Old 11-30-2013, 07:29 PM   #1
SeizureNoodles
SeizureNoodles is an unknown quantity at this point
RB RB with a NX16000 Digital Cluster (4 cyl tach)
Hey there Zilvia, nice to meetcha. I am in the process of acquiring a NX1600 digital cluster, to use in my s13. The only problem I am having trouble finding the answer to is how to make the 4 cylinder tachometer work with the 6 cylinder engine, as I understand that my rpms will show 33% higher than they truly are. I am working on getting a cluster from a 93 5 speed so I should be good in the speedometer department once I sort out which sensor to use, but the tach is the not so easy answer. I was hoping someone with greater knowledge of RBs and clusters/this cluster could help me figure out a solution to this.
I have been searching around for RPM converters and ways to adjust the tach on the cluster to no avail. I noticed there was a way to adjust some tachs by pulling off a casing on the back and manually adjusing, but am not sure if this is the case with the NX1600 tach. If none of you can solve my question I might have to shell up the cash and try to figure it out myself.
SeizureNoodles is offline   Reply With Quote
Old 11-25-2014, 08:21 PM   #2
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
Bump an old thread. Im wanting to do this if anyone has any info
ANVIL is offline   Reply With Quote
Old 11-26-2014, 06:12 PM   #3
seagrasser
seagrasser is an unknown quantity at this point
Dakota Digital box SGI-8. $80 bucks
S14 RB25
seagrasser is offline   Reply With Quote
Old 11-27-2014, 07:13 AM   #4
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
just make it work. I recently wired in a pulsar cluster to my rb25 and it does work. my tach was about 500rpm off before the swap and is still now. just follow the walkthrough on here. I recommend if you have a digital hud you get a analog cluster harness
supersayianjim is offline   Reply With Quote
adjustment, digital cluster, nx1600 cluster, s13 240sx, tach signal
