Old 06-19-2020, 07:40 PM   #1
tjdionson
tjdionson's Avatar
tjdionson is an unknown quantity at this point
Unhappy Power loss.
Wondering if anybody has ideas or a solution.
Car: 1996 240sx with s13 sr20det.
Symptoms: Key in "on" position: normal power, power to ecu, etc. If I try to start the car it clicks once or twice then a buzzing comes from fuse area in the driver's side kick panel, then power cuts off. I have to disconnect the battery and wait for a couple of minutes, reconnect , then power comes back on.
I have a brand new battery in (battery is relocated in the trunk) terminal connections are good; don't see any issues with fuses. I'm stumped. I just want to start her up and go for a drive!!!! Appreciate any help.
tjdionson is offline   Reply With Quote
Old 06-20-2020, 05:06 AM   #2
S14rebuild
Check your grounds., not just at the battery but where it bolts to the chassis, engine grounds aswell
Old 06-20-2020, 10:41 AM   #3
jr_ss
Have you bench tested the starter?
240sx, engine bay harness, sr20det 240sx s13
