09-12-2006, 08:02 AM | #1 |
Will an aftermarket diff for S13/S14 fit a J30 (R200V)???
Hey all,
I have not been able to get a straight answer on this issue. Would a Kaaz/Quaife/OBX aftermarket diff designed for a 240sx (as a replacement for the OEM Open Slip unit) fit a J30 diff setup? The reason I am asking is because right now i have a J30 installed on my S14 . . . its totally shot and I want to replace it as cost effectively as possible. I could go out and buy an open slip stock diff setup and have the aftermarket piece istalled into that, but I want to know if it is possible to retain the J30 pumpkin, gearing, and casing and use them with the aftermarket unit. Thanks in advance, Cash |
09-12-2006, 08:38 AM | #2 | |
I'm in the same boat btw.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
09-12-2006, 08:55 AM | #3 |
Ya, although the J30's gearing is so nice on the highway, its easy enough to go back to a stock diff and swap in an aftermarket unit.
Maybe ill just ditch the J30 and go aftermarket/OEM Open diff. |
09-12-2006, 09:42 AM | #5 |
The short answer: YES.
A R&P set might not fit, sinc eht eJ30 has a longer pinion..but KAAZ and the like just replace the center section (the open diff unit, or the VLSD)... ...so as long as the aftermarket diff you buy is intended to be installed into an R200 VLSD (different outut shafts as compared to open diff models of aftermarket diffs)...then you're set. - Brian
www.KA24DEvelopment.com |
09-12-2006, 10:07 AM | #7 | |
for example: Kaaz lsd for factory Vlsd: DBN2625 Kaaz lsd for Factory open: DBN2620 hope I helped. |
09-12-2006, 12:26 PM | #9 | |
09-12-2006, 10:32 PM | #10 | |
