Old 12-19-2007, 06:56 PM   #211
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
www.racebread.com check under their USDM parts interface section. too many cross referenced parts to list in one post.
Tenchuu is offline   Reply With Quote
Old 12-31-2007, 06:25 PM   #212
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
Here's a helpful s13/ka24 - r33/rb25det wiring conversion I found. Just click "proceed".
http://racebread.com/old/Documents/harness.swf
s13coupedrfter is offline   Reply With Quote
Old 02-05-2008, 02:15 PM   #213
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
Originally Posted by TheSnail View Post
rb25 valves are the same as vg30dett valves.
Originally Posted by bardabe View Post
VG30DETT and VG30DE valves are the same. as well as cams, timing belt, thermostat, Head and Head gasket.
and some where else I read that z32 coilpacks work on rb25's? (if they do its not bolt on)
im 99% sure those are false
MODS - this thread could really use some cleaning up. Maybe deleted and started over with all FACTS instead of people arguing and people's assumtions.
ANVIL is offline   Reply With Quote
Old 02-05-2008, 11:50 PM   #214
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Z32 coilpacks aren't a bolt on to any RB, however word of mouth is Q45's work i have personally not tried it so no assurance on that but i KNOW Z32 wudn't work. im looking at one right now.
the VG30 and VG30DETT are practically the same engines with the following 2 exceptions:
the VG30DETT has Oil squirters, Forged Pistons, taped oil lines, and oil return bungs on the oil pan, and 370cc injectors.
the VG30DE has non of the above. but ha sa 10:1 compression ratio with 270cc injectors. everything else on these motors is pretty much the same / identical.
Review Thread
bardabe is offline   Reply With Quote
Old 02-07-2008, 12:11 AM   #215
ANVIL
ANVIL's Avatar
when I was in the market for rb25 valves, I measured both with an micrometer and they were different.
Old 02-07-2008, 12:18 AM   #216
ECR33S14
ECR33S14's Avatar
ECR33S14 is an unknown quantity at this point
Send a message via AIM to ECR33S14
Early model Q45 coil packs will work on a series 1 RB25 but you have to change the"boot" (i guess thats what youd call it?). the series 2 shares the same coil packs as the RB26 and nothing else.
95 Zenki-RB25 swap with a couple of things
95 Zenki-SR on the way
ECR33S14 is offline   Reply With Quote
Old 02-07-2008, 12:33 AM   #217
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
Series 2 shares coil packs with the R34 RB26 ONLY
RB25DET Series 2 and R34 RB26DETT have ignitors built into the coilpacks.
RB25DET Series 1 and R33/R32 RB26DETT have external ignitors.
kouki_s14 is offline   Reply With Quote
Old 02-18-2008, 05:39 PM   #218
lost_generation
lost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nicelost_generation is just really nice
quick question, if i were to buy a rb20det front cut, could i use all the manual parts to convert a sohc auto to a 5 speed, or do i have to find usdm parts(expl the driveshafts) i'm just not sure if the master cyl, pedals and shit would work
lost_generation is offline   Reply With Quote
Old 02-18-2008, 05:40 PM   #219
240love
240love's Avatar
240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection
i doubt they will work....
240love is offline   Reply With Quote
Old 02-18-2008, 05:41 PM   #220
kouki_s14
kouki_s14's Avatar
RB stuff wont work
Just buy new stuff, i tried to used junkyard parts, they all eventually failed so i bought all new stuff and it has been great since.
Old 02-18-2008, 05:51 PM   #221
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
Question: isnt thre a way use the Getrag 6-speed set from the R34 GTR.
Meaning , use the Rb25det trasmission casing and use the 6-speed box and bolt it up to the Rb25 casing ? ............. Eliminating the awd componet on the back of the R34 GTR box ?
racer98 is offline   Reply With Quote
Old 02-19-2008, 10:46 AM   #222
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
I'm a noob(first post) and i have a question as well. can u mate an s14 or s15 SR20 motor with a KAauto' tranny?
if so, what sort of replacment parts must i have like(replacing the ECU or fule pump) to make it all work.
joshls2 is offline   Reply With Quote
Old 02-19-2008, 11:42 AM   #223
racer98
racer98's Avatar
Um, what thread is this ? its related to RB motors and parts not SR's GTFO.
Old 02-19-2008, 01:06 PM   #224
joshls2
joshls2's Avatar
Well actually thats what i wanted to knowin the firstplace, but i asked the wrong question, sorry.. I heard some where that the bell housing of the RB25 matches that of the z32 tranny. or was it just the clutch?..hmmm.
but yah, are you able to mate a RB25 to a 300zx auto-tranny? thanx.
