Old 07-03-2008, 09:04 PM   #1
koolcat
koolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-known
Send a message via AIM to koolcat
s14 header
I just bought it cause the seller said i can use it on my 91 ka24de. Can i use that on a s13 ka24de? Everything line up but there is another line from the s13 which i don't know what it is. It is like the egr line but below the oxygen sensor. Can i just leave it out? Will it affect anything? Sorry search but can't find anything.
thanks
koolcat is offline   Reply With Quote
Old 07-04-2008, 08:25 AM   #2
orion::S14
orion::S14's Avatar
The extra line on the stock S13 exhaust manifold is for the AIV/PAIR valve...and should be removed.
You're in GA, with no emissions testing...so ditch it.
Remove the metal line, the rubber line, and the box. Cap the hole in your airbox, if you still have the stock airbox.
- Brian
www.KA24DEvelopment.com
Old 07-04-2008, 03:25 PM   #3
koolcat
Oh i do need emission, i live in the city so they do it here. So with out the aiv/pair valve i will not pass emission no matter what? Hey thanks for the reply
Old 07-06-2008, 12:05 AM   #4
koolcat
hey guys, what happen if i took my stock header off and crank the car and fire come out of there? Also if i step on the gas fire shoot out farther but if it just idle, it's ok. I also took the aiv/pair valve out.
Old 07-06-2008, 12:10 AM   #5
murda-c
murda-c's Avatar
yeah the fire is normal.
Don't do that again.
Old 07-06-2008, 12:13 AM   #6
koolcat
So if i take out the aiv/pair valve will i pass emission in any way other then paying the guy
Old 07-06-2008, 12:45 AM   #7
Somnambulist
Somnambulist's Avatar
Somnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfection
Send a message via AIM to Somnambulist
Yeah don't do that again..
Somnambulist is offline   Reply With Quote
Old 07-06-2008, 08:54 AM   #8
koolcat
Well can you guys tell me why? Thanks...also will i be able to pass emission since i took out the aiv/pair valve on the s13 because i have an s14 header?
Old 07-06-2008, 09:13 AM   #9
projectRDM
projectRDM's Avatar
Yes. Quit asking.
FORMERLY R240NA
Old 07-06-2008, 11:17 AM   #10
koolcat
damn my bad sorry i asked but no one answer so that y i kept on asking.
Old 07-07-2008, 01:57 AM   #11
koolcat
What should i do with this egr line? Can i just buy some tube to connect the two?
Old 07-07-2008, 07:48 AM   #12
projectRDM
projectRDM's Avatar
You'll have to use the correct EGR pipe, in this case an S13. Was that really so hard to figure out?
FORMERLY R240NA
Old 07-07-2008, 07:50 AM   #13
murda-c
murda-c's Avatar
You'll need an egr tube that isn't broken for one...
Old 07-07-2008, 09:45 AM   #14
koolcat
Well im just asking can them with some rubber tube? Is it bad?
Old 07-07-2008, 05:25 PM   #15
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
I must be easily amused, that was funny.
-Retired
98s14inaz is offline   Reply With Quote
Old 07-07-2008, 11:16 PM   #16
projectRDM
projectRDM's Avatar
Rubber + exhaust = melted pile of goo.
Kid, are you even bothering to use your brain before you ask a question?
FORMERLY R240NA
Old 07-07-2008, 11:42 PM   #17
koolcat
Oh damn my bad man wasn't thinking bout that just thought of how to hook it up, got so much things going on lately can't think str8. Damn so i think i need the egr line from an s14 then since the header is for the s14.
