Old 08-15-2020, 04:54 PM   #1
Liam pink
Liam pink is an unknown quantity at this point
SR Sr20 breaking up under load
My sr20de plus t will free revv fine but as soon as it sees load and boost it will break up heaps and cough and splutter. I have changed plugs multiple times have had coils tested and came up okay (although sometimes it doesnt mean anything as they arent tested when hot etc) i have also done a new coil loom and had injectors cleaned. Still has the same problem. Will likely source some different coils and see if that fixes it but has anyone got any other ideas?
Liam pink is offline   Reply With Quote
Old 08-15-2020, 05:05 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
I have the same issue. Check your ignition timing
nisileighty is offline   Reply With Quote
Old 08-15-2020, 05:09 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Have a blow off valve? Could be loose and blowing open under boost. Been there done that
zombiewolf513 is offline   Reply With Quote
Old 08-15-2020, 05:14 PM   #4
oewoko
oewoko is an unknown quantity at this point
I had this problem. For me, it was the coilpacks. At first , I wrapped them with electrical tape, which helped. The old coil packs can arc to the valve cover. I am now running qr25de coil packs, and wrapped for extra measure. The car starts so much easier, and runs smoother
Sent from my SM-N910V using Tapatalk
oewoko is offline   Reply With Quote
Old 08-15-2020, 06:52 PM   #5
Liam pink
It does but ive tried it both connected and not connected and hasnt nade a difference
Old 08-15-2020, 06:52 PM   #6
Liam pink
Cheers. Ill prob get some different sr coils or do yaris coils
Old 08-15-2020, 06:53 PM   #7
Liam pink
Likely taking it to a tuner soon anyway so ill get them to look at that aswell
Old 08-16-2020, 09:14 AM   #8
S14rebuild
sr20de and u added a turbo?
Or sr20det
If its the first you will need tuning for it to run proper
Old 08-16-2020, 10:30 AM   #9
zombiewolf513
^that
Mine was a Tial so it was the mechanical spring weight blowing open connected or disconnected. I had to change the spring to a heavier one to fix it. Figured it out by removing it and wrapping the pipe with ductape for a test run. Definitly dirty but it works
Old 08-16-2020, 06:25 PM   #10
Liam pink
Or sr20det
De+t man. Added turbo. Been tuned on link g4
Old 08-16-2020, 06:32 PM   #11
S14rebuild
Its been tuned...
Check for boost leaks
Old 08-16-2020, 10:31 PM   #12
Liam pink
Its been tuned...
No boost leaks.
Old 08-17-2020, 02:05 AM   #13
zombiewolf513
Sparkplug condition and gap
Old 08-24-2020, 11:31 AM   #14
TheBlackHand
TheBlackHand's Avatar
TheBlackHand is an unknown quantity at this point
Can you clear your inbox? Trying to send you a message.
TheBlackHand is offline   Reply With Quote
Old 08-24-2020, 03:03 PM   #15
inopsey
when was the last time you maintained/inspected your fuel system? ie) changed the filter? how many miles on the fuel pump/is the fuel pump original for the car?
Old 08-24-2020, 05:42 PM   #16
S14rebuild
Op hasnt been on since the 17th....guess hes not to concerned.....
breaking up, missing, s14, silvia, sr20
