Old 10-22-2020, 05:25 PM   #1
darthbeobee
darthbeobee is an unknown quantity at this point
RB25 S1 AEM F/IC 6 Wiring Help.
Hello all
I've been having problem with my RB25det swap in my s13. The swap I bought came with an AEM F/IC 6 installed and tuned. I bought a new harness for the swap and tried to wire it into the new harness but the car won't start. I believe that it's an issue with the CAS wiring on the piggyback. I wired everything stock to the ecu and the car starts but runs rough. I tried rewiring the F/IC in using this guide for a RB26 https://www.aemelectronics.com/.../Nissan_Skyline_RB26... but made sure I wired everything to the correct ECU pins. Does anyone have any experience wiring one of these into a RB25?
darthbeobee is offline   Reply With Quote
Old 11-03-2020, 02:59 AM   #2
centuryold
centuryold is an unknown quantity at this point
Originally Posted by darthbeobee View Post
Hello all
I've been having problem with my RB25det swap in my s13. The swap I bought came with an AEM F/IC 6 installed and tuned. I bought a new harness for the swap and tried to wire it into the new harness but the car won't start. I believe that it's an issue with the CAS wiring on the piggyback. I wired everything stock to the ecu and the car starts but runs rough. I tried rewiring the F/IC in using this guide for a RB26 ... but made sure I wired everything to the correct ECU pins. Does anyone have any experience wiring one of these into a RB25?
Hey, Any update on this OP? Is it solved aol username yet?
centuryold is offline   Reply With Quote
Old 11-03-2020, 01:22 PM   #3
darthbeobee
Originally Posted by centuryold View Post
Hey, Any update on this OP? Is it solved yet?
Yes, it turns out that the plug for the CAS on the new harness was faulty. I got it running but still have some vacuum leaks to work out.
aem, rb25det, wiring diagram