Old 02-19-2008, 01:53 PM   #225
racer98
racer98's Avatar
Huh?, you're in the wrong section.
Old 02-19-2008, 02:20 PM   #226
joshls2
joshls2's Avatar
''Huh?" no im not. dose any one else know, please.
Old 02-19-2008, 02:29 PM   #227
racer98
racer98's Avatar
each year of auto are diffferent, you will have to try each one for your own and figure it out. good luck.
Old 02-19-2008, 02:33 PM   #228
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Just the clutch as far as i know
96Turbo is offline   Reply With Quote
Old 02-19-2008, 02:36 PM   #229
joshls2
joshls2's Avatar
well what about mated with a 240 auto? reson why i'm asking is because i'm ready to get a rb25 but i want it to be auto. (faster shifting)
Old 02-24-2008, 01:48 PM   #230
deep in silvia
deep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to beholddeep in silvia is a splendid one to behold
What other alternator are combatable on the series I rb25det?
deep in silvia is offline   Reply With Quote
Old 02-24-2008, 01:53 PM   #231
racer98
racer98's Avatar
might want to play with gear ratio charts before you start taking something apart.
Old 02-24-2008, 01:54 PM   #232
racer98
racer98's Avatar
I have one but can you post a photo of yours, this is a completet long shot.
93 KA24 but swap the pulley.
Old 02-24-2008, 01:57 PM   #233
racer98
racer98's Avatar
What would be intresting to do with the R34 GTR transmission. (Getrag 6)
Unbolt te AWD transfercase and use the bell & housing case on a Rb25 box for a 6speed 2wd set up.
or figure out a cost effective sequential 6-speed box. Cost effective under $10K.
Old 02-24-2008, 03:52 PM   #234
deep in silvia
Old 02-27-2008, 05:06 PM   #235
cashed240
cashed240's Avatar
cashed240 has made poor choicescashed240 has made poor choicescashed240 has made poor choicescashed240 has made poor choicescashed240 has made poor choicescashed240 has made poor choices
i posted in the tech section as well but i really need help, rb20 in a coupe and floods out and revs super slow til bout 2500 then back down, smells like raw fuel, i am using a z32 maf because thats all i had and OSAKA didnt send one w the swap, now i realize that its not right for the ecu but i swapped w a ka sohc maf and ther is no change at all(di that just to see if it would make any difference) as a matter of fact it runs the same w the maf unplugged so i am confused and dont know where to look. it idles fine once it starts just the other issues. i have heard that the temp sensor might be bad?????? any ideas would be greatly appreciated. also do i need to ck coils and how?
cashed240 is offline   Reply With Quote
Old 02-27-2008, 05:13 PM   #236
racer98
racer98's Avatar
you are going to have to go over every thing with an ohms tester, would have been better if they would stop doing this chicken shit. I dont like to read stuff like this. Really bothers me.
you have a orange lable Maf and you need the green lable one that is for the Rb20DET, now you are going to have to check
-IAC
-Injectors.
-essentially rip a part the whole electrical system.
-also check your ecu and so on
Old 02-27-2008, 05:14 PM   #237
racer98
racer98's Avatar
did you try one ? from the KA and swap out the pulley ?
Old 02-27-2008, 05:21 PM   #238
Tenchuu
Tenchuu's Avatar
*****RB25DET SPARK PLUG INFO*****
most people suggest the BKR5E-11 re-gapped to .8mm. the -11 with factory gap runs like shit.
the BKR5E is gapped at .8mm already, and therefore is a drop in replacement
For iridium (and i highly suggest it, just switched mine over to these, go with a BKR5EIX. since you can't re gap iridium, that one is also gapped .8, where the BKR5EIX-11 that most people suggest is too big of gap once again.
i hope this helps weed out some false info i have found on the web, i found all this out by having changed my spark plugs a total of 11 times over the last 4 months seeing who was correct on heat range and gaps. and i can say that the iridium, 5 HR .8mm gap ones are noticeably better.
Old 02-27-2008, 08:26 PM   #239
Ptclaus98
Ptclaus98's Avatar
Ptclaus98 is an unknown quantity at this point
I was just wondering, where'd the FAQ go?
Ptclaus98 is offline   Reply With Quote
Old 02-28-2008, 02:10 PM   #240
racer20
racer20 is a well-known jackass
Send a message via AIM to racer20
So which one is hard to swap an rb25 or the rb26. I am thinking of doing this swap down the road.
Looking for a S13 shell coupe or hatch
Looking for a sr20det longblock
racer20 is offline   Reply With Quote
