Old 05-12-2018, 06:20 PM   #1
azsr20det
azsr20det is an unknown quantity at this point
Aftermarket sr20 pulleys install
So i have a set of pulleys for my sr20 i bought ages ago and want to install, before I attempt it though I just wanted to ask a few questions,
1. Is it ok to install these with the motor in the car?
2. Are any of the nuts/bolts holding the pulleys on reverse threaded?
3.does anyone make colored replacment belts?
4. Do you need any special tools to pull the stock pulleys off?
Thanks
azsr20det is offline   Reply With Quote
Old 05-13-2018, 12:45 PM   #2
jakeykunSR20
jakeykunSR20 is an unknown quantity at this point
1. Yes
2. No
3. Yes
4. No
jakeykunSR20 is offline   Reply With Quote
Old 05-17-2018, 10:47 AM   #3
azsr20det
Originally Posted by jakeykunSR20 View Post
1. Yes
2. No
3. Yes
4. No
Thank you for the straightforward answer. I plan to do the quest alternator upgrade so ill swap that one when i do that, debating replacing the ps pump, is there one that autozone sells that fits the SR or do i need to try and find one from japan or a used one? So basically i remove the belts, undo the nuts, pop old ones off, put new ones on, and replace hardware? Ive never done pulleys before, do they try and spin when loosened?
Also who makes the colored belts? Im trying to get as much color in the bay as possible, going for that bag of skittles over the top in your face look. All the black and silver shit is boring, figure if your swapping / upgrading shit might as well make it obvious its aftermarket
Old 05-17-2018, 12:34 PM   #4
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
It's gonna look funky with a rainbow engine bay.
apex128 is offline   Reply With Quote
Old 05-17-2018, 12:50 PM   #5
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
If you replace the stock harmonic balancer with a one of those cheap billet aluminum one - say bye bye to the bottom end.
Jorgs_7 is offline   Reply With Quote
Old 05-17-2018, 12:55 PM   #6
brandon519
brandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura about
My car came with one of those on it. Should I be that worried?
Also to the original poster, you may need a puller to remove the harmonic balancer.
brandon519 is offline   Reply With Quote
Old 05-17-2018, 02:07 PM   #7
harlockssx
harlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enough
I ran one for 7 years without bottom end failure...it really depends on the health of the existing bearings. My SR was extremely low mileage, which I purchased myself when I was living in Japan directly from a totaled car with only 30,000Km on the odometer. While you "should" really use a damper, there are many like myself who have run with a solid crank pulley without any issues...
Old School
harlockssx is offline   Reply With Quote
Old 05-17-2018, 02:28 PM   #8
Jorgs_7
Jorgs_7's Avatar
Ive seen a few threads / FB posts about bottom end bearing failure. Coincidentally with solid crank pulleys.
Its just a personal theory of mine. Do what you please - but here is your fair warning to avoid solid $30 crank pulleys.
Old 05-17-2018, 03:04 PM   #9
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
https://www.unorthodoxracing.com/university
GKTech
Motary is offline   Reply With Quote
Old 05-18-2018, 07:45 AM   #10
Jorgs_7
Jorgs_7's Avatar
Originally Posted by Motary View Post
That's a good read.
Still wouldn't install a $30 aftermarket solid aluminum crank pulley on my 1991 SR20.
Old 05-22-2018, 04:52 AM   #11
azsr20det
Ive only got the alternator, power steering, and ac? pulley (the 4 nut one) I dont have the main bottom one (harmonic) if i were to do the harmonic id go with a quality one like ait or whoever it was that makes the $300+ one
Old 05-26-2018, 01:25 AM   #12
6330
6330's Avatar
6330 is an unknown quantity at this point
You will need a impact gun to remove the alternator pulley
6330 is offline   Reply With Quote
