11-15-2008, 08:53 AM | #661 |
Re-Visited the Dyno...
So I took my car back to the dyno yesterday after changing a few things that gave me problems last time - BOV, couplers, fans, boost cont., actuator, etc..
Heres the thing which baffled the fawk outta me and everyone there - I am running a GT2871r .64a/r with Tomei 256/256, 740cc, etc.. all the nessessary mods for 350ish rwhp @ 10psi (ATP's "Special" Actuator) I made 296rwhp/256rwtq @15psi I made 328rwhp/283rwtq - everything seemed spot on - for those 2 runs So we Tried for 18-19psi - Car would completely fall flat on its face @ 6500rpm and 330rwhp as if it had some sort of rev limitter (PowerFC was set to 7400rpm) AFR's were perfect, timing was good, hp and tq curve looked great.. it Just Stopped @ 6500 rpm even holding the pedal down - it sounded like someone had turned on the dyno brake (if that makes any sense) Under no Load or lower psi the car would rev out perfect in/out of gear The PowerFC was reading the MAFS max voltage? @ 4400mv The TPS graph showed it was reading fine AFR's were perfect Timing was dead on WTF? Sidenote: The shop owner said the turbo may be failing @ higher psi or Locking up (which should/would restrict air flow causing the symptoms) He mentioned that he'd seen this before - idk guys wtf?! help
11-15-2008, 09:22 AM | #663 |
He's bsing you.... What MAFS are you running? That is so weird.... on my N62 I run 18 PSI and I still don't max the MAFS out....
Turn and Burn! |
11-15-2008, 09:25 AM | #664 |
it isnt maxing out a z maf - thats for sure.
is there a "fuelcut" setting or a load limit on a powerFC?
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
11-15-2008, 01:42 PM | #666 |
bro, it's your cams. here's my dyno with boost control problems and step 1 hks 256/256 cams. you need more duration. mine at 10 psi with boost conrtoller problems as you can see.
otherwise same setup. i'm getting a retune with bigger cams and smaller injectors and now i have a boost controller installed for my next tune.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
11-15-2008, 05:37 PM | #667 | |
I couldnt tell ya - ill ask my tuner
11-15-2008, 05:38 PM | #668 | |
11-16-2008, 12:08 AM | #669 |
honestly I wasn't in the car while it was being tuned. "steve" from "shadowerks" was. you'd have to pm him about that.
11-16-2008, 04:56 AM | #670 | |
LoverTechnologies "Half Broken Things!" Last edited by cotbu; 11-16-2008 at 05:05 AM.. Reason: Late sarcasm detection |
11-16-2008, 05:44 AM | #671 |
if shadows is doing your car - he would know -
i never used a PFC - and i know he's a haltech master (maybe pm brianw or shawn (RT)
11-25-2008, 05:38 PM | #675 | |
TUNAS. Jalostotitlan Jalisco |
11-25-2008, 06:02 PM | #676 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
Extrude Hone, External Gate, and Swain Coat are still LESS than getting a worthwhile tubular manifold. Even then, you can't be promised that it won't crack and won't make the same power. I'm not sure what you read, but my car is full of real world parts, assembled by a real world guy. Trust me when I say, if I was building a race motor with this turbo, that it would make much more power and spin much higher...but alas, this is a street car. Quote:
Seriously, hook at brother up I'm not scurrrred hehe. Although I may lose my fan club (oh sarcastic me) haha. Quote:
Check to see if you're blowing out spark? Gap them puppies down to .022 Not bad at all! S3's love stock springs, but love upgraded jwt springs as well (JWT no longer sells retainers, they use OEM ones)
11-25-2008, 09:11 PM | #677 |
I do not have the boost cont. for the power fc - im using a Greddy Profec-B Spec II so the Power FC Has no way to tell how much boost im puttin out
11-25-2008, 09:14 PM | #678 | |
I will try gapping the plugs down some more this weekend thank you for the help
11-25-2008, 09:20 PM | #679 |
Thanks for clearing that up. Btw cody, I see that you're running a Greddy elbow what's your input on that? Does it really help separate the gases and help spool? Do you think it would fit with the GT2871R GTS version since it has a S15 compressor housing.
11-25-2008, 09:33 PM | #680 |
It does work because it is divided all the way down past the flange, so yes it does work. Yes it would fit because the turbine side is the same as all other T25s...
Turn and Burn! |
11-25-2008, 10:57 PM | #681 |
Jus wanted to know what you guys think i will be putting down on stock 8 psi
this is my set up: SR20det Red top GT2871r .64 3' inch inlet on stock boost Greddy intake manifold Megan exhaust manifold Megan elbow Stock Cams 370cc injectors megan down pipe & test pipe HKS HI power exhaust Exedy stage 2 Stock 62 ECU ARP Head Stids Apex 1.1mm Metal Head Gasket FMIC |
11-25-2008, 11:08 PM | #682 | |
Trader Rating: (58)
11-25-2008, 11:11 PM | #683 |
^^LOL that is so sad! Spend some money on other stuff instead of I have stuff... OMG... Lol.... I don't think you CAN run 8PSI on a GT2871R...
Sad....
Turn and Burn! |
11-25-2008, 11:44 PM | #684 |
i also have no a/c or ps i think it should be around 250whp give or take but i dono. im getting cams,740cc,and a Power FC.
well the car isnt running yet and i herd stock boost is 8 psi on the 2871r. I dont think the stock maf will be maxed. i have a N62 but its jus sitting in my garage until i get it tuned. I jus need to daily drive it for now, jus wondering though what it would make at what ever the stock boost is. |
11-25-2008, 11:53 PM | #685 |
Dude... OMFG.... Boost pressure does not mean that is how much air is running through your engine. GT2871R at 8PSI > T25 at 8PSI in airflow.... You will be running lean and asking to blow your motor... Or at least running close to Maximum flow for your injectors.... It is a risk for running that turbo with an untuned ecu as it may not be able to compensate for the increase in airflow into the motor....
Secondly you cannot run a N62 on a stock ecu without a piggy back or a standalone anyways....
Turn and Burn! |
11-26-2008, 12:00 AM | #686 | ||
and thats why my N62 is jus sitting, im waiting till i get enough money to buy the Power FC. Im not stupid. but im going to buy a wide band with my next check. |
11-26-2008, 12:16 AM | #688 |
I didn't bother, but i would guess it was kinda high. but i knoe im in need of 740cc. and the Power FC but money is pretty tight because i jus got this stuff. jus want the car driveable for now. I think it should be ok as long as i dont turn up the boost.
11-26-2008, 12:57 AM | #689 |
At 13 to 14 psi you are running 95 - 100% of the injectors which is not safe at all. At 8psi it ain't going to be much better on that turbo... Trust me not safe to run it like that. I know money is tight, SO maybe you should just get a rom tune from JWT or enthalpy or something... A PFC is about 50 - 70% more because you will need to tune it and its like 100 an hour to tune on top of that....
Turn and Burn! |
11-26-2008, 05:57 PM | #690 | |
It looks like it would hit the stock wastegate diverter. Maybe you're referring to the GT2871R with the 3 inch inlet not the GTRS version. |
