04-28-2007, 07:31 AM | #61 |
Hey man thanks for your response. Its good to know that there are cheaper, smarter, options out there that allow me to do more to keep my car in a healthy shape...anywho, peace
Juicy slayin aint easy, but dammit somebody has to do it!!! |
04-28-2007, 07:40 AM | #62 |
I have a question for you. I have had a CA in my vert now for about a year and a half. I use a Greddy Multi Switcher to control my fans. For some reason when I turn on my lights or any accesories the temp raises about 2-3 degrees for every accessory I have on. I have checked all my grounds and even made a grounding kit. The problem is still there. I have even taken out the dash harness and engine harness just to double check that there is no shorts, and took out any unnecessary wiring for things that are not hooked up. Do you have any suggestions as to what is causing this? I am out of ideas as to what is making this happen.
Rich-
04-28-2007, 07:48 AM | #63 | |
It might not even be a big deal. When you have A/C and such on, you lose power, right? So maybe that's the same way. I'll look into it some, but contact GReddy as well since you're actually physically with the car and if they want you to try something you can. Yeah man, just ask around and in the end it'll help.
loading HATERS.....99% ███████████████] |
04-28-2007, 07:57 AM | #64 |
Yeah I have contacted Greddy about the issue. Their first suggestion was grounding the motor better. I had already done that so I ruled that out right away. Then they told me to use shielded wire. Did that and no change. The reason it is such a problem is because it was making my car run too cold, and was throwing the ecu into a cold start mode.
04-28-2007, 08:19 AM | #65 |
Try putting it in another car or using another unit and see what happens...
Still searching, that's kinda creepy man.
04-28-2007, 08:31 AM | #66 |
Yeah it sucks. I don't have any friends well none that want me to try it in their car. I am investigating farther today. Note: I changed the temp sensor about a week ago, because it was bad. Still no change when I did that. I look forward to what you find, that I haven't yet!
04-28-2007, 09:37 AM | #67 |
Admin Asshole
What is the REAL reasoning behind this thread.
In other words, what are you, Farzam, hoping to gain with this thread? As far as I can tell, this is an Off Topic, or Tech Topic, at best.
04-28-2007, 09:43 AM | #68 |
Just a little update. Now the dash lights and gauge lights dim for a split second when I hit the brakes. My defi gauges will reset if I hit the brakes like ~3-5 times. What do you think? STILL a weak ground?
04-28-2007, 09:48 AM | #69 | ||
He specifically said to put this thread in chat or tech and I figured chat would be best, but if you think it needs to be moved, then by all means do so. What I hope comes out of the thread is that people gain knowledge on topics addressed and to enrich the zilvia community. It seems that many n00bs get caught up in being a n00b and get left behind, and this is partially to ensure that they get a better chance at becoming a rolemodel zilvian. I'm essentially being a humanoid search function. Quote:
Call the Ghostbusters as soon as you can. Make sure the gremlins can't hear you. Get a voltometer, look around and see if everything is fine. Also check your Fuses, relays, harnesses, battery, grounds, etc...doesn't hurt to look. I'd probably take out all the electronics you have and see if the car still acts up and then slowly install/uninstall stuff. Doesn't sound like much fun, but you'll probably run into the problem. It's what I do.
04-28-2007, 10:00 AM | #70 | |
Why is front only bad? |
04-28-2007, 10:25 AM | #71 | ||
get a new alternator
i had the SAME EXACT problem on my stagea Quote:
but on a side note, it wont hurt you terribly just running the fronts....after all they do do what like 85% of the work anyways?
2015 Subaru Outback Overlander - Wagonofdoom |
04-28-2007, 10:33 AM | #73 | |
the reasoning behind 'stock rears' and z32 size fronts here in Japan is they come from the factory with different proportioning than US cars
I'm not an engineer so I know fuckall about designing proper brake proportioning in a factory car, but I know that with Z32 fronts on a US market S-chassis, the front bias goes from something like 65-70 to ~93%. Do NOT quote me on those numbers, that's just what the mice spinning the wheels in my head are telling me. Asad did a good breakdown on it on FA a few years ago.
04-28-2007, 11:10 AM | #74 | ||
90% of the time it's the alternator. I say we burn em all. Quote:
Balance. Duh.
04-28-2007, 11:14 AM | #75 | |
* > Drifting JWT powered Altima |
04-28-2007, 11:23 AM | #77 | |
200whp is easy and cheap as dirt. PM me with how to make 200whp for how much... And along with making sure you have performance parts, always remember to make sure everything is ABLE to perform. Tire pressures, no leaks, check to see everything is ready. There are plenty of checklists on this site you can get to make sure you'll be gravy trainin' it up.
04-28-2007, 11:28 AM | #79 |
OMFG I fucking love your siggggggggg everyone posirep this guy 20 times.
I remember I had a WTB thread and some premie said they were the same, lemme look around a little and i'll get back to you with a bolded, definite answer.
04-28-2007, 11:53 AM | #80 |
What are your views of knockoff external wastegates, have u ever used em and which type would you recommend. I know plenty of ppl w/ honda turbo knockoffs setup that work fine.
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
04-28-2007, 12:10 PM | #81 |
I don't cut corners.
That being said, my view on knockoffs is that they are Satan himself. We aren't driving Hondas, so why are you gonna try and rock Rotas like they're dope?
04-28-2007, 12:16 PM | #82 |
Why do you believe that the the Z in Zilvia has lost its meaning since the days of yore, although the popularity of the Z has increased since the introduction of the 350Z?
04-28-2007, 12:23 PM | #83 | |
This is a more opinionated question and since I am not a Z owner, I could not talk from true experience.
04-28-2007, 12:46 PM | #84 |
Follow up.
Although West Im sure has realized this, do you believe that the name "Zilvia" has gained such a cult like following, that another name that would suit the majority of 240sx owners of Zilvia better would ever come about? |
04-28-2007, 12:53 PM | #85 |
i have a question for you. i was driving,
when i engaged my clutch i heard a loud "CLANK" in the tranny someware and i felt it in the clutch pedal. then the rpms dropped and the car died. when i tried to start it up agian the starter just clicked. what could this mean |
04-28-2007, 12:59 PM | #86 | |
Just like to remind people to please keep their questions related to forum rules, and this is in the technical question.
Baka, contact West about that. Quote:
Do you hear your fuel pump workin or anything? When you crank it is it even turning over or what?
04-28-2007, 01:24 PM | #87 |
I found wiring diagrams for my car...but, I can't seem to find anything with the colour coding of the wires. >_< I need to know the colour coding for the dash wiring harness (specifically the gauge cluster) for a 1996 240sx and a 1998 240sx. Any chance Farzam, since you seem to have all the answer, lol?
Damn factory service manuals don't have the colour coding. Think a chiltons would have them??
04-28-2007, 01:44 PM | #88 | |
04-28-2007, 02:59 PM | #89 | |
I had someone bring in an FC and it had a bent shift fork and GOD KNOWS what happened to the rest of the tranny, but it wouldn't start cause the fork was ruined and someone ripped out sensors. I'll look into it more, i'm just trying to answer all the questions and it's starting to accumulate.
04-28-2007, 03:13 PM | #90 | |
