Old 07-21-2016, 09:52 PM   #1
Pygmy180
Pygmy180 is an unknown quantity at this point
Fuel prime no spark. Ecu??
So doing an sr swap on my 240. First problem was I wasn't getting fuel prime now I fixed that but now I'm not getting spark I checked the CAS and the timing is all good but then I took an extra look at the ecu and saw this... Are those tabs important is there a fix or no I need a whole new ecu? Where can I buy one from a trust worthy person
Pygmy180 is offline   Reply With Quote
Old 07-22-2016, 03:41 AM   #2
cotbu
cotbu's Avatar
unless they are stopping the plug from fully seating they are not the problem or issue.
open the ecu up, look and smell. check the plug side for pushed out pins. go through the wiring again. make friends with people, borrow an ecu. if this is your first swap you probably missed the coil pack and/or head ground.
Old 07-22-2016, 05:15 AM   #3
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
As long as the harness fits snug you should be fine
Old 07-22-2016, 09:33 PM   #4
Pygmy180
Thanks for the reply I'll check the ground again on the coil packs, and make sure my harness is as snug as possible. my brother has an ecu for his black top s13 sr20 I have red top. Is it safe to try his?
Old 07-23-2016, 12:09 AM   #5
cotbu
cotbu's Avatar
If he has an e5 or e6, should work fine, but definitely if you're just verifying spark.
Sent from my SM-N910T using Tapatalk
ecu, no spark, sr20
