Old 03-19-2017, 02:19 AM   #1
Adam88
Adam88 is an unknown quantity at this point
Send a message via ICQ to Adam88 Send a message via AIM to Adam88 Send a message via Yahoo to Adam88
240sx S14 kouki 1997
Hi, For sale project kouki Fully built SR20det +400hp on 91 octane. NO trades, No part out. Price is $16500 OBO Cash only. Salvage California title, currently on non-op with NO back fees. Willing to take some easy parts of the car to fit your budget. Text me if interested, I don't answer phone calls from unkown numbers. Phone # 5595475065. Car is located in Fresno, CA.
https://fresno.craigslist.org/cto/6045611847.html
https://www.youtube.com/watch?v=MWFIdAS-xFQ
https://www.youtube.com/watch?v=9hdjbA_hhsg&fs=1" width="644" height="390">https://www.youtube.com/watch?v=9hdjbA_hhsg&fs=1" />https://www.youtube.com/watch?v=9hdjbA_hhsg">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=9hdjbA_hhsg
ENGINE:
Zenki S14 black top SR20DET
Carrillo H-beam rods
CP 87mm Pistons
ARP Head studs
ARP Main bolts
ACL race bearings
1.5mm Tomei Head gasket
1mm Oversized valves
Tomei 270 camshaft
Supertech dual valve springs
Circuit sports rocker arm stopper
Tomei Oil pan
Mishimoto oil cooler
Garrett GTX 3076R Twin Scroll
Full Race Twin Scroll manifold
Full Race Downpipe
Biltz 3" Nuerspec exhaust
Greddy Intake manifold
Greddy top feed fuel rail
ID 1000CC injectors
Tomei N15 70mm Throttle body
Tial Wastegate
ATI Crank dampener
Synapse BOV
Solid engine mounts
Walbro 255 intake pump
Wiring Specialties Pro Engine Tranny Harness
Nismo Thermostat
Circuit sports FPR
Tomei coil cover and oil cap
GodSpeed Radiator with Nismo cap
GodSpeed Intercooler
Mishemoto Electric fans with custom switch panel.
Odyssey Dry cell battery installed in the trunk
ENGINE MANAGEMENT:
AEM EMS w/ map sensor
AEM Failsafe AFR with Boost Gauge
AIM MXL Strada
MAC Boost Solenoid
TRANSMISSION:
2006 Nissan 350Z transmission W/ custom bellhousing
Transmission adapter plate
Spec Clutch Mini Twin Disc
ChaseBays clutch line
Solid transmission mount
Custom 1 piece aluminum driveshaft
Kazz 2way LSD
Greddy Diff cover
SUSPENSION:
326 power D1 spec coilovers
Megan racing- Front & Rear control arms
Megan Rear lower toe arms
Megan Rear upper control arm
Megan Rear traction arms
Megan steering bushing kit
Megan Front & Rear sway bars
Spl S14 outer tie rods
Z33 inner tie rods
Rebuild power steering rack
ChaseBays Power steering system kit.
Nismo power brace
SPL solid subframe bushings
SPL Solid Diff bushings
Greddy front and rear strut tower braces.
BRAKES:
R33 front and rear
R33 master cylinder
P2M master cylinder heat shield
Project mu D1 spec rear shoes (not installed yet)
Front & Rear Stainless steel brake lines
INTERIOR:
2 Bride Vios Low Max (Made is Japan)
2 Bride seat rails
2 G-force 6-point harness
Cusco Safety 21 6-point bolt in roll cage
Momo drifting steering wheel
NRG Hub & Quick release
NRG 3 pieces cooling panel (not installed yet)
Speedhut water temp gauge and fuel level gauge
EXTERIOR:
5-Zigen FNORC-1
2- 17X9 +15 2/ with new federal tires
2-17X10 +12 2/ with new federal tires
HID Headlights
Rear valances
non cracked dashboard
Cons
NO A/C No heater. No sound deadening. Cracked windshield.
Stock body with some dents, dings and oxidized paint.
[IMG][/IMG]
Adam88 is offline   Reply With Quote
240sx, s14, sr20det
