09-28-2018, 02:34 PM | #1 |
Need your help, overheating and many other problems
So about 2 months ago i rebuilt the head (ka24de w/ 233k), during this period i replaced a ton of parts and it ran amazing for about a month and after that it started to develop problems such as over heating.
All of the parts i replaced: headgasket valve stem seals pretty much every gasket i had to remove relapped all of the valves new mishimoto radiator new thermostat new water pump had to bypass the heater core as it was clogged and i have no use for it anyways The problems: white or blue smoke (really hard to tell) during high rpms, 5k+ overheating at idle and driving but not all the time, only way i can cool it down is hold the rpms pretty high for a little rough idle loosing oil but my valve cover is leaking so i am not sure if i am burning oil as well. I would fix it but one of the valve cover bolts closest to the firewall broke off inside (Car came with it broken) and i cant drill it out unless i pull the head again. The car does run a little rich because i adjusted the dissy to run a little advanced (in hopes of a couple of hps) What have i done?: i have bleed the coolant a million times!!!! its usually fine for a little and then starts overheating. I have looked for leaks and i dont have any, not a single one. Someone pls help i have spent hours pulling my hair out trying to figure this out. |
09-30-2018, 11:38 PM | #2 |
If it overheats at idle, and giving it throttle will get it to cool down, you have air in the system. One of the most annoying engines to bleed i know.
5.3 V8 Swap w/ Nitrous |
09-30-2018, 11:47 PM | #3 | |
Anyway, OP, how's your clutch fan?
Tuners are big bullies |
10-01-2018, 12:26 PM | #5 |
Did you install all of said parts yourself? If so, are you sure you have your valve stem seals fully seated?
(づ。◕‿‿◕。)づ T E A M B L O O M |
