a message via AIM to eazye2000 Send a message via MSN to eazye2000
If you need S14 front and rear 5-lugs, let me know. I also have S14 front spindles as well. PM if you're interested.
I do not have ball joints, nor lower control arms.
eazye2000 is offline   Reply With Quote
Old 01-12-2009, 07:29 PM   #13
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
S15 is like the 300zx brakes IIRC, so yes
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 01-12-2009, 08:33 PM   #14
Mister.E
Mister.E's Avatar
Trader Rating: (53)
yes they will work. i have S15 Spec R pads on my 30mm Z32 calipers. damn near all the brakes are the same
Old 01-12-2009, 08:44 PM   #15
projectRDM
projectRDM's Avatar
S15 front brakes/suspension is identical to the JDM S14.
FORMERLY R240NA
Old 01-13-2009, 03:35 AM   #16
Jaketenpointo
Jaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enough
Has anyone tried this?
eBay Motors: SILVIA 240SX S13 89-94 5 LUG CONVERSION FRONT REAR HUB (item 190268375515 end time Jan-19-09 15:26:08 PST)
Its embarrassing posting a no name ebay product, but I was wondering if anyone has had any luck with them/ pressed OEM bearings into these?
Jaketenpointo is offline   Reply With Quote
Old 01-13-2009, 02:23 PM   #17
HyperTek
you could drill out the front hubs for 5 lug
trim some fat off the back to make teh studs fight right.
Then replace the wheel bearings eventually.
even easier on s14
then find some 5lug rear hubs from z32 or s14
Keep it Classy
Old 01-13-2009, 02:34 PM   #18
midnightouge
midnightouge's Avatar
midnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfection
I'm using z32 rear hubs and J30 front hubs with oem s13 bearings pressed in.
There is a write up about it, but i cant find it.
midnightouge is offline   Reply With Quote
Old 03-17-2009, 12:51 AM   #19
Black_Demon
Black_Demon is an unknown quantity at this point
okay. i am just a little confuse and don't know if it is true but when i look on the ichiba website and they say that it comes with the oem bearing pressed in???? so is this true or not? is it just some kind of ichiba bearing or is it real oem???? here is the site ICHIBA 240SX S13 5-lug Conversion Front
Black_Demon is offline   Reply With Quote
Old 03-17-2009, 01:15 AM   #20
LongGrain
LongGrain's Avatar
its OEM "spec" or OEM "style"
not a real nissan product per se
i have ichiba fronts and S14 rears and have not had any problems. i swapped my 4 lug stuff with a local guy so i'm not sure if my fronts had the bearing replaced or not, but they are holding up fine for me.
LongGrain is offline   Reply With Quote
Old 03-17-2009, 01:32 AM   #21
hpipro4
hpipro4's Avatar
Trader Rating: (71)
hpipro4 is an unknown quantity at this point
Feedback Score: 71 reviews
does anyone know if the older model of ichiba frt hub have oem bearing?
rear ichiba hubs splines to which axles? s13 right?
also z32 rear hubs won't spline on stock s13 axles correct?
thnx ya'll
hpipro4 is offline   Reply With Quote
Old 03-17-2009, 01:33 AM   #22
90hatchie
Banned from the Marketplace
z32 NA hubs bolt right up
90hatchie is offline   Reply With Quote
Old 03-17-2009, 01:34 AM   #23
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Send a message via AIM to hOngsterr
ppl have told me to go 5 lug with the s14 because OEM are stronger than the ichiba's or what not,
thats the only thing thats slowing me down from upgrading
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 03-17-2009, 01:38 AM   #24
hpipro4
hpipro4's Avatar
Trader Rating: (71)
im guessing i have the turbo z32 rear hubs then cause s13 axles wont spline on hub....hole is too big!!!
Old 03-17-2009, 02:01 PM   #25
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
im using s14 5lug hubs, with stock brakes, s13 lca and s13 ball joints
some pics of my front 5lug install
civilized_drifter is offline   Reply With Quote
Old 03-19-2009, 06:24 AM   #26
calehall08
calehall08 is an unknown quantity at this point
I'm using the ebay ones with brand new oem bearing pressed in for the front. And I'm just using s14 hubs in the rear
calehall08 is offline   Reply With Quote
Old 09-24-2009, 11:04 PM   #27
bboyswoosh87
bboyswoosh87's Avatar
bboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enough
Is there a write up on how to do this? Anyone know?
bboyswoosh87 is offline   Reply With Quote
Old 09-25-2009, 05:15 AM   #28
projectRDM
projectRDM's Avatar
You bumped a six month old thread to ask how to install a ball joint? Are you really that fucking stupid?
1) Remove old ball joint.
2) Install new ball joint.
If that escapes you, wash your mouth out with buckshot. Please.
FORMERLY R240NA
Old 09-25-2009, 09:47 AM   #29
Z33dori
Z33dori's Avatar
Fucking awesome
but you forgot to mention he needs to press out the BJ..... yes the BJ
Old 09-25-2009, 08:44 PM   #30
bboyswoosh87
First of all your a prick go some where else with your god complex.
Second, You know most people use s14 ball joints on s13 LCA's. He used a s13 ball joint with s13 Front LCA's.
If your gonna talk s**** go some where else. At least I didnt open up another thread thats useless.
5 lug conversion, s13, s14
