08-15-2018, 07:50 AM | #1 |
S14 Sunroof trim replacement found
No affiliation to this guy... stumbled upon this on eBay this morning.
https://www.ebay.com/itm/240sx-Silvi...4+sunroof.TRS0 Looks like us s14 sunroof guys are in luck! I plan on ordering one of these, I will update this thread with the results! |
08-15-2018, 08:34 AM | #2 |
Wow man $200
mine is all broken to hell. So I took some of my tire shield plastic and cut a strip from that, a nice long wavy strip, and permatexed that shit around the sunroof and painted it back with $1 walmart paint and its been leak free since (cost $1) isn't the whole point of 240sx that you dont actually need money to operate and maintain one? lol jk carry on |
08-15-2018, 01:08 PM | #3 |
This is interesting and I am looking forward to some better pic showing the quality. A lot of people are confused as to what this part actually does. It is not designed to form a water tight seal against the roof skin, but only to keep larger debris out like leaves, etc. There is a channel around the sunroof frame, under the glass, with a drain hose connected at each corner that lead and drain into the rockers under the door. If you are experiencing leaks, one of these hoses have come disconnected or are clogged.
08-16-2018, 07:12 AM | #6 |
11-13-2018, 08:12 AM | #8 |
Hey man, unfortunately after purchasing the item the seller cancelled the transaction saying his replacement trims are not “to his standards” understandable but BS. I was really looking forward to finally having a trim and hopefully helping the community out too haha.
03-26-2019, 10:48 AM | #12 |
Trader Rating: (25)
Feedback Score: 25 reviews
I can only find one other post that says to use the g20 sunroof, and its from this same guy in 2012. I feel like if it were true it would have become common knowledge by now. I too would like some verification.
03-26-2019, 11:07 AM | #13 |
I actually went and looked today, local wrecking yard had a 95 G20 sunroof.. it looks close and layout is the same but it is to large and will not fit, off by a few inchs.
03-29-2019, 02:56 AM | #14 |
Man w/ CTSV & a Car Seat
It has the same part number iirc. Reason it never became common knowledge is because the few people who knew about it wanted to keep it to themselves. Since I havent owned a S14 since 2014, I dont care at this point.
03-29-2019, 03:37 AM | #15 |
Its not common knowledge because it doesnt fit.. when you mentioned it in 2012 it still didnt fit..
03-29-2019, 06:40 AM | #16 |
Now, is there only one size sunroof for the s14? I think i saw a picture of an s14 that had a manual sunroof, whereas mine had the power one that retracts all the way back. Are they the same?
Tuners are big bullies |
03-29-2019, 11:09 AM | #17 |
Back when these cars were selling from dealerships new, aftermarket sunroof installations where pretty popular.. my guess is that it was just that.
03-29-2019, 06:10 PM | #18 | |
I just wasn't sure about the 14, since the 13 came with both power and manual if im not mistaken. Local car for sale in question:
03-29-2019, 10:37 PM | #19 |
I’ve got the factory options sheet somewhere for my s14. I believe the sunroofs were only available on SE models and it was called a “power moonroof”. I also believe that if your sunroof is manual it was a dealer installed item, which in that case you can probably find a trim for if you are lucky. But us factort sunroof boys are still SOL. I actually messaged the seller again recently about the trim and never received a response...
03-30-2019, 11:35 AM | #20 |
The trim on my factory sunroof came off and a few months before I sold the car I tried to fix it. The trim and gasket had basically separated from the glass at one of the corners, so I basically completely took it off, cleaned it up the best I could, and resealed it using windshield sealer, and let it dry for a day. It sealed it and didnt look bad, except now the gasket was too wide, and the sunroof wouldnt go up or down without a little manual help. I just kept it close since then, not like I ever used it much. Still, better than water getting in or duct tape xD
03-30-2019, 02:03 PM | #21 |
04-04-2019, 02:46 PM | #23 |
The original flaw with OEM sunroof seems to me that the cover is very good at sealing the small compartment away from the rest of the car, and the portion exposed to atmosphere on top is also small. So water vapor gets trapped between the two spaces and especially when sun hits it- high energy/velocity water molecules and oxygen attack the delicate intricate metal mechanisms contained within this space (it rusts the metal parts at high rate) such that twenty years later every single 240 sunroof with a cover is rusted badly.
The trick of course upon ownership is to immediately restore the surface by sanding/wirebrushing back to mostly plain metal and rust transition state and then painting/coating with some kinda permanent rust inhibitor designed for that state of metal (like a POR-15 which hasn't let me down yet. It doesn't come off of skin or clothing btw...) and then leave the cover open 1/2" or so. That tiny little gap allows the water from above to escape into the car which keeps the water from attacking the metal up there. Which of course if you have alot of it (many days of rain constantly I guess) could be an issue (Solution B: damprid desiccant exchanges) but this all assumes the mechanism survived intact enough to be operational in the first place. The gap also keeps water from pooling on the inside glass. It just has nowhere to go when the cover is shut tight. Ironic since that is what the cover is designed to do- working as intended. I Wonder if a spritz of WD40 wouldn't have prevented all of this, once per year or something by the original owners. If they were aware of the issue... how many perfect sunroofs would still be here now. I guess the WD is an ideal solvent/rust inhibitor for the mechanism because it is quite comfortable with water while still functioning as a lubricant. A rare quality for an oil but important in systems like this where we can't just raise temperature to 212*F all the time to drive out water (like engine oil). |
04-04-2019, 08:04 PM | #24 | |
Skurr Skurr |
04-05-2019, 10:56 AM | #25 |
everything up there needs to be cleaned, all rust removed. It should be obvious by looking because huge chunks of rusty metal will be falling apart everywhere. Its pretty common to find them disintegrating before your eyes. Shards of rusted metal slivers will fall down into the parts that move and jam the sunroom also. First thing I do is vacuum and scrub.
All this is from perspective of not wanting to spend any $$ on it. Just want it to work and minimal maintenance- clean it, convert/coat, if necessary replace the motor. Then periodically lubricate the assy and it should in theory last the life of the vehicle from that point. Just leave the cover open 1/2" to let the water out, and if you live in a climate where it sometimes rains a lot all the time consider additional desiccant exchanges. Although I've never done it for cars I drive everyday, I do use CaCl2 in cars that sit outside sometimes, even if they don't have sunroof because the high moisture content and stale air promotes growth of all manner of organism. |
04-26-2019, 04:55 PM | #26 |
The metal trim needs to be wire wheeled nice and primer coat of rustoleom or the like, then light sand again and apply 3M window weld sealer and a new trim piece.
Declogged all the sunroof tubes since thats another regular maintenance thing that happens that people don't practice regularly and more build up will happen on cars that sit outdoors and it won't break down the sunroof trim as bad if just use air compressor to unclog debris from sunroof track, maybe also applying like a UV ray and water repellant sealer like rainx or rustolem "never wet" to the whole thing would work nice too. Hopefully that guy starts making those trims seems like many would benefit from having a nice working s14 moonroof for the s14 240sx street cars out there.
04-29-2019, 03:38 PM | #27 |
05-28-2019, 04:54 PM | #28 |
Looks like they re posted. https://www.ebay.com/itm/240sx-SILVI...4AAOSwREhc7bGA
