Old 06-28-2017, 12:00 AM   #1
KevinZtwin
KevinZtwin is an unknown quantity at this point
CA F/S (SoCal): 1990 300ZX TT (Whole Car & Parts!) Turbos & Wheels.
What is your FULL name? Kevin Hurst
What is your email? [email protected]
What is your phone number 7607028277
What is your City? : Long Beach
What is your State? : California
What is your Zipcode? : 90813
Price: Offers welcome (also open to trades for power boats)
The time has come to part ways with my much loved Z
Unfortunately, with family and work I just haven't kept up with the car game and now my eyes are set on a boat for the family...so it's time for the Z to find a loving home.
The car has a lot of upgrades, but I haven't driven it in 4 years (life got busy)!
It is currently registered as PNO (Planned Non-Operational) in CA with a clean title. I am looking to sell the whole car as-is, part out, or trade for a power boat. The car will not pass SMOG in CA, so if purchased as PNO you'd need to take care of that prior to registration.
I am the 2nd owner. SpecialtyZ did my service & tuning.The prior owner went to Stillen & Alt Z for service. The car has a lot of platform upgrades that can take anyone a long way if you want to put in a little elbow grease to make it your own.
On to the pics!
Car as it sit's for last few years:
Last service (6/19/13) at SZ seen on Oil Filter (clutch/flywheel install) Only driven once (on the way home from shop)!
Z1 Intercoolers:
Mod List (I'm sure there are things I'm forgetting, but here is a pretty complete list):
Engine:
VG30DETT
Stock 370cc injectors
NGK PFR6B-11B Spark Plugs (gapped to 0.035″)
AMS 4 pc. Pulley Set
Z1 Side Mount Intercoolers
Z1 Dual POP Intake
Powertrix Engine Grounding Kit
Z1 Motorsports High Capacity Oil Cooler Kit
Z1 Motorsports Silicone Intake Hoses (black)
CZP Coolant Overflow Catch Tank
Nismo Radiator Cap
Greddy Magdrain (magnetic drain plug)
Performance Electronics:
Custom Tune by SpecialtyZ
HKS Twin Power Ignition Amplifier
Blitz SBC i-Color Spec R Boost Controller
120amp Alternator
Transmission:
Z1 Premium Short Shifter
Zspeed Solid Shift Mount Bracket
AMS Steel Braided Clutch Line
HD Clutch Fork Upgrade
SZ (RPS) Max Street Clutch
SZ (RPS) Aluminum FlyWheel
Shaftmasters Aluminum 1 Piece Driveshaft
CZP Chromoly Clutch Pivot Ball
New OEM Automatic Transmission Mount
Suspension:
Powertrix Race Coilovers (8k/6k)
STILLEN Anti-Sway Bars
Powertrix Adjustable sway bar end links
Powertrix FUCA’s
Powertrix RUCA’s
Powertrix Adjustable Tension Rods
Powertrix Rear traction rods
Powertrix Rear Strut Bar (powdercoated black)
AMS HICAS Elimination Kit w/Z1 solenoid bypass fitting
New OEM Inner Hicas Tie Rods
Z1 Motorsports Rear Subframe Bushing Collars
SPL V.4 Outer Tie Rod Ends
Energy Suspension Steering Rack Bushings
Energy Suspension Front LCA Bushings
Energy Suspension F@R sway bar bushings 21mm & 28mm
Exhaust:
Megan Downpipes
Megan Testpipes
Resonated 3″ H-Pipe/Axle-back
Brakes:
12.75″ cross drilled rotors
Wilwood Forged Superlite calipers
Wilwood brake pads
Motul RBF600 Fluid
STILLEN Cross Drilled Rotors (rear)
STILLEN Metal-Matrix Brake Pads
Z1 Motorsports Brake Master Cylinder Brace
SpecialtyZ Custom steel braided brake lines
Wheels/Tires:
5Zigen FN01R-C Time Attacks (17×10″ +35 all around)
Nitto NT555RII Tires (275/40/17 all around)
DP Motorsport Carrera Cup (F:17×8.5″, R:17×9.5″)
Yokohama S.drive 255/40/17 \ Toyo Proxes4 275/40/17
Sound:
Alpine 6.5″ Front Components
Kenwood 6.5″ Rear 3 way speakers
Dual Head Unit
Interior:
1999 JSpec Shift Knob
Z1 Motorsports Red Stitched Shift boot and Ebrake boot
Corbeau CR1 Seats (Black Micro-suede) w/Corbeau Sliding Seat Rails
Lighting:
Kaixen 5000K HID Kit
1999 J-Spec Tail Lights
Fluids:
Motor oil – Royal Purple 20W-50
Transmission Oil – Royal Purple Synchromax
Differential Oil – Richmond Gear Oil
Miscellaneous:
AIV Delete
PRVR Delete
EGR Delete
Carbon Canister Delete
PTU Relocate
Tuned by SpecialtyZ on 4/20/10:
349rwhp, 371rwtq @ 14psi (91 octane)
I also have a few extra parts (reasonable offers considered):
Brand New ASH-SPEC built turbos - upgraded 2560R style wheels in Manual (.63 A/R) TUrbo housings.
Turbos T25 62trim turbine with T3 62trim compressor. Coated turbine housing, 14psi WG actuator, compressor housing inlet expanded to a tapered 2.385" inlet for ASH 2.5" planar inlet piping (also available & never installed).
17x10 +35 5Zigen FN01R-C Wheels with BRAND NEW Nitto R-Comp NT555 RII tires (275/40/17 all around)
Please message me with serious inquiries / offers.
Thanks!
KevinZtwin is offline   Reply With Quote
Old 06-28-2017, 06:38 PM   #2
dCamron
dCamron is an unknown quantity at this point
No price and this will definitely get locked/booted...
Low-to-no post count=No troll, just a reader
-dC
dCamron is offline   Reply With Quote
Old 07-05-2017, 09:40 PM   #3
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
No price & like 90% of the pictures don't work... smh
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline   Reply With Quote
Old 07-07-2017, 11:24 AM   #4
bluz370
bluz370 is an unknown quantity at this point
I will start the bidding at $4,500
bluz370 is offline   Reply With Quote
Old 07-07-2017, 11:46 AM   #5
JetS500
JetS500's Avatar
JetS500 is an unknown quantity at this point
Lol Zilvians show no mercy... get an actual price listed or what they said will happen and you'll have to write all over again. Re-host those pics so we can actually see!
JetS500 is offline   Reply With Quote
300zx, 5zigen, turbo, wheels, z32
